Author Topic: The Sequel - Oh Blimey I bought a CNC Lathe (Beaver TC 20)  (Read 1298743 times)
« Reply #1375 on: Today at 09:17:40 AM »
Well another try:
I've managed to drill a 6mm  hole 20 mm deep into the back of the hex driving recess using an HSS carbide drill. Went in remarkably easily. Next size up that I have in HSS Carbide is 8mm - total rejection, just polishing the edge of the hole. Tried another brand new HSS carbide in 8 mm with the same result.
I can only assume that the core of the screw has been left relatively soft with the rest at 12.9 hardness.
It seems that 12.9 steel needs to be brought up to 400 Deg C to soften and I'm getting no ware near that with my propane torch. I do have a Mapp gas cylinder but that only burn a few degrees hotter so probably not the solution.
I've a pair of big old Oxy-Acetylene cylinders out side in the safety cage but I dread to think what the state of their hoses is - not been used in a few years. The logistics of getting them near the bench will be challenging.
. . . more cogitation  :scratch: :scratch:
Offline smiffy
« Reply #1376 on: Today at 11:51:51 AM »
Is it possible they are left handed threads ? or some times tightening a bolt can loosen one that refuses to come undone when turned in the correct direction  Mike
« Reply #1377 on: Today at 11:57:52 AM »
It did occur to me that it possibly could be a left hand thread, but there is no valid reason why it should be as the tool disk is rotated in both directions by the servo with the logic working out which way is quicker from 'current tool' to 'desired tool'
I did however try left handed vigorously with the big ugga-dugga !
