Author Topic: The Sequel - Oh Blimey I bought a CNC Lathe (Beaver TC 20)  (Read 1306826 times)
« Reply #1400 on: November 18, 2026, 10:51:57 AM »
Does that ring gear coming out help? Held by a number of cap head bolts...?
« Reply #1401 on: November 18, 2026, 01:27:22 PM »
I suspect that the bearing behind it is what?s trapping it - more archaeology tomorrow hopefully will reveal all!
« Reply #1402 on: November 18, 2026, 01:44:04 PM »
That bearing will no doubt put up a fight on its removal?. :Doh:   Looking forward to the next chapter installment? :beer:
« Reply #1403 on: November 18, 2026, 02:08:44 PM »
 :beer:still lurking and watching
« Reply #1404 on: Today at 08:00:46 AM »
So I started this morning intending to remove the front curvic coupling and see what lies behind it. This unit must have had a hard life - one of the bolts was sheered off.
Having removed them the coupling didn't want to budge - looks like there are some locating dowels that it's held on by. Rather than get too involved I decided to see if the hydraulic cylinder arrangement intended for 2500 psi would move at all on 100 psi shop air. Yes a nice satisfying click as it shot forward, but more of a dull thud when sent the other way. It was then STUCK  :bang: Soft drifts and big hammers were to no avail so I rigged up a co-axial puller using M12 all thread and a big fat washer custom made on the CNC Plasma Table. It freed of without much drama.
Going off to have a re-think I consoled myself  with 'retail therapy' - I sent my rented BOC argon cylinder back years ago as the charges were stupid - I had intended to get a 'rent free' Adams Gas set up but never got round to it. 20L cylinder and brand new regulator ordered - I must investigate 'pea shooters' for Argon.
I'd originally used the Argon to de-gas aluminium in my oil fired furnace but don't now need to with the induction furnace, however I do have an ancient wall mounted 150 amp AC/DC transformer based TIG welder that I used to use - does it still work? I've no idea but now that I'll have the Argon at least I can try it - if I buy a replacement the gas is still needed.
. . .off to find about Argon pea shooters !
