Author Topic: RECS 205P Electronic "centrifugal switch"  (Read 8 times)
« on: Today at 04:27:23 PM »
Hi All,
I was asked to trouble shoot a 240v 1/2hp motor that would not start on its own but would run if given a spin.
The mechanical centrifugal switch contacts were beyond repair, so I ordered an electronic version from Amazon.
It's designation is RECS 205P, It arrived without any circuit diagram! A search online  "suggested" connection diagrams that proved unsuccessful  :scratch:
I measured resistance between each lead combination and asked AI for help  :bugeye:
Following some suggestions I set up 3 incandescent bulbs, one in series with the main live and the other two to mimic start and run connections, further testing I eventually got the "start" bulb to flicker on/off
Before putting full voltage onto the motor I wired a 1.5kw infra red element in series with the motor in case there was a short circuit. I got the motor to spin but the start winding could be felt to be cutting in and out. So full voltage applied and success finally.
As far as I could find out none of the online diagrams matched what has worked, so I thought I should share my findings that may help others in the future ?
Red and Black both connect to mains live
Blue to Neutral
White to start winding  in series with starting capacitor
