Author Topic: Building a shed  (Read 36379 times)
Offline NormanV
  • United Kingdom
Building a shed
« on: April 05, 2021, 09:37:41 AM »
Three years ago I moved to a new house. I needed a workshop so I decided to build a timber shed. I was only allowed to build a shed that was 10ftx8ft. I used 3x2 timber for the frame fully insulated on all walls roof and floor with 75mm rockwool and lined internally with 6mm mdf. So far so good. I clad the outside with T&G board as I thought that this would look goo andbe weatherproof. This was a big mistake, after two years the wood had shrunk so much the the joints opened up so much that some of the tongues had popped out of their grooves. On one wall I removed all of the planking and refitted all the planks with the grooves reseated. I had to make a filler plank 40mm wide to take up the gap.
The shed is great, solid, warm and well soun-proofed but I will not use T&G for future sheds.
Re: Building a shed
« Reply #1 on: April 05, 2021, 11:17:42 AM »
It's a problem with the modern fast grown 'kiln dried' timber that shrinks like fury.
I remember taking a baltic pine rafter out in my last (1905 built) house, and it was over twice the weight of the of the stuff I was getting from the local builders merchant.
Looking at the growth rings the new stuff are widely spaced and the slow grown Edwardian stuff is tightly packed.
