Author Topic: G01 bloqué sur f50  (Read 12053 times)
Offline rayfredo
G01 bloqué sur f50
« on: January 05, 2019, 09:02:28 AM »
bonjour
je suis nouveau dans le forum,et j'ai besoin d'aide
j'ai un controleur RMHV2.1 mais l'avance programmé reste toujours à 50mm quelque soit  la valeur
j'ai changé le firmware avec pandora , mais rien ne change, j'ai toujours le problème
pouvez vous m'aider à résoudre ce problème
un grand merci par avance
cordialement rayfredo
Re: G01 bloqué sur f50
« Reply #1 on: January 05, 2019, 09:06:05 AM »
Rayfredo,
Welcome to the forum, I hope some one will be able to help you with your specific issue.
Almost exclusively the language used on this forum is English, and I'm sure that you will get a far better response were you to re-post your request translated into English.
Mean while, would you like to post something in the Introductions section telling us a little about you ?
Google Translate helps a lot:
"Hello
I am new to the forum, and I need help
I have a controller RMHV2.1 but the programmed advance always remains at 50mm whatever the value
I changed the firmware with pandora, but nothing changes, I still have the problem
can you help me solve this problem
a big thank you in advance
cordially, rayfredo "
Offline seadog
  • NE London
« Reply #2 on: January 05, 2019, 09:47:51 AM »
Bienvenue Rayfredo.
