Author Topic: The Sequel - Oh Blimey I bought a CNC Lathe (Beaver TC 20)  (Read 1311416 times)
« Reply #1400 on: November 18, 2026, 10:51:57 AM »
Does that ring gear coming out help? Held by a number of cap head bolts...?
« Reply #1401 on: November 18, 2026, 01:27:22 PM »
I suspect that the bearing behind it is what?s trapping it - more archaeology tomorrow hopefully will reveal all!
« Reply #1402 on: November 18, 2026, 01:44:04 PM »
That bearing will no doubt put up a fight on its removal?. :Doh:   Looking forward to the next chapter installment? :beer:
« Reply #1403 on: November 18, 2026, 02:08:44 PM »
 :beer:still lurking and watching
« Reply #1404 on: November 19, 2026, 08:00:46 AM »
So I started this morning intending to remove the front curvic coupling and see what lies behind it. This unit must have had a hard life - one of the bolts was sheered off.
Having removed them the coupling didn't want to budge - looks like there are some locating dowels that it's held on by. Rather than get too involved I decided to see if the hydraulic cylinder arrangement intended for 2500 psi would move at all on 100 psi shop air. Yes a nice satisfying click as it shot forward, but more of a dull thud when sent the other way. It was then STUCK  :bang: Soft drifts and big hammers were to no avail so I rigged up a co-axial puller using M12 all thread and a big fat washer custom made on the CNC Plasma Table. It freed of without much drama.
Going off to have a re-think I consoled myself  with 'retail therapy' - I sent my rented BOC argon cylinder back years ago as the charges were stupid - I had intended to get a 'rent free' Adams Gas set up but never got round to it. 20L cylinder and brand new regulator ordered - I must investigate 'pea shooters' for Argon.
I'd originally used the Argon to de-gas aluminium in my oil fired furnace but don't now need to with the induction furnace, however I do have an ancient wall mounted 150 amp AC/DC transformer based TIG welder that I used to use - does it still work? I've no idea but now that I'll have the Argon at least I can try it - if I buy a replacement the gas is still needed.
. . .off to find about Argon pea shooters !
Offline Muzzerboy
    • The Mighty Shiz
« Reply #1406 on: November 19, 2026, 05:38:04 PM »
Are you aware of BOC's "Hobby Welder Deal" pricing for Y size cylinders? For argon Pureshield it's currently ?62+vat per year. Depending on your usage, it may be better value than the "rent free" deals, as the refill cost (?73.50+vat) is generally lower. Argoshield Light (93% argon, 5% carbon dioxide and 2% oxygen) is the same rental but ?56+vat for refill.
Y size is 20 litre ie 4.72m3 of argon at 230bar.
Note that Air Products no longer supply non-commercial customers, allegedly for safety reasons (asphyxiant etc) but I suspect it's because they consider them to be not worth the hassle. BOC on the other hand have recognised that there is a large population of Y cylinders that aren't used by industry, so why not have them collecting dust in amateur workshops, getting paid, rather than scrap them or clog up their depots.
For my laser welder, I'm planning to go with SGS Gases 20L nitrogen rent free initially. They also do a 30L for not much more but they aren't stocked in branches by default and are quite a beast.
« Reply #1407 on: November 20, 2026, 08:19:13 AM »
I did contact BOC a couple of years ago and they were very dismissive about the hobby side and never came back to me with prices.
Too late now - Adams Gas now have my order which should be delivered in the next few days. I do still have a Y size BOC argon mix cylinder that they charge me stupid amount of rent for but that will go back soon.
Offline kayzed1
« Reply #1408 on: November 20, 2026, 02:57:30 PM »
When i had my TIG kit i used Hobby weld mid size bottles, can not remember the prices now but they were ok-ish for the amount i used up front cost for the bottle and set price for an exchange..
Lyn.
« Reply #1409 on: November 22, 2026, 07:11:06 AM »
Now this front curvic coupling piece is stretching me to the limit. I want to get it off to see if anything behind it is retaining that roller bearing that can be seen in the picture.
There is a ring of six M8 Allen Cap Screws that obviously are the main holding for it, but it won't come off. There are two M8 tapped holes that I had assumed were to push the curvic part off the main casting. It was all rather mucky so this morning I've cleaned it up a bit and cleared the threads in the two supposed pusher hole with a bottoming tap.
Inserting a grade 12.8 bolt in both threaded holes and exerting as much torque as I felt was their limit - still no movement.
This is getting silly! There are three other 6mm  holes which again I cleaned out with an M6 tap and tried maximum torque but no movement what so ever.
Off to lick my wounds!
« Last Edit: November 22, 2026, 08:02:22 AM by awemawson »
« Reply #1410 on: November 22, 2026, 07:49:40 AM »
A bit of heat mebbe? :dremel:
« Reply #1411 on: November 22, 2026, 08:43:36 AM »
I did try John but it's a big lump of metal. I can get the Curvic coupling up to about 110 Deg C in local places but that's about it due to it's heat sink properties.
I don't suppose that the coupling was bonded as well as bolted - may have been maybe to avoid fretting but I have little hope of getting it up to Loctite releasing temperatures that need to be north of 200 degC.
« Reply #1412 on: November 22, 2026, 11:04:45 AM »
kitchen oven when the missus aint home... :clap: :clap:
« Reply #1413 on: November 23, 2026, 08:55:12 AM »
Good theory but even stripped down to this extent I have great difficulty moving it about on the bench. The 'rotation' to get the front bearing sort of upright involved long levers. It's quite amazingly heavy  :bugeye:
I did calculate the (removed) tool disk at between 80 and 90 kg - considering that it mounted up to 45 kg of tooling no wonder it needs a powerful servo drive. It's all rather massively constructed.
« Reply #1414 on: Today at 05:50:36 AM »
OK let's try a different approach - remove the bearing directly. it's a:
                  INA-X-life NK 80/35  Slovakia 095 N0803
According to it's markings which resolutely refused to be photographed ! Now somewhere deep in the depths I have a 'Blind Bearing Removal Kit' - a/ can I find it and b/ will it work.
Yes found it:
Arh - but will it work? No not a chance, it's the best part of an order of magnitude too small  :bang:
So more thinking needed.
