MadModder
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Gallery
Home
Help
Search
Login
Register
MadModder
Gallery, Projects and General
The Design Shop
Advice on building s simple ‘clutch’ to stop a driven accessory
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Advice on building s simple ‘clutch’ to stop a driven accessory (Read 43218 times)
Jim Dobson
Full Member
on:
September 28, 2025, 11:11:35 PM »
I’m after some advice to build a simple ‘clutch’ that can be activated by a lever to disengage a running accessory that is being run by a belt off an engine.
If in the photo below where I have drawn the red line (and that belt was longer) what type of simple ‘clutch’ could be built to be able to work to disengage the belt with a lever moved one way and then re-engage the belt with the lever moved back? This would be an extremely handy thing for me to have when running accessories of steam engines and H&M engines etc
I’ve wracked my brain and everything I have come up with would be a dud……any ideas?
Hope I’ve made some sort of sense with the above!
Logged
awemawson
Global Moderator
Hero Member
East Sussex, UK
Re: Advice on building s simple ‘clutch’ to stop a driven accessory
Reply #1 on:
September 29, 2025, 03:29:24 AM »
A tensioning pulley in the drive train mounted on an “over centre” crank that can either tighten or slacken the belt much like a flat belt overhead drive shaft would be in an Edwardian workshop.
Logged
BillTodd
Hero Member
Colchester Essex (where the lathes were made)
Reply #2 on:
September 29, 2025, 04:08:10 AM »
Or maybe roll the belt onto a free-wheeling pulley?
If you wanted a stand-alone clutch unit then a floating pulley that could be forced into contact with a moving one or a stationary block could give you both clutch and brake.
Logged
timby
Jr. Member
Reply #3 on:
September 29, 2025, 05:01:06 AM »
I am old enough to have worked in a steam sawmill, a "fast and loose " pulley as described by BillTodd was usually the choice to stop a drive but I like awemawson's idea better, a jockey pulley on an arm might look better.
Logged
Jim Dobson
Full Member
Reply #4 on:
September 29, 2025, 06:54:33 PM »
A big thanks for all the replies, much appreciated. If I can fabricate one up, this would immensely increase the pleasure I get from running small accessories of my variety of engines…..again thanks all.
Someone went to the trouble of cobbling this together to show me a way - Super appreciated!!!
https://youtube.com/watch?v=ztFepc4LHhQ
Logged
vtsteam
Global Moderator
Hero Member
Republic of Vermont
Reply #5 on:
September 30, 2025, 12:25:28 PM »
A really great reference to fast and loose pulleys, exactly as used in the day, is David Richards Steam Powered Machine Shop videos, like this one which illustrates how they worked and were set up. Dave has around 80 videos. This is only #2.
https://youtube.com/watch?v=2zI0iozg3Ns
Logged
www.youtube.com/watch?v=4sDubB0-REg
Jim Dobson
Full Member
Reply #6 on:
September 30, 2025, 07:32:08 PM »
Thanks Steve, its been a while since I've watched any of his awesome vids of his workshop.
Logged
Print
Pages: [
1
Go Up
« previous
next »
MadModder
The Design Shop
