Author Topic: OpenBuilds C-Beam Machine  (Read 56192 times)
Re: OpenBuilds C-Beam Machine
« Reply #25 on: August 25, 2020, 04:28:52 PM »
Yes it can...
Which size rails do you have?
Offline efrench
« Reply #26 on: August 26, 2020, 02:27:38 PM »
I have 9, 12, and 15mm MGN linear guides.  Their only redeeming quality is their price :)  I have a set of STAF guides on the X axis of my rose engine.  They're made in Taiwan and are equal to or better than Hiwin guides.
« Reply #27 on: August 26, 2020, 03:45:44 PM »
These rails and blocks aren't too bad. I have definitely seen worse.
I ended up buying some Super Lube Silicone Lubricating Grease to use. I needed it anyway for some Nerf blasters.
Has good recommendations for that...
« Reply #28 on: August 26, 2020, 03:46:16 PM »
What size bearings did you order for the 15mm blocks?
Offline efrench
« Reply #29 on: August 27, 2020, 01:40:49 AM »
Here's the link.  Definitely check yours with a mike first.
« Reply #30 on: September 02, 2020, 05:24:04 PM »
This has been on hold for a little bit.
I ended up order some stronger stepper motors, a better PSU and some MISUMI t-slot plate for a better table.
Now... I wait.
