Author Topic: after about 60 minutes tool path goes awry using ddsc2.1 controller  (Read 28857 times)
Offline hogman
Hi,
Today spindle moved to next part and took a Z dive. Code is good, operation sims well yet for some reason Z went wrong. Other ways it can go off is slowing way down and taking a wrong path.
I have seen this happen during an op that has been running awhile. I use a digital dream 2.1 offline controller. I do recheck the code and it is always fine.
Any ideas why this happens and how to fix. ? Please suggest another controller if wise. I do not want to run a pc tho.
Offline russ57
Re: after about 60 minutes tool path goes awry using ddsc2.1 controller
« Reply #1 on: November 16, 2020, 04:47:55 AM »
Overheating?
-russ
Offline hogman
« Reply #2 on: November 16, 2020, 07:57:27 AM »
may be. I will change mount today to open up vents in back of unit. Thank you
