Author Topic: UK Scraping Class of 2017  (Read 51731 times)
« on: December 20, 2017, 10:31:57 AM »
This 'Child' Board / Forum Subsection is here to act as a focus point initially for pictures and information gleaned on the UK 2017 Richard King Hand Scraping Class, and then to act as a depository for any further information on Hand Scraping.
Please edit pictures to a format of 800 x 600 maximum to ensure we don't hog too much of Eric's data space
Re: UK Scraping Class of 2017
« Reply #1 on: December 20, 2017, 01:25:02 PM »
Cheers Andrew.
Being the organiser of the class I suppose I better go first :)
I had several items that I intended to work on but all the little things that needed organising meant that I didn't get time to do them all. Mostly I worked on my Hardinge HLV saddle which had a large deep score mark running along the underside.
So I set it up in the milling machine and skimmed the underside of the saddle. We allowed 28thou - the thickness of the turcite as measured plus 5 thou for the glue (24hr max strength araldite). Milled the most of it off with a face mill then used a fly cutter for the bit under the dovetail. Mixed up the glue then clamped the turcite under a triangle surface plate for a whole day to squeeze out the glue and allow the turcite to set with even pressure.
The result was very good and ready to be carefully hand-scraped for bearing.
« Reply #2 on: December 20, 2017, 05:22:14 PM »
A few pictures from the class:
« Reply #3 on: December 20, 2017, 05:23:45 PM »
A few more
« Reply #4 on: December 20, 2017, 05:37:17 PM »
I was very impressed with how well Matthew's home-made repeat-o-meter worked, I didn't know what to expect from it but it showed up the smallest dips and rises. Of course we didn't know if it was reading the plate or just moving about randomly, until we had the idea of putting it on Kev's brand new plate and the needle didn't move at all.
« Reply #5 on: December 20, 2017, 05:44:36 PM »
Link to Matthews original thread on the device:
http://madmodder.net/index.php/topic,12195.msg145467.html#msg145467
Offline Graham Stabler
« Reply #6 on: December 21, 2017, 04:43:10 AM »
Andrew,
Are we allowed to start threads on general scraping topics (building a sharpener say) or is this forum just for finished things?
Cheers,
Graham
« Reply #7 on: December 21, 2017, 06:53:06 AM »
Absolutely Graham - start a thread  :thumbup:
This section is for anything scraping related so it's all collected in one place
« Reply #8 on: December 21, 2017, 11:40:41 AM »
Great, I have some stuff to post on DIY power scrapers too. I was just mindful because we are under a how to section and I won't initially know how to :).
Graham
Offline HughF
« Reply #9 on: December 22, 2017, 10:46:56 AM »
I completed the compound slide rebuild last night, the project I started when I was at the class. Many thanks to Andrew for the steel to make the gib from, that was completed last night. Now to finish the cross-slide scraping and re-assemble the lathe.
it feels completely transformed by the scraping and the new gib, hopefully the machine will cut better now.
« Reply #10 on: December 22, 2017, 11:04:34 AM »
When you adjusted the gib did you notice how little adjustment was required from sliding to locked up solid?
Offline HughF
« Reply #11 on: December 22, 2017, 11:22:31 AM »
About 5 degrees of rotation on the grub-screws! Can't wait to get the cross-slide done now...
