Author Topic: usb stick  (Read 14828 times)
Offline kayzed1
usb stick
« on: March 02, 2026, 04:36:38 PM »
Can  anybody help: i have 3 or 4 usb sticks from Win10 loads i did on old laptops, just thought as now old i could maybe recover the 16Gig sticks, trouble is they say write protected when i try to format them. They do not have a lock switch on them..Can it be done please?.
Cheers Lyn.
Re: usb stick
« Reply #1 on: March 02, 2026, 09:22:02 PM »
Yes, probably. But I use Linux so not sure how to do it from Win. If you have one writeable USB drive, you could possibly put a Puppy Linux or EasyOS on that, reboot to it, and then use the program gparted in them to reformat the others.
If that doesn't work a disk imaging program should be able to put a new image on it. EasyDD does that in Linux. Once re-imaged you should be able to run Gparted on it and reformat to any type of disk. Probably FAT32 to keep compatible with most thumbdrives.
Re: usb stick
« Reply #2 on: March 02, 2026, 09:28:29 PM »
If you still run Windows, you can use a program called USB-Image-Tool to write an EasyOS image to a USB thumbdrive. Or any other disk image you might want by preference. Or it might be able to simply reformat the disk -- I don't know for sure, haven't tried it, because I don't run Windows.
USB-Image-Tool is available here:
Information:
https://www.alexpage.de/usb-image-tool/
Download:
https://www.alexpage.de/usb-image-tool/download/
Offline kayzed1
Re: usb stick
« Reply #3 on: March 05, 2026, 06:29:30 AM »
Thanks Steve, i will give it a try :smart:
Re: usb stick
« Reply #4 on: March 05, 2026, 08:05:32 AM »
You could try deleting the partition through diskpart and then re-creating and formatting if you don't care about the data.
To delete a protected or hidden partition using DiskPart, use the delete partition override command.  This forces DiskPart to bypass protection that prevents standard deletion, such as for OEM, recovery, or system-protected partitions.
Steps to Delete a Partition with Override:
1. Open Command Prompt as Administrator.
2. Type diskpart and press Enter.
3. Run list disk to identify the correct disk.
4. Select the disk: select disk X (replace X with the disk number).
5. List partitions: list partition.
6. Select the target partition: select partition Y (replace Y with the partition number).
7. Execute the override: delete partition override.
8. Type exit to close DiskPart.
Warning: This command permanently deletes data. Ensure you?ve backed up any important files. You cannot delete the system, boot, or active paging file partitions using this method.
Offline Muzzerboy
    • The Mighty Shiz
Re: usb stick
« Reply #5 on: March 06, 2026, 06:01:17 AM »
You might find they are simply damaged and unrecoverable. I spent several hours recently trying unsuccessfully to reformat some 8 and 16 GB USB sticks.
There are some pretty powerful tools for doing so (partman and beyond) but when these fail, you may simply have to conclude they are scrap. When the built-in controller sees a permanent hardware failure it may lock the device (ie read only) to prevent further loss of data, no matter what tools you deploy.
Luckily they are almost ten a penny these days and they are often given away free, loaded with demo software.
