MadModder
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Login
Register
MadModder
Gallery, Projects and General
How do I??
electronic ignition cdi
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: electronic ignition cdi (Read 25952 times)
speedibee
Jr. Member
on:
February 01, 2021, 07:44:26 AM »
I have ordered an electronic ignition kit from hobbyking ,for the Webster engine I'm building , what i want to know if anyone has the answer is , can i mount the magnetic trigger on a steel flywheel .or will it confuse the signal ?
Logged
You are never alone with Schizophrenia
chipenter
Hero Member
Re: electronic ignition cdi
Reply #1 on:
February 01, 2021, 10:12:46 AM »
I don't see why not my rev counter magnet is mounted on my lathe spindle , the flywheel is not magnetic is it?
Logged
speedibee
Jr. Member
Reply #2 on:
February 08, 2021, 06:26:15 AM »
flywheel is going to either steel or cast iron
non magnetic
Logged
pycoed
Jr. Member
Reply #3 on:
February 09, 2021, 06:00:28 AM »
I installed a rev counter for a Kubota diesel engine & fitted the magnet to the steel power steering pump pulley ( same size as the crank pulley, but MUCH easier access) & it works fine. I glued the first one on, but the counter didn't work - dumbo didn't realise the pickup is pole sensitive
. Second one is just held by it's own magnetism & has been fine for the last 18 mths (isn't it amazing how these temporary bodges become permanent?)
Logged
Sea.dog
Full Member
Up Spirits!
Reply #4 on:
February 09, 2021, 07:22:46 PM »
I have one a cheap Chinese tacho on my lathe. It worked well for a couple of weeks then stopped. After trying various things, including getting a spare pickup from the eBay seller. I discovered that turning the magnet over fixed the problem
About 4 months ago it died again (after 7 years) and I've not yet tried to fix it.
My magnet is also held in place by the power of thought
Logged
stevehuckss396
Jr. Member
Reply #5 on:
February 21, 2021, 11:44:50 AM »
Mount the magnet to, or in the cam gear. No need to make it spark twice as much as needed.
Logged
Print
Pages: [
1
Go Up
« previous
next »
MadModder
How do I??
