Author Topic: Bearings  (Read 13972 times)
Offline shipto
  • Redditch, UK
Bearings
« on: August 07, 2021, 10:01:27 AM »
I am stuck on a project and need a specific bearing but dont know A: if they even exist B: what they would be called if they do.
So they need to be a thrust bearing (and no searching for that isn't bringing up what I need) that will secure onto the end of a pin at about 4-5mm probably by way of a spring type jobby similar to how things like drive shafts are held in place and a free spinning flat face with an outside diameter of about 12-15mm.
Any ideas about what I should type into a search engine would be appreciated.
Offline shipto
  • Redditch, UK
Re: Bearings
« Reply #2 on: August 07, 2021, 11:12:55 AM »
Give Simply Bearings, or Bearing Boys a call, they are both very helpful:
https://simplybearings.co.uk/shop/?gclid=CjwKCAjw3riIBhAwEiwAzD3TiWjiaI9nFhGfCy8sr_mQt2n2Y_uXqqgdH5S_Sg-VUZUMg4DX2bfupRoCSRkQAvD_BwE
https://www.bearingboys.co.uk/?gclid=CjwKCAjw3riIBhAwEiwAzD3TiYyk5PFXqOskYGOK_1qpFs5P-muZ1DcDq4VEe9K3lYfYeBLBJTCohBoCgfAQAvD_BwE
I will give them a call when I get the chance on monday but looking through the sites I am not hopeful, I am seriously thinking that what I want doesn't exist to be honest so I may have to rethink my approach.
Re: Bearings
« Reply #3 on: August 07, 2021, 01:39:25 PM »
Angular contact bearings my be closer to wat you want , with a face cap .
Offline shipto
  • Redditch, UK
Re: Bearings
« Reply #4 on: August 07, 2021, 03:15:51 PM »
Yes that looks promising, Thank you.  :D
