Author Topic: Quick and dirty die-nut.  (Read 23914 times)
Offline one_rod
  • Chesterfield, Derbyshire.
« on: July 18, 2017, 05:06:25 PM »
As there seems to have been a bit of traffic on the forum lately, about case-hardening, I thought I'd add my two pennyworth.
Nothing special, just an everyday job from work. But I had my phone with me, so thought I'd take a few pics.
The problem.
The threads on the end of this spindle have been damaged. Doesn't look much, but I've chased them out with a fine file, and still can't get the nut to spin on freely. If I force it I'll end up galling the thing up properly, and probably scrapping it. The thread is M16 x 1.25. An ISO-fine thread. There isn't a die nut anywhere on the firm to fit and the machine it's from needs to be back in action as soon as possible. Local tool suppliers say minimum 24 hours to get the right size die.
20170718_103622 by Mick, on Flickr
Aw, nuts...
Have some spare nuts with the right thread, so it's time to improvise. Cut a diagonal slot to give a good rake angle.
20170718_103908 by Mick, on Flickr
Got gas.
Warm to a nice cherry-red.
20170718_104357 by Mick, on Flickr
Old, but still useful.
I'm pretty sure this can has been with the firm longer than I have. We may retire together.
20170718_110239 by Mick, on Flickr
The magic happens here.
Add a little of the voodoo powder and re-heat, until it's all been absorbed or burned off.
20170718_104456 by Mick, on Flickr
20170718_104736 by Mick, on Flickr
Suddenly, we're cool.
The quench. For some reason my camera makes this look like it's white hot. It was actually a bright cherry red.
20170718_110407 by Mick, on Flickr
To work.
A quick wire brushing to get rid of the oxide scale, a dab of cutting oil on the threads, and feed it on. You can feel the difference, this is cutting the threads and making fine swarf, not just mashing the metal up.
20170718_105221 by Mick, on Flickr
Job done.
The proper nut now runs the threads nicely, no binding or snags.
20170718_105820 by Mick, on Flickr
Soon the machine is back in action and everyone is happy.
“Super Fitter” saves the day, again.   :thumbup:
« Last Edit: July 18, 2017, 05:37:19 PM by one_rod »
"A season ticket for the one way ride..."
Offline PK
Re: Quick and dirty die-nut.
« Reply #1 on: July 18, 2017, 05:51:48 PM »
Nice job! :clap:
« Reply #2 on: July 18, 2017, 05:59:11 PM »
Satisfying!
I have a can of Kasenit which I'm very protective of.
« Reply #3 on: July 18, 2017, 06:21:28 PM »
......The quench. For some reason my camera makes this look like it's white hot. It was actually a bright cherry red......
Mick - it may infra-red saturating the IR cut filter in front of the camera sensor, and the camera then maxing-out or auto-white-balancing.
« Reply #4 on: July 18, 2017, 11:14:17 PM »
Nice work.  Are you making its replacement in the meantime?
It doesn't look like there was much left for threads there, so I'd not trust it to hold up for very long before stripping out again.
Offline edward
« Reply #5 on: July 19, 2017, 10:16:44 AM »
I've done very similar for some damaged threads on some brass fixture screws using steel nuts, although I didn't need to harden mine. I countersunk one side of the nut as it seemed to help it engage the thread (damage was near the end). I was quite surprised at how well it worked, I was expecting it to be a quick fix until we got new fixings but the fixture is still in use months later.
Offline shipto
  • Redditch, UK
« Reply #6 on: July 19, 2017, 05:06:12 PM »
do or did they sell kasonite pre dented? dont think I have ever seen a properly round tin in my life.
« Reply #7 on: July 19, 2017, 10:17:34 PM »
Mine has a dent.
Offline Fergus OMore
« Reply #8 on: July 20, 2017, 02:13:03 AM »
Mine has a dent.
Exactly as designed! The manufacturers of the stuff hoped that once you had bought it that the tin would collapse and spill contents-- so that you would have to buy another tin. Again, I doubt that making cans( USA) and tins( UK)  could economically make distorted out of round containers.  I recall( very vaguely) pushing tinplate through solder horses- three high- and then they were split.
Remember if the guys were trying to save minute amounts of cash by using negative torroidal seams( then)  loomed. Somebody had already done a costing of just how thin the steel would have to be and more importantly, how thick the deposition of even more costly tin would have to - get away( my view) on the steel.
On the other side of packaging there was something called- lightweight glass.
Now, I'm sort of having a new workshop, my ersatz case hardening compound is in a plastic  container- probably cheaper than the original 'tin' but designed to do exactly the same as the original tin- but  the plasticiser would degenerate- and go to powder.
I went past Durham Cathedral in the train a day or so ago, it was designed  to last forever for the glory of God but we don't think that way anymore.  We don't mend poor quality steel in spindles and  we roll the thread and have rattling good fits on nuts which are-- clears throat- radioactive from recycled metal originally designed to replace case hardening.
Fun, init? Well, now the Brits are having to go to 68 to get their State pension-- or so it is said.
I got out of the rat race at 55- my own case hardening was already wearing through.
Have a nice day or whatever
Norm
« Reply #9 on: July 20, 2017, 09:28:15 AM »
Nevertheless, it's a sunny day, here, today, Norman, and the family and I are going to clean up and paint the boat. :ddb:
And should I find a damaged thread anywhere in the next few years I intend to do as one_rod has!
Offline Biggles
« Reply #10 on: July 20, 2017, 10:19:06 AM »
Good job, I haven’t seen a can of kasenit since I left school.   :coffee:
Offline S. Heslop
« Reply #11 on: July 20, 2017, 06:14:37 PM »
Satisfying!
I'm jealous of anyone with an old tin of Kasenit.
Following that line of thought i've just ordered some potassium ferrocyanide. Looking at old MSDS sheets for Kasenit it's listed at about 50% sodium ferrocyanide. MSDS sheets for the more modern stuff only list small amounts of potassium nitrate and chromium oxide (but not which kind). I've got a small amount potassium nitrate hidden somewhere so I could try throwing some of that in, but I wonder what makes up the other half of the old Kasenit. Going from the colour of the stuff it could just be powdered charcoal. Sodium ferrocyanide melts at 400°C so I don't think anything extra will be in it to make it famously stick.
Offline one_rod
« Reply #12 on: July 21, 2017, 10:14:18 AM »
Not really necessary, the spindle has virtually zero axial load. The nut just holds a bearing spacer and grease plate in place. The machine operator took the plate off for routine maintenance, damaged the thread, and rather than report it, tried to force the nut back on, hoping it would somehow be ok. Of course it wasn't ok...
Norm
I'd like to meet the person who first thought it was a good idea to pack stuff like this in plastic containers.     :wack:
Brazing flux is a particular gripe of mine. I get through quite a lot of the stuff at work.
But plastic and hot-bench work just don't mix. One careless moment with the oxy-prop torch and there's another canfull heading for the bin. :palm:
« Reply #13 on: July 21, 2017, 01:05:01 PM »
Spilt borax?   You should have no trouble with ants.
Norm
Of course, you could wash your dirty overalls in it.
« Reply #14 on: July 21, 2017, 06:21:02 PM »
will have to put a pic of my tin kasenit its got no dents
« Reply #15 on: July 21, 2017, 06:34:00 PM »
Bob
Cheers and thanks for your's and Peter's help tonight
Norm
« Reply #16 on: July 21, 2017, 07:08:40 PM »
Bob, are you sure you didn't take a buck and body hammer to it?  :poke:
Offline fatal-exception
« Reply #17 on: August 23, 2017, 04:32:53 PM »
Since Cherry Red comes in a plastic container, I'm going to put it in a steel container and proceed to dent it, just to follow status quo. :D
« Reply #18 on: August 24, 2017, 06:28:04 PM »
Mines yellowed :poke:
« Reply #19 on: September 20, 2017, 04:35:31 AM »
 Hi Guys
           Found some dark powder in a glass jar on shelf at the back of my garage the other day. Normally inaccessible due my ever growing stock of hard wood. I did buy some Casenite 20 yrs ago from Tilgears, and have searched many times for it in the past. The label I put on the jar has now disappeared, and I have bought other similar looking substances since. I must test it to see if I have hit the jackpot.
