Author Topic: Experiences, thoughts and rants about using Linux as a newbie after Windows  (Read 113162 times)
Same here, I have Office 97, and had used it for a very long time in Wine, but gradually moved over to LibreOffice.
I never had a paid version of PhotoShop -- I used to use some cheaper alternatives back in my Win98SE days (the last version I used). I have used PhotoFiltre also a free older photo editor in Wine.
These days I mostly use MTPaint for photo resizing/cropping and some color correction, and Gimp for anything more complicated. I don't like Gimp's interface, and have never learned much in it other than the few tools I use (color correction, perspective and other transforms, print size changes) I wish it was more intuitive for me, but I don't find it so.
Too bad LibreOffice Calc doesn't do MSExcel's macros, and has a less useful (according to my wife, an editor) track-changes methodology for collaborative work. For me, these aren't problems for my own work in a spreadsheet.
The one must-have Windows (Wine) app I absolutely depend on is the old free 3D CAD Google SketchUp versions 7 and 8. Not the newer Trimble versions ($$).
I have free plugins for the old ones that allow .dxf, and .stl saves and also a CAM plugin that outputs G-code. I've tried to learn other 3D CADs and I find them really difficult/clumsy (for me). Maybe it's just the way my mind works.
Offline sorveltaja
Do you mean apps like Freecad? If so, yes, it's free, but it has rather steep learning curve - and the fact that it keeps crashing often doesn't exactly help the learning process. That's why I've used it only for converting meshes to another format.
In the same vein, another issue with possible solution. I've used Notepad++ on Windows in the past, and now on Linux, I use Notepadqq, which is basically a clone of Notepad++.
But after installing Notepadqq, It seems to be very prone to crash with default settings. It has done that with all the Linux distros I've tested so far.
I may have read about it on the net, but one option to fix that is to go to Settings--> Preferences--> General--> Backup open document every..seconds or minutes or whatever, and uncheck that option.
In other words, disable autosaving feature. After doing that - I've not experienced such crashes.
Yup. I made a really concerted effort to learn it, using a set of video tutorials -- which worked okay. But then when I tried to draw a flywheel with fillets on tapered elliptical sectioned spokes, I found the tutorials were fine for the kinds of shapes each concentrated on, but nothing I tried would allow me to make the shapes I wanted. I gave up after it became too frustrating -- and yes there were also crashes.
I then tried the same thing in SketchUp which doesn't have native filleting ability, and yet surprisingly, I was able to get a very close approximation of what I wanted with primitives, and an add-on I found. It was SO much simpler to draw that, and modify it. One big difference I noticed is that in FreeCad you work in a 2D sketch generally to start with, while in SketchUP, you start right in 3D space and create your drawing.
Anyway, SketchUP to me does mirror the way my mind visualizes things, with basic tools that are easily understood intuitively -- at least for me.
Online RussellT
Hi Steve
Interesting.
I started trying to learn Freecad when I got a 3d printer.  I used Sketchup for the first few things I printed (like you an old free version) but I found that it regularly left holes in the mesh and it was a real struggle to correct them.  That was the motivation to learn some Freecad - and like you I did a series of video tutorials.  I have got to the stage where I can draw most of the things I want to print - which are mainly fairly simple.  I don't have trouble with Freecad crashing in Windows.
The flywheel sounds challenging to draw, whatever software you use.
Russell, I would really have liked to become proficient in FreeCAD.
I should say to be fair, it didn't crash often. I think I lost some work one time, but at a bad time in terms of overall frustration in trying to achieve a particular goal. And certainly, running old SketchUPs in WINE (a Windows-like program environment for Linux) occasionally crash, too.
If I'd ever found a path in FreeCAD, no matter how difficult, to achieve that flywheel shape, I would have stuck with it. Because I would then have then thought I'd find quicker and easier ways to do that with practice.
At one point in trying to taper an elliptical sectioned spoke, and then fillet that into the flywheel rim I reached a dead end.
It seemed to me that a possible solution was not to do that in the round, but split the spoke lengthwise -- as if making a half-pattern, before tapering it. But when I tried that, the taper was applied vertically as well as width wise, lifting the flat face, which I didn't want.
I kept running into these sorts of problems. I think they are due to functions (like taper) being pre-defined, rather than achieved through applying primitives -- as you do in SketchUP. In the latter, it's easy, just draw a straight elliptical sectioned spoke, rotate to one end, and then scale it's section with grab handles. Which you can do either uniformly or in one direction only, depending on which handle you grab.
In FreeCAD, you often have to fill in numeric specifications and preferences for an action before you actually do it. If there isn't a slot to change some spec that you need, you're out of luck.
Manipulating SketchUP objects is more analogous to manipulating physical objects made of clay. You form or deform them with on-screen tools, then afterwards set the amount of deformation more exactly by typing in a number.
I still regret not being able to use FreeCAD -- it bothers me not to succeed with something I set out to do, and I don't really want to be dependent on just a single old CAD system.
I occassionally use Fusion360 - so occassionally that things seem to change each time due to updates which can be a pain. But I find ChatGPT very goodat answering the 'How do I do . . .  and it digs me out of holes!
Offline sorveltaja
I've actually thought about starting a new thread about if there are any positive uses for AI. I have used free version of ChatGPT, and in my case, it's a valuable tool - for example, when I'm searching something on the net, and don't necessarily know what terms to use (as a non-english bugger), it can provide context to take the search further.
Yes, I've used it quite a lot on Blender and Linux issues, but sometimes, it spews things like "I'll provide laser sharp solution to your problems". At one time I told it to not overly elaborate(if that's the correct term) - just stay on the subject, and behave like the machine that you are - no emotional hooks.
I use the free version being a tight wad. Today I asked it to clarify which way up Rank Chevrons should go on British uniforms and it confirmed my view that the point is downwards. I pointed out that many AI pictures get confused even having correct and inverted ones in the same picture. It agreed and when I said it just shows how bad AI can be it started giggling !
