MadModder
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Project Logs
Home
Help
Search
Login
Register
MadModder
Gallery, Projects and General
How do I??
Bending Aluminum Round Rod
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Bending Aluminum Round Rod (Read 5272 times)
snub
Full Member
Country:
Canada
on:
September 01, 2019, 08:51:34 PM »
1/2" diameter, 6061 T6. I only need to bend it 5 degrees. Should I heat it up first, or do it cold. Any tips or tricks?
Logged
Joules
Hero Member
Country:
Re: Bending Aluminum Round Rod
Reply #1 on:
September 02, 2019, 01:53:52 AM »
https://en.m.wikipedia.org/wiki/6061_aluminium_alloy
As it appears it can be forged, I would be tempted to add some heat, depending on final application as the material temper maybe affected. Another thought is surface finish, you may mark or flat the surface whilst bending without formers. If you have the material try both options, I would be interested in the results, especially with pictures included.
I might also add, how long is the part... a 1m bar you can probably bend over your knee, but a 1” bar is a press job.
Last Edit: September 02, 2019, 05:50:20 AM by Joules
Logged
snub
Full Member
Country:
Canada
Reply #2 on:
September 02, 2019, 08:46:38 PM »
The piece is 16" long (40 cm) and it needs to be bent 4" (10 cm) from the end.
Logged
snub
Full Member
Country:
Canada
Reply #3 on:
September 02, 2019, 09:15:09 PM »
Here is what it will be replacing. As you can see, not much of a bend.
Logged
Joules
Hero Member
Country:
Reply #4 on:
September 03, 2019, 06:31:46 AM »
Just do it in the vice, use a ring spanner if you need some leverage and a tighter bend.
Logged
snub
Full Member
Country:
Canada
Reply #5 on:
September 03, 2019, 11:34:41 PM »
Got it done. Wrapped copious quantities of electrical tape around it, put it in the vise, put a 2 foot piece of steel pipe over it, a few short tugs and all is well.
Logged
Joules
Hero Member
Country:
Reply #6 on:
September 04, 2019, 09:44:37 AM »
Fixed like a pro....
Logged
Print
Pages: [
1
Go Up
« previous
next »
MadModder
How do I??
