Author Topic: Manual tool change help ddcsv  (Read 28018 times)
Offline tonyho810
« on: November 26, 2019, 12:07:53 PM »
Hi,
Can anyone help please. I'm trying to do a manual tool change on my home made router driven by ddcsv2.1. I'm using Fusion360 and trying various post processors.  As far as I can work it out the post inserts M06 in the code and the ddcsv goes off and runs the t.nc macro. Is that correct? I'm stuck with the t.nc macro, what do i put in it? If someone has already generated on could you share it please? I put a post on the official forum but no response.
Thanks,
Tony
Re: Manual tool change help ddcsv
« Reply #1 on: November 27, 2019, 04:54:53 AM »
Please read this:
« Reply #2 on: November 27, 2019, 04:57:08 AM »
I should include more about T.nc in that file, but here is what it contains:
G04P0
M110
G91 G92 Z#[767+#592]-#[767+#593]
#592 = #593
Hope this helps
Will
« Reply #3 on: November 27, 2019, 05:34:40 AM »
There is also a Facebook group that is pretty responsive
https://www.facebook.com/groups/1724999967517167
Here you will in the files section the latest user manual and a version description document as well as other useful stuff
Will
Offline tonyho810
« Reply #4 on: November 27, 2019, 06:18:51 AM »
Thanks Will,
I rememered in the middle of the night that  unix is case sensitive and I had been using t.nc instead of T.nc. That combined with the code you posted will fix it I'm sure
Thanks again,
Tony
