Author Topic: Tips and suggestions for keeping stuff from falling off your bench  (Read 13664 times)
Offline RichardDepetris
It happens so often that I never gave it much thought, but it has become a real pain.  While I am working on a project on my bench, there's always screws and small parts that fall on the floor.  I have to stop what I am doing to get on my hands and knees to look for it. It usually takes several minutes to find a small part.
Aside from installing a trapeze net under my bench, how have you resolved this situation?
Sent from my iPad using Tapatalk
Offline mexican jon
Re: Tips and suggestions for keeping stuff from falling off your bench
« Reply #1 on: May 21, 2017, 01:16:59 PM »
Work on the floor  :doh:  :lol: :lol:
« Reply #2 on: May 21, 2017, 01:17:52 PM »
I was actually thinking about it.
« Reply #3 on: May 21, 2017, 01:22:47 PM »
A strip of the flexible magnet that's part of a 'fridge door seal glued around the vertical periphery of your bench. Not much use for brass screws but the steel ones will get caught  :thumbup:
Offline mexican jon
« Reply #4 on: May 21, 2017, 01:23:23 PM »
:D :D :D
« Reply #5 on: May 21, 2017, 01:28:17 PM »
Richard -- I use a "tray" with CRS Bars glued to it.  I then "attach" a bunch of magnetic cups to the "bars" into which I place my "small parts."  Unless I knock over the entire "tray," they stay where I put them.
« Reply #6 on: May 21, 2017, 01:43:48 PM »
If that is wood table a shallow half round groove if you have a routter is a good solution. Anyt other "stoppers" are nasty to arms. Some old writing desks had some interestin features on the front.
Another thing is to keep floor clean, contrastic color helps.
I usually clean when I first have dropped something on floor and frustrate with swarf and it takses ages to find the part I dropped.
« Reply #7 on: May 21, 2017, 02:31:30 PM »
I built a jewellers bench top I can mount in the bench vice on my steel bench.  The jewellers bench can have a tea towel pinned underneath to catch fasteners etc.   Very handy for working on small and intricate parts.   Something like below.
Offline mklotz
  • LA, CA, USA
« Reply #8 on: May 21, 2017, 03:03:30 PM »
Self-adhesive foam weather-stripping applied at the front edge of the bench can provide a forearm-friendly barrier for both ferrous and non-ferrous parts.
If you don't want it on the bench all the time, apply it to a thin plastic strip that can be laid down when needed and removed when not.
Do your work on a soft, tight-weave, light-colored fabric so that small parts won't bounce if dropped.  An old baby blanket works well as do the newer micro-fiber cloths.
For jobs where springs or clips are likely to "jump out", do the work with the work and your hands inside a transparent plastic bag.  Clothing bags from dry cleaners work well.
Regards, Marv
Home Shop Freeware
Offline Mike E.
« Reply #9 on: May 21, 2017, 03:39:30 PM »
If you have a wooden bench top, consider using a router with a ball shaped cutter to cut a shallow groove about an inch in from the edge, along the length of the bench; similar to the pencil groove on old time school desks.
Mike
California & Wales  - Home, & Home Away
« Reply #10 on: May 21, 2017, 04:46:25 PM »
Hi Mike welcome to the forum  :thumbup:
How do you fancy popping over to the introductions section of the forum and telling us all about your workshop and projects ?
http://madmodder.net/index.php/board,3.0.html
Offline Mike E.
« Reply #11 on: May 22, 2017, 04:02:56 AM »
Hi Andrew, thanks for the welcome. I'm slowly finding my way around the forum and have posted an introduction.
Mike
Offline wgw
« Reply #12 on: May 22, 2017, 05:30:03 AM »
Can't help with falling off- a wet &dry vac. cleaner is good , just search in the bottom for dropped bit. Hold a torch flat to the floor, shows up dropped bits.
