Author Topic: My week this week, my workshop videos!  (Read 715522 times)
Re: My week this week, my workshop videos!
« Reply #275 on: June 01, 2024, 11:02:27 AM »
Hi folks,
I get the boiler back together, reinstalled, but just get started on the flue and run out of Mig gas, so its on to some other joblets to fill in! Boiler is refilled with no leaks, so the Fernox leak sealer has triumphed once again, other makes are available! A short, mainly wet week!
Phil, June 1st is grey and cold in East Yorkshire!
« Reply #276 on: June 08, 2024, 11:37:58 AM »
Hi folks,
A very short week of modifying an inherited partly made(?) stand to suit my very heavy gas forge, so thatI can use it anywhere in the shop, as opposed to having to carry it to some level surface and set it up to use! Only got a couple of days in before life overtook me, but much was achieved!
Phil, in occasionally warm and sunny East Yorkshire!
« Reply #277 on: June 15, 2024, 11:01:59 AM »
Hi folks,
I get the gas forge up on its stand, change the gas burner orientation to make it more compact, and get it running in order to heat and flat bend some strip steel. Then I get the new boiler flue fitted and fit a new thermostat so it will self regulate and shut down if it gets too hot! Looking at the weather I might need it! Time to test it soon!!
Phil, splish splashing through the EastYorkshire monsoon!
« Reply #278 on: July 06, 2024, 11:04:19 AM »
Hi folks,
I get to the root of my heating problem when I strip the pump down, but only manage one and a bit days at the workshop this week! The bushings on the pump are very worn and the rotor is catching on the stator and the pump locks up. I have an ominous feeling in the back of my mind that thisis why I took this pump out of service in the first place! We find that no matter how many of a thing you have in your pile of junk, you eventually use up the last one!
Phil, deep in the steamy rain forest of East Yorkshire!
« Reply #279 on: July 13, 2024, 11:00:55 AM »
Hi folks,
A mixed bag this week! I fix the garden tractor after it takes on a tree stump and loses, get started on realigning the colchester lathe (more next week) Do the inevitable tidying up, and have two very productive days of antique repairs ! Enjoy!
Phil, the central heating is on in East Yorkshire!
« Reply #280 on: July 20, 2024, 11:01:24 AM »
Hi folks, Part two of aligning the Colchester headstock, plus stripping and rebuilding a three jaw chuck, in order to clean and oil it, and get it working to its full potential accuracy and smoothnes! Three jaw chucks all have runout, even when brand new and good quality, expect 3 to 4 thou runout, and more on an import! They are convenient and quick, and as long as you are turning all the diameters of your component, any runout is ireelevant, but if you need to use the outside diameter of the bar as well, it will not be concentric with the diameters you have turned! If you need to do this, use a 4 jaw! A 4 jaw is the most accurate chuck you have!
Phil, in sunny hot and summery East Yorkshire! It won't last!!
« Reply #281 on: July 27, 2024, 11:10:03 AM »
Hi folks,
This week I strip the Holbrook countershaft and work out the sliding positions for the upper pulley to obtain the 12 speeds on the Holbrook, six selected by belt changing, and the back gear giving another six. I pop over to my mate Richards in the derwent valley and we troubleshoot his Ingersol rand "$" compressor We get it running in short order but there is a fault on the unloader system which turns out to be the non return valve has failed. And then the what is it! Something interesting from a York car boot, probably with a military history, have a look and let me know in the comments, and dont forget to subscribe!!
Phil,  in pleasantly warm and sunny East Yorkshire!
« Reply #282 on: August 03, 2024, 11:30:01 AM »
Hi folks,
A mixed week in which I get some more work on the Holbrook in, and realise that my envisioned solution for the countershaft arrangment is fatally flawed,  and with thanks to the Guru of all things Holbrook, Mr John Bourke, I rethink it all and take his sage advice to heart!
After an early morning at York Uiversity on Tuesday for My eldest  to get her Masters in Biology Graduation, we go on to Wednesday grass cutting in the field, back on the Holbrook Thursday, and Friday, in sweltering heat we start the fence that we started on the day lockdown was imposed at the start of Covid!
Phil, summer has arrived in East Yorkshire
« Reply #283 on: August 10, 2024, 11:06:40 AM »
Hi folks,
  This week we complete the final preparations for the annual Wicani Jamboree, which is a get together of dog breeders and owners held annually on the field owned by my cousin Keith and I. This involves doing all the maintenance, repairs and tidying up we should have done at regular intervals during the year, and doing it all in about two weeks to make the place look great and to try (and usually fail) to impose some order on the chaos of nature! There is no such thing as natural beauty in nature! Eventually the strongest weeds take over and you are left with a monoculture of nettles, blind brambles and thistles. Sometimes we win, but mostly it just a wilderness! We love it, but really could live without the work it takes!
Hope you enjoy it,
Back on the Holbrook next week!
Phil, in pleasantly warm East Yorkshire.
« Reply #284 on: August 17, 2024, 11:06:18 AM »
Hi folks,
 A whole uninterrupted week in the workshop! I get the majority of the build done, designing it in my head as I progress! The worst part was derusting the steel, the best was the welding AFTER I fitted a new contact tip! Also advanced two tech levels with the Rapidor, got the damper working correctly to lift the saw on the backstroke, and got the vice to cut at 45 degrees! Did an unscheduled angle grinder fix, but after all it did come out of a skip several years ago! Good progress!
Phil warm and dry in East Yorkshire
« Reply #285 on: August 24, 2024, 11:03:38 AM »
Hi folks,
 Another week in the workshop, not quite uninteruppted, but I virtually finished the belt tensioning mechanism, and fit in a couple of side jobs as well, a quick repair on a part for an astronomical telescope, and watch to the end to see a quick tidy up of the workshop!
Phil, in Wild and Windy East Yorkshire
« Reply #286 on: August 31, 2024, 11:35:37 AM »
Hi folks,
 Another short week due to hospital appointments and daughters returning to university with a pantechnicon load of stuff! We did it! Phase two, the motor mounting, clutch and brake assembly is begining to take shape in the noggin, and I am ready to mount the motor, I finally after much procrastination,  fit the starter to the Rapidor, which is now fully automated and I can walk away from it and let it cut and autostop! How 20th century is that!!
Phil in Scorchio East Yorkshire!
« Reply #287 on: September 07, 2024, 11:03:01 AM »
Hi folks,
On the Holbrook, I set up a double pulley on the motor to give two speeds from the motor, which restores all of the Holbrooks 12 speeds, I get the motor mounting plate sorted, and set up a sliding system in order to select the two pulley positions, and basically, it is all falling into place. A visit to Haxby shed to meet Paul on his home ground, some biographical notes, and a look round his very clean and tidy workshop, which is filled with some classic machine tools!
Phil, in Autumnal East Yorkshire
« Reply #288 on: September 14, 2024, 11:03:05 AM »
Hi folks,
On with the Holbrook B9! I get the motor mounted and start to work on a mechanism to disconnect the drive without turning the motor off. What seemed to be a simple case of a slipping belt clutch, which I have used before many times, including on the 2CV tractor, doesnt work well in this application with much shorter belts and tighter wrap around the pulleys. I learn about the fabric covered V belt which is designed to slip with anything but a full wrap and consider the possibility.  It is coming together, and after reversing cleaning and servicing the motor, she runs, and in the right direction too!
Phil Its beginning to be chilly in East Yorkshire
« Reply #289 on: September 21, 2024, 11:01:22 AM »
Hi folks,
This week the pulley slipping clutch starts to work, thanks to some input from Gardentractorboy! I fit two belt guides and hey presto, the belt slip clutch works! I get a pivot made and fit a square "cam" to the end, and we have a system that moves the motor from drive to free in one movement! I struggle on through various interruptions, some more welcome than others, but end the week on a positive note with a drive system clutch that works a treat!
Phil, geting a bit "back endish" in East Yorkshire
« Reply #290 on: September 28, 2024, 11:02:30 AM »
Hi folks,
 All the Holbrook transmission comes together this week, and it all works, and then a huge penny drops, and with one change, my cunning plan bears fruit! I explain it all in the video! I am still getting over 60% of my viewers are not subscribers,  please subscribe! Its free and it helps me move towards the time when I might actually get some of the time and money I put into my projects back!
Next week will be finishing off, and a belt guard, plus eliminating any buzzes and rattles which crop up! Warning, contains gratuitous Rapidor porn!!
Phil,  in very wet East Yorkshire!
Offline Jim Dobson
« Reply #291 on: September 30, 2024, 02:20:07 AM »
Crook with a sore back, what an enjoyable thread to peruse on my iPad whilst laying down.
« Reply #292 on: October 05, 2024, 10:52:38 AM »
Unlucky Jim! I have this problem on occasion, it is no fun at all!
Hope you feel better soon!
« Reply #293 on: October 05, 2024, 11:06:33 AM »
Hi folks,
 eThis week starts with a sidetrack, a sure sign I need a break from the Holbrook project to get the creativity flowing again! I took one look at the cold damp weather and realised I would soon need to heat the workshop, and so decided to get to the bottom of the circulation problem and did just that, but what a game it was, and I am still not sure of the cause, though it was definitely a blockage, physical or air, that was the cause! It is now fixed, and the pump is silent, and actually circulating the water!Typically, the next day and the rest of the week were bright and very warm!  On with the Holbrook, I fit the control handle stop, and start making the belt guard, the final step before it all comes to pieces for painting!
Phil, in wet and cold then dry and warm East Yorkshire
« Reply #294 on: October 12, 2024, 11:03:30 AM »
Hi folks,
 This week I make the belt guard for the Holbrook lathe, and make and fit the stop and the hold up mechanism. Some TIG and Mig welding, a bit of milling, but no Rapidor this week! Thursday/froday my old mate Richard Teale comes over, and we fit a new roof to the blacksmiths shop area of the workshop. This morning I am stiff as a board and ache all over, but it is done apart from the last 1/2 sheet as you will see!
Phil, in typical East Yorkshire weather! It can't make its mind up!!
« Reply #295 on: January 18, 2025, 11:14:39 AM »
Hi folks,
 Back in the Workshop for my first attempt at a full week, although in reality I am doing 11-00 till 4-00! It is enough at the moment as believe it or not I average about 3.5 miles a day! Tiring but I did it! It will get easier! A day of fallen tree clearing on Tuesday and the rest on the belt guard for the Holbrook lathe. I hoped to complete it, but will do that early next week!
Thanks for watching!
Phil, in Chilly East Yorkshire.
« Reply #296 on: January 19, 2025, 09:06:57 AM »
Shot this just before Christmas, put it on the tube, but forgot the forums! obviously not quite firing on four at the time!
Hi folks, Just a short video to show I am still alive and kicking up a fuss! A few odd jobs to clear the decks before the festivities begin! Thank you all for your patience, and I hope you all have a wonderfull Yule and a bright and happy new year!
Bright blessings to all! Phil
« Reply #297 on: January 25, 2025, 12:37:43 PM »
Hi folks,
I get the belt guard finished, and a few other little jobs completed on the Holbrook B9 and the realisation dawns that it is nearly finished! I have the collet draw tube to complete, and the belt guard pivot to finalise, and then it is time to finalise the underframe, and remove it to drill the holes for fixing and lifting, aqnd then it's paint, paint and more paint!
Phil, in Wild wet and windy East Yorkshire
« Reply #298 on: February 01, 2025, 11:08:05 AM »
Hi folks,
I Get sidetracked so easily towards the end of long projects, but I looked in the firewood bag, and there it was! Antiques repaired, trees trimmed, some milling, some lathe work, another week of winter passes, roll on spring!!
Phil, in suddenly very cold East Yorkshire
« Reply #299 on: February 08, 2025, 11:03:56 AM »
Hi folks,
Short week, Monday on Taxi duties, and Thursday at the osteopaths with my shoulder strain! I finally decide to get stuck in to the Holbrook steelwork, and strip off all the drive and underskids for drilling and painting, it goes well, and I may sneak back today (Saturday) and put another coat on, which will be the first coat of black. If it is not sufficiently dry by Monday I will be starting another project in the new space I have now that the stairlifts have GONE!
Phil, In suddenly Wintry East Yorkshire.
