Author Topic: VORTRIXE & OKMO Z01 Morse Z 3 6cc Throttle Controlled Miniature Gasoline Hit & M  (Read 10385 times)
Offline Jim Dobson
VORTRIXE & OKMO Z01 Morse Z 3 6cc Throttle Controlled Miniature Gasoline Hit & Miss Engine Model
Another short vid of the Z01 which is being running in very nicely, Jin is bringing out wonderful gas engines one after another, I've had so much enjoyment from this engine running straight from taking it out of the box and it sounds wonderful running.
I'm using Marvels Mystery Oil (which was hard to come by in Australia) at 20:1 with White Gas (Shellite in Australia) which is just enough to put a bit of colour into the fuel (you can use unleaded petrol). I also put in some Ballistol which is water soluble into the water that goes into the cooling tank.
(Called 'Moosemilk by black powder pistol and rifle shooters')
