Author Topic: The Sequel - Oh Blimey I bought a CNC Lathe (Beaver TC 20)  (Read 1304815 times)
Online awemawson
« Reply #1375 on: November 10, 2026, 09:17:40 AM »
Well another try:
I've managed to drill a 6mm  hole 20 mm deep into the back of the hex driving recess using an HSS carbide drill. Went in remarkably easily. Next size up that I have in HSS Carbide is 8mm - total rejection, just polishing the edge of the hole. Tried another brand new HSS carbide in 8 mm with the same result.
I can only assume that the core of the screw has been left relatively soft with the rest at 12.9 hardness.
It seems that 12.9 steel needs to be brought up to 400 Deg C to soften and I'm getting no ware near that with my propane torch. I do have a Mapp gas cylinder but that only burn a few degrees hotter so probably not the solution.
I've a pair of big old Oxy-Acetylene cylinders out side in the safety cage but I dread to think what the state of their hoses is - not been used in a few years. The logistics of getting them near the bench will be challenging.
. . . more cogitation  :scratch: :scratch:
Offline smiffy
« Reply #1376 on: November 10, 2026, 11:51:51 AM »
Is it possible they are left handed threads ? or some times tightening a bolt can loosen one that refuses to come undone when turned in the correct direction  Mike
Online awemawson
« Reply #1377 on: November 10, 2026, 11:57:52 AM »
It did occur to me that it possibly could be a left hand thread, but there is no valid reason why it should be as the tool disk is rotated in both directions by the servo with the logic working out which way is quicker from 'current tool' to 'desired tool'
I did however try left handed vigorously with the big ugga-dugga !
Online awemawson
« Reply #1378 on: November 11, 2026, 05:52:52 AM »
In a dark corner of my brain I had a vague recollection of having a few 'Cintride' brand solid carbide drills - just maybe they might work. Intended for slow speed drilling of hard steels in a machine tool able to exert significant pressure while rotating. Well I'm forced to use a hand drill so the 'significant pressure' is limited to what I can apply with my tummy  :lol:
OK I found the box, mainly empty cardboard boxes but I did have one 9.5 mm solid carbide genuine Cintride so lets see what happens:
I've managed to sink the hole now to 13 mm deep - there can't be much material left of the countersink - I'll have to do some maths -
- go do the Maths Andrew !
Online awemawson
« Reply #1379 on: November 11, 2026, 06:19:19 AM »
Another TWIT moment of course - the bolt shank is 12mm - assuming that the 9.5 mm hole is approximately concentric (it isn't quite) then there will be (12-9.5) / 2 wall thickness left or 1.25 mm which will have very considerably weakened it but it's very  tough steel. I'll have a go with a punch and see if it'll shear off.Very well supported of course as it's snugly sitting in the female countersink.
(a 12 mm Cintride bit is north of 50 UK pounds)
Offline Muzzerboy
    • The Mighty Shiz
« Reply #1380 on: November 11, 2026, 07:06:17 AM »
I think I'd have reached for the TIG myself if that had been mine. Between the added leverage of a large bolt welded to the head plus the effect of heat, I'd be surprised if it didn't budge. But there's no right or wrong method.
Csk machine screws with hex sockets are one of the least effective and most troublesome fasteners - hard to tighten adequately without damaging the head and a sod to remove when they get clagged up after the passage of time and corrosion.
Online awemawson
« Reply #1381 on: November 11, 2026, 07:19:27 AM »
Sadly no Tig set up   :bang:
Online awemawson
« Reply #1382 on: November 11, 2026, 09:44:04 AM »
Brute Force wins the day  :zap:
A large centre punch applied to the drilled counter sink head in three 120 degree spaced whacks sheared the head clean off:
This exposed a ring of Allen headed bolts:
Which held a cunning double taper arrangement
Slowly it starts to come apart
This allowed the bearing and half the rear curvic coupling to slide off the shaft.
Now looking into the assembly I can see retaining nuts on the shaft  that will probably need special spanners to be made.
But enough excitement, I need a lie down and a wet rag on my forehead !
« Reply #1383 on: November 11, 2026, 11:15:35 AM »
Persistance wins the day! :clap: :clap:..Enjoy your lie down.. :lol:
Offline pycoed
« Reply #1384 on: November 12, 2026, 03:53:46 AM »
Yes- when you think that was just a splash cover the CSK screw was holding on, & the trouble it caused.
Online awemawson
« Reply #1385 on: November 12, 2026, 05:40:12 AM »
. . . and with no TIG . . . then what would you reach for  :lol:
Online awemawson
« Reply #1386 on: November 12, 2026, 03:52:14 PM »
Just a bit more progress: I've managed to extract the stub of that M12 Countersink headed screw by jamming a Torx bit up the hole that I'd drilled and using the Impact Gun:
And I've identified the  bearing retainer nut that I need to unscrew from the shaft for the next step - It's a KM10 M50 x 1.5 mm pitch bearing lock nut - amazingly still an available standard. As this is deeply recessed it's hard to measure for making a suitable key, but fortunately it has KM10 stamped on it !
Seems that I need a 100 mm length (minimum) of 50 mm bore x 70 mm o/d heavy walled pipe. My initial searches have drawn a blank here in the work shop.
(needs to be hollow to slip over the shaft and reach into the nut. The search continues. Theoretically I could turn it from solid bar but that a lot of drilling and boring !
« Last Edit: November 12, 2026, 05:01:06 PM by awemawson »
« Reply #1387 on: November 13, 2026, 08:05:23 AM »
how about a bit of scaffold tube? is that in the ball park?
Ha...wrong diameter..I misread the dimensions..Sorreeee. :coffee:
But....You could weld a bit of plate onto the end of the scaff pipe, after boring a hole in it, then profile the outside to fit the nut? :dremel:
Is that madmodder enuff for ya?..  :clap:
Online awemawson
« Reply #1388 on: November 13, 2026, 10:32:02 AM »
John, photos later as I'm occupied elsewhere atm but I came across an off cut of the Steam Pipe that Pete got for me to use as an extended exhaust pipe for the big 110 kva generator that I use to run the Induction Furness.
Not an exact fit but if I make the engagement lugs somewhat longer than needed I 'think' I can bend them to engage properly
Online awemawson
« Reply #1389 on: November 14, 2026, 09:37:33 AM »
So let's make a box key spanner thingy:
OK how do I mark out the tube as I have no centre to work from. Various thoughts - print a tape of the same length as the circumference of the pipe - measure it out - mark pipe from it. Not very easy to get the sizes right. Alternative plan - draw up end of pipe in Autocad print it out, stand pipe on it and transfer the marks. This is the method I chose but needless to say there were hurdles in the way:
- Draw in Autocad - done
- Print 1:1 on my local Laserjet 2100 - Autocad says it's done it - printer stays awfully quiet. Much mucking about and I find that t he printer has lost it's IP address in the recent power cuts - pinging 192.168.1.69 where it should be returns nothing. OK what's it set itself to? I know that it's physically connected to the hub as if I unplug it the appropriate light goes out on the hub. There is a way to print out Laserjet settings pressing a combination of buttons on the printer. A bit of googling and I find it's now 192.168.1.224 - quickly set the printer port to this and I can print out the sketch:
and mark the pipe:
OK lets cut some steel - no apparently there's a water trough at the far end of the field gushing (expensive) water and needs immediate attention so of I go  :bang:
Suitable bend put in the float valve rod and we are back. A few cuts in the pipe end - break off the unwanted bits and let try it . Now I'd left the sticky out bits long knowing that they would need a bit of a bend to fit - offer it up, a tap with a large rubber hammer and the tabs go in the nut recesses remarkably well.
First attempt at unscrewing has failed as I can't stop the axle rotating as I apply torque - I'm using  the 'leather glove and welding clamp' well known method but it slips too much.
Withdraw for a rethink as I'm blooming cold having been playing with water and need to warm up.
Online awemawson
« Reply #1390 on: November 15, 2026, 05:04:37 AM »
Now as there is a ring of M10 threaded holes on the Tool Disk end of this shaft the obvious way to stop it rotating as I try to unscrew that recessed nut is to bolt a 'torque reaction lever' to it - so I did:
The protruding pegs that engage the nut are too long and will tend to bend so I shortened them now that I know they will bend if I can manage to apply enough torque so I shortened them to a guesstimated minimum length:
I gave the nut a bit of heat from the propane torch and still couldn't get it to unscrew, but now the limiting factor is the hardness of the protruding pegs as they round off on the corners. The nut will be a decent quality steel but I don't expect that it's hardened.
As a last resort I will try and drill small holes through its face and crack it with a cold chisel, but that for later.
Online awemawson
« Reply #1391 on: November 15, 2026, 07:51:59 AM »
OK let's try and split that nut with careful drilling' Progressively opened a hole up to 7 mm by which time there was a vary thin web left between the hole and the nut recess:
Cutting the web with a small cold chisel that conveniently jammed in the nut extraction recess and cracked the remaining steel until:
I WON !
So it turns out (not surprisingly I suppose) that  there's a locking tab washer under the nut - maybe THAT's why it wouldn't unscrew !
So  this means that I should have a clear path to the next bit of dismantling hopefully.
« Reply #1392 on: November 15, 2026, 01:53:57 PM »
Difficult to see from the photos, but I would guess it?s hard to bend up a locking tab from the recess? Maybe there was a different way of assembling ?
Online awemawson
« Reply #1393 on: November 15, 2026, 02:54:15 PM »
There was probably a special hook shaped tool I reckon.
Offline Muzzerboy
    • The Mighty Shiz
« Reply #1394 on: November 15, 2026, 05:15:43 PM »
A flatblade screwdriver, followed by a pin punch, I would think. Possibly just the pin punch? Edit: I was thinking of disassembly, not assembly.
« Last Edit: Today at 05:35:45 AM by Muzzerboy »
Offline smiffy
« Reply #1395 on: Today at 02:54:57 AM »
All  KN  series  nuts are available with nylon locking inserts ,that might be easier than using a tab washer . Mike
Online awemawson
« Reply #1396 on: Today at 06:09:01 AM »
That's interesting Mike - it may be the way to go.
Remember this assembly is probably never going in the machine - the dis-assembly is really just to show me the 'gotchas' before I start on the 'real' one.
(And even when / if I can pull the real one apart and cure its problems the lathe still won't work as its Servo system is seriously compromised but there is no point at all in fixing the electronics  without first overcoming the mechanical failings of the Tool Turret)
I had rather naively thought that once that lock nut was removed the other gubbins on the shaft would slide forwards for removal - How wrong I was  :bang:
OK lock washer removed:
Now this is the bit I thought would slide off the shaft:
But I think now perhaps it should unscrew on the 50mm thread that the nut was threaded on. This would perhaps make sense as it is part of setting pre-load on the two thrust races that are allegedly either side of the piston. If you look there are a pair of holes drilled in its face for some sort of pin spanner.
HOWEVER it also seems having cracked the lock nut by drilling it's face I have drilled through into the part I want to remove and the thread forming a nice locking arrangement  :bang:
So a bit of work needed to fettle the edges of that hole and clear the burrs that are probably locking the thread.
. . . blimey it goes on a bit this dismantling doesn't it
Online awemawson
« Reply #1397 on: Today at 07:36:27 AM »
Given a stout enough pin spanner I reckon those burrs would give way. Needs to be 60 mm pin spacing 3/16" pins with a 50 mm central hole, and able to work down a hole about 100 mm. I have a very nice adjustable pin spanner with interchangeable pins and adjustable spacing, but it's only any good for 'face working' so no good here :bang:
Ah well - another tool to make I suppose if I can find the materials.
