Author Topic: WM 250/280 lathe change gears calculator  (Read 13765 times)
Offline picclock
« on: February 25, 2020, 09:40:01 AM »
Impossible to find the change gears for some threads on my WM250 Lathe. Good lathe but poor threading info.
So I wrote a change gear calculator. Probably buggy, but seems to work OK for me. Windows 10 64bit, or Windows 32bit compatible with Windows 7/XP . No installation, just create a directory and extract the exe file into it. It does write a gears text file which can be updated in the program or via Notepad etc.
Hope someone finds it useful.
Best Regards
picclock
« Last Edit: August 04, 2020, 05:20:35 AM by picclock »
Offline kayzed1
Re: WM 250/280 lathe change gears calculator
« Reply #1 on: February 25, 2020, 02:18:26 PM »
Says this App can not run on your PC.. extraction fault..
Offline Chuck in E. TN
  • USAF Retired
« Reply #2 on: February 25, 2020, 05:36:31 PM »
The WM250/280 is a 7x mini lathe, right?
LMS has a change gear calculator online:
https://littlemachineshop.com/reference/change_gears.php
Chuck in E. TN
Offline picclock
« Reply #3 on: February 26, 2020, 03:26:12 AM »
@Chuck
WM250/280 is a different beast to the mini lathe, closest I can find is a grizzly 9x22. Although I found a calculator for the grizzly it did not work on my WM250.
See : https://www.warco.co.uk/metal-lathes/303007-wm-250v-lathe.html
@kayzed1
Dowloaded and unzipped OK to a win 7 computer, using 7zip, but it is a 64 bit program so its only good for Win 10 64 bit.
I've now added a Windows 32bit version which should be Ok with Windows 7 (tested) and 10 (untested - dont have 32bit windows 10).
Best Regards
picclock
« Last Edit: February 26, 2020, 04:35:39 AM by picclock »
Offline kayzed1
« Reply #4 on: February 26, 2020, 01:53:40 PM »
I am on Win10/64. I hate Windowz but will try again in a bit..see if i can work out wotsafoot.
Offline picclock
« Reply #5 on: August 04, 2020, 05:23:08 AM »
WM250 Change gears program updated.
Enjoy.. .
Best Regards
Picclock
