Author Topic: Enjomor 6cc Hit & Miss Engine - Last Mods I Think?  (Read 13102 times)
Offline Jim Dobson
« on: August 14, 2023, 10:01:24 PM »
Somehow I doubt it though, these engines are made to muck around with.
Re: Enjomor 6cc Hit & Miss Engine - Last Mods I Think?
« Reply #1 on: August 15, 2023, 02:18:45 AM »
Congrats, Always a thrill when our models run.  :clap:
Looks good, sounds great. Seems to be cycling through the hit and miss well.
I would probably try to get the revs down a bit more but that is more fiddling (modifications) as you thought.
Well Done.
Offline Jim Dobson
« Reply #2 on: August 15, 2023, 03:04:44 AM »
Well Done.
Thanks John, yes if it could miss a little more than hit I would be really stoked. I am watching as much as I can on YT picking up a hint here and there.
I made another dummy battery on the lathe with some delrin and brass and tried running it on just two AA batteries (3v) thinking that might make it run slower but it wasn't enough to fire it.
Those 'points' I think hold a bit of the key to slowing it down, but boy are they fiddly things!
Thanks again for the comment, really appreciated.
« Reply #3 on: August 16, 2023, 03:12:28 AM »
From my limited experience hit n miss depends on the mass of the flywheel (Out by the rims), the mass of the governors and governor springs. All seem to interact but from lessons learned, change one at a time otherwise you will wonder which change messed it up.
:doh:
Regards,
Offline Jim Dobson
« Reply #4 on: August 21, 2023, 02:31:06 AM »
Thanks John
