Author Topic: Spanner to Undo CAT40 Pull Studs  (Read 31535 times)
« on: July 23, 2021, 05:32:57 AM »
This is a recent tool that I made to engage with the 'notches' in CAT40 tooling to allow me to unscrew the 'Pull Studs' for re-use in  other tooling. I have a CAT40 tightening fixture but to remove the pull studs the holder needs to be inverted and the fixture won't accommodate that.
I've been gripping the CAT40 flanges in soft jaws in the vice, which isn't very nice, but I was also motivated as a chap on eBay is selling some obviously ex Beaver tooling as it has the propriety special pull studs, and although he is prepared to sell me the studs can't get them unscrewed. So I may have to make a site visit!
(You cannot buy the pull studs)
CNC Plasmacut from 6 mm mild steel, two off welded together to make the required thickness and a bit of hand fettling.
. . . works OK on the bench.
Re: Spanner to Undo CAT40 Pull Studs
« Reply #1 on: July 23, 2021, 05:57:58 PM »
Couldn’t you just machine 2 flats for a wrench like Hass does?
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #2 on: July 24, 2021, 05:29:22 AM »
It's so satisfying to be able to make these "one-off", custom tools  :clap: :clap:
Tim
« Reply #3 on: July 24, 2021, 02:29:37 PM »
Two flats wouldn't cut the mustard - it needs the two prongs to engage the recesses in the holder to stop it rotating while  conventional spanner is used on the flats of the stud itself.
Put up a picture of your Haas arrangement so that I can better understand what you mean
« Reply #4 on: July 25, 2021, 05:35:40 AM »
This is what the Haas uses it’s made of three layers and holds it quite well the center one holds it steady.
« Reply #5 on: July 25, 2021, 10:45:52 AM »
That's very neat and I'd love one, but it wouldn't work if I have to go and visit this eBay chap in what I suspect is a 'we buy anything' junk shop from the range of stuff he is selling on eBay. (vases, cuddly toys, kitchen goods . . etc ...)
mind you he seems not to be replying to messages any more  :(
