Author Topic: The Return of No. 83, a Hot Air Engine  (Read 59327 times)
Re: The Return of No. 83, a Hot Air Engine
« Reply #100 on: April 13, 2025, 11:57:16 AM »
steadying hand pressure by increasing revs.
Have you tried clamping it down to the bench?
Heh, nope, Russell!  :lol:
« Reply #101 on: April 13, 2025, 08:04:09 PM »
I think I mentioned that the original intention was to run this little engine on wood. I wish I'd had the time when I first built it to make that possible.
Today I started making a little latch for the fire door on the firebox. I also began insulating the firebox. It will be insulated just like my melting furnace, but on a tiny model scale.
Here I've fitted a layer of fiber insulation to start with:
« Reply #102 on: April 19, 2025, 10:13:18 PM »
Working on my foundry is slowing me down on No. 83. I'm thinking about doing an iron casting to replace the brass power piston cylinder and displacer guide block. Foundry was in a sad condition, but have made big strides over the last few days
Back at it shortly.......
Offline jiihoo
  • Finland - Northern Europe
« Reply #103 on: May 12, 2025, 10:44:10 AM »
I am following with high interest.
I'd been ignoring MadModder for some time and when I started visiting again I found many interesting projects. This is one of them  :beer:.
« Reply #104 on: May 12, 2025, 04:41:55 PM »
I’m watching with great interest but my get up and go to a large extent has got and gone! I do still occasionally power up the gen set for the induction furnace to blow out the cob webs and run the pump to raise water from the bore hole through the heat exchanger as this keeps the field drain return to the stream clear, but apart from sometimes raising a bar to red heat in the pot for a bit of fun it remains idle sadly.
« Reply #105 on: May 12, 2025, 07:16:24 PM »
Glad of the company, guys!  :beer:
Today I made an ashpan out of some scrap galvanized tin:
And put some "small logs" in it -- ya know, just to see what it looked like......
« Reply #106 on: May 12, 2025, 07:31:24 PM »
Well, then I kinda figured might as well light them and see what happens........
What happened was Number 83 took off at 1500 RPM and the base of the smokestack oxidized to a beautiful shade of purple:! Finally Number 83 was running on wood, after 18 years, doing what it was intended to do!  :ddb: :ddb:
« Reply #107 on: May 13, 2025, 05:28:00 AM »
Excellent  :nrocks:
« Reply #108 on: May 15, 2025, 04:09:35 PM »
Thanks, Bill!  :beer:
Offline shipto
  • Redditch, UK
« Reply #109 on: May 16, 2025, 12:39:44 PM »
Brilliant.  :beer:
Offline Country Bubba
  • LaGrange, GA USA
« Reply #110 on: May 17, 2025, 08:14:12 AM »
Ah the sweet smell of success! Happy for you.
Art
Country Bubba
« Reply #111 on: May 17, 2025, 04:55:05 PM »
Thanks Dwayne, Country Bubba!  :beer: :beer:
« Reply #112 on: May 27, 2025, 01:13:13 PM »
I've made up a Prony brake to measure power output, in conjunction with a tachometer ( https://www.madmodder.net/index.php/topic,13897.0.html ) and now that I'm ready for more tests, it's time to tear down and clean the engine. Inspection shows a few issues:
1.) Flywheel grub screw is loose.
2.) A wear pattern of the outer rim of the main bearings is visible on the flywheel boss. This means the flywheel was contacting there, rather than bearing against the inner journal of the ball bearing. I need a shim washer to eliminate that source of friction.
3.) The steel wrist pin is lightly marking the power cylinder. I need to substitute a brass wrist pin, or shorten the pin and plug the ends with some graphite plugs.
4.) I suspected that the displacer pushrod was loose in the displacer. It screws into the far end, and was originally sealed there with a high temp adhesive. I probably broke that bond when adjusting the pushrod length awhile back.
To check for leaks, I lowered the displacer into a glass of hot water. This expands the air inside the displacer, and any leaks immediately show up as bubbles. Sure enough, they popped right out of the screwed end joint, so I have to fix that. Otherwise the internal volume of the displacer adds markedly to the dead space of the entire engine, and with the internal volume expanding and contracting a little out of phase, absorbs power that should be going to the power cylinder.
5.) The tiny amount of oil from lubricating the external parts has worked into the power and displacer cylinders, congealing, and adding friction. It was washed out with soap and water.
6.) The finish inside the displacer cylinder is slightly rough to the touch from boring. I didn't think much about it before because it's a non-contact surface, but I now imagine that it must produce air resistance at speed as it shuttles back and forth. So I think I'll hone all of the test displacer cylinders to a smoother (and similar) finish for testing. I don't think lapping is necessary, but maybe some day I'll try that as well to see if it makes a difference.
Offline nickle
« Reply #113 on: May 28, 2025, 08:01:44 AM »
Running on wood pellets as originally imagined is a fantastic outcome. Well done. On the cylinder roughness... It may actually help in some circumstances. A turbulent boundary layer caused by roughness can actually reduce overall drag under certain conditions... Think dimples on a golf ball type thing... Smooth golf balls are higher drag and don't go as far. I've heard some engine tuning types actually prefer rougher ports when porting performance engines for the same reason. I can't recall how to set up the math's as it's been an awful long time since I learned about it. Before and after figures would be interesting and maybe a plan to roll back to rough surface finish if that works better. Either way, well done on getting it to run so well.
« Reply #114 on: May 28, 2025, 10:47:27 AM »
Thanks Nickle for your thoughts  :beer:. I did wonder if the roughness might contribute to heat exchange, which I think is the biggest concern of all in hot air engines, especially if increasing their size (which I intend to do). We'll see. And yes, a possible experiment is to try otherwise identical cylinders with different internal finishes.
BTW, one other variable, besides smoothness, is the increased side clearance created by honing the ridges down. Does that help or hurt? Well could be both, also. More clearance reduces air resistance, but decreases heat exchange.
The number of variables in hot air engine design is huge compared to IC or steam. That's because of the gas heat exchange requirements within the engine itself. Also why they are still so subject to experimentation..... and so therefore, interesting.
« Reply #115 on: May 28, 2025, 11:11:10 AM »
I think experiments with hot air engines often lose sight of the fact that they have an advantage over IC and steam in that they can use any form of heat (unlike IC engines) and don't require the danger, operational watchfulness, and expense of boilers (unlike steam engines). Most experimenters seem to have in mind an ultimate goal of fueled transportation, and use gas fossil fuels to experiment with in hot air engines. They search for efficiencies with engine configurations that favor these fuels.
Hot air engines can run on non-fossil biological solid fuels, including waste like sawdust, nut shells, rice husks, mulch hay, leaves, pine cones, branches, chips and waste wood, and they can run on solar heat, and waste heat from industrial processes.
Stationary uses where some fuel or heat source is inexpensive and available is a niche use that they seem eminently suitable for to me, rather than transportation, which is better suited to fluid fuels and electricity.
I don't believe hot air engines will ever be able to replace high power density fossil fueled IC engines. But as stationary engines they can utilize high availability local fuels that IC types absolutely can not. And so provide a low cost power source, and a different definition for the concept of fuel efficiency. That's been my interest all along.
Offline nickle
« Reply #116 on: May 29, 2025, 07:07:19 PM »
They are fascinating things... I still have not built one despite them being the main reason for buying my first lathe 20 years ago! I have the beginnings of a fizgig on the shelf in my shed. The surface area for heat exchange thing is an interesting aspect of Stirling Engine design... I wonder if some sort of ribbed displacer cylinder would help... but then you get more drag from a larger surface area and the thermal mass of the cylinder can become an issue. As you say, there are so many variables. Aside from the ability to use low energy density fuel, I think one of the most interesting aspects of these engines is the ability to use waste heat. there are endless industrial and domestic processes that have heat disposal as a problem... including a Stirling cycle in that process allows some energy extraction to happen. It wont always be optimal temperature differentials between the hot and cold sides, but its waste heat so efficiency doesn't have to be the main driver. Have you got a copy of Edgar Westbury's "A Practical Treatise on Hot Air Engines"?
« Reply #117 on: May 29, 2025, 09:41:25 PM »
Hi Nickle!  :beer: I do have Westbury's treatise, also a lot of old Model Engineers, which I've collected over the years. Coincidentally I have just been reading yesterday about Westbury's last engine, a Robinson type, published a couple months before he passed away. And a then an editor's note, about a year later:,
I find this not only a little sad, but also somewhat mysterious, and it makes me want to build that engine just to see for myself whether this is true, or not.
Offline nickle
« Reply #118 on: May 30, 2025, 04:24:39 AM »
Isn't that design in the book? that would be a shame as i was eying that build off for a some day project.
« Reply #119 on: May 30, 2025, 10:11:08 AM »
I'm not convinced that it doesn't work as drawn. But if it doesn't, it would be instructive to make the changes to get it running. Part of the fun actually, and a place to learn things.
I will give one interesting side note (clue). Robinson engines used a perforated displacer with regenerative material inside. The Westbury design does not, and E.T.W. seems not to have realized this, and had drawn a sealed hollow conventional displacer.
Still, I believe it should work that way, as well.
« Reply #120 on: June 01, 2025, 03:09:29 PM »
I'm seeing some wear again in the displacer rod/bushing. I feel that the bushing is too short, compared with what I'd now like. Or at least with the side forces on it, considering the shortish connecting rod I now have for its throw.
However, increasing the bushing length isn't possible without major reconfiguration of the engine. I'd have to move the crankshaft, supports, bearings, and flywheel aft, and remake all of the rods. I also don't really want to increase the length of the engine for other reasons.
Instead, I'm considering a few more compact linkage systems to reduce the side forces on the displacer pushrod. Also making a Teflon displacer bushing. Among possible alternative linkages used on hot air engines are the Scotch yoke, the pivoted Scotch yoke, and the Ross linkage. I can probably add at least one of these without moving the crankshaft, and they might also allow a longer bushing and pushrod as well as reduced side forces.
The penalty is more friction and more moving mass. But I think it's a trade-off I want to make, because in future I'd like to try an axial regenerator in the displacer cylinder. That would require very accurate linear motion. Though presently working fine, I think there's too much play now in the bushing to fit anything in the small clearance space around the displacer without interference.
« Reply #121 on: June 02, 2025, 08:05:49 PM »
Have thought a lot the past day about the Scotch yoke. I like it okay on its own, but what is giving me pause is the need for some kind of sliding support to keep it from flopping sideways.
It seems there are twenty animated examples of simplified Scotch yokes online, to every one photo of an actual physical working version. In practically all of the animations, the authors haven't bothered to restrain the yoke with a guide. So almost none are practical.
I think the guide is where the real friction is going to be. I've come up with a limited number of choices for guides:
1.) the crank pin, or pin and roller, bearing would need side rims to keep the yoke trapped between them.
2.) the yoke is grooved and a pin bearing rides in the groove
3.) the yoke is constrained between rubbing guides on either side, or a grooved guide at the bottom.
4.) the pushrod is flattened or square sectioned with a bushing to fit
5.) an additional pushrod above or below the active one is used as a second guide
6.) a pivot at the bottom of the yoke and a pivoting connection to the pushrod restrains the yoke (actually, this is technically a quick return linkage, not a Scotch yoke.) It is non linear in stroke speed. Hence the name.
I don't know. The #6 appeals to me because of the elimination sliding guides, but would the non-linear stroke be an advantage or disadvantage? And should it be favor the slower motion toward the hot or cold end of the displacer cylinder?
