Author Topic: Broken lathe  (Read 33779 times)
Broken lathe
« on: January 11, 2023, 12:22:29 PM »
My 290 lathe is broken….,😢😢😢😢😢
The vfd has failed…an Invertek 1.5kw unit…Powers up but displays O-volts…. Indicative of high bus voltage…which seems odd.
I first put it down to being cold in the garage or damp…but no, brought into the house, sat on a rad to dry out to no avail….
I’ve put a call in to Invertek to see if it can be repaired/how much…a new one is around £200…. Ouch!!
Offline Muzzerboy
    • The Mighty Shiz
Re: Broken lathe
« Reply #1 on: January 11, 2023, 04:47:00 PM »
Re: Broken lathe
« Reply #2 on: January 12, 2023, 08:25:04 AM »
Well not good news….
They say it’s 5 yrs old and has been superceded…..
A replacement is £206….
So I could go to eBay and buy a cheap chink replacement, or inverter drive supermarket has a WEG unit for much less…..choices choices…,,
Re: Broken lathe
« Reply #3 on: January 13, 2023, 07:55:14 AM »
Thought I'd update on this....
after several futile attempts to revive the poorly inverter, I've ordered a new one from Inverter drive supermarket....the WEG one..
The Invertek replacement was coming in at £188, given their lack of enthusiasm to help, I decided to go elsewhere..
Hopefully this one will last me...
Re: Broken lathe
« Reply #4 on: January 13, 2023, 10:17:47 AM »
Of the few vfds I have successfully revived,  the easiest to repair was a cheap Chinese made model, mainly because it used mostly discreet devices and came apart in a relatively simple manner. The typical compact models from Europe/japan use solid state modules which, while available, are impossible to swap.
Re: Broken lathe
« Reply #5 on: January 13, 2023, 10:59:32 AM »
Bill,
The Invertek unit that has failed, has a multi pin power module for the output devices. The remainder of the circuitry is fairly straight forward, there’s a TNY device for the power supply, numerous 8 pin ‘op amp ‘ looking devices and an ARM processor….Repairing is not for the faint hearted, there’s a main board with 2 more boards slotted into it…these need removing to better access….
With the lack of a circuit diag. Repair is hopeless….hence the new purchase..
Re: Broken lathe
« Reply #6 on: January 13, 2023, 11:28:51 AM »
Shame you bogged off to the back of beyond John.  There be surface mount rework facilities here :dremel:
Glad you are getting sorted, but if you do want the VFD having a look over and happen to be in South Yorkshire you're welcome to pop by.
Re: Broken lathe
« Reply #7 on: January 13, 2023, 11:57:54 AM »
Joules,
Thanks for the offer…. :beer:
Like I said above, the lack of a drawing really hampers….Under and over volts on the bus would usually be covered by 2 comparators feeding into the control logic probably handled by the processor….I’ve found this to be the case with earlier Teco inverters….can’t see this one being any different….really. :coffee:
Re: Broken lathe
« Reply #8 on: January 13, 2023, 12:03:49 PM »
Mostly my check would be diodes and capacitors, any unidentifiable multi legged beastie with a crater in it deems the job unlikely to be repairable.
