Author Topic: PCB routing  (Read 7837 times)
Offline PK
PCB routing
« on: April 14, 2017, 08:15:21 AM »
I used to make 4 or 5 boards a week using photographic techniques, then it was 10-20 a week, then board fab shops in china started offering boards for 50c a pop with no setup costs and  7 day turn times (including delivery)....
This is great, but two or three times a year I still need a PCB now...
Problem is that the emulsions and chemicals just don't store for any length of time, so it turns into a disappointing process..
I thought I'd give isolation routing a go in the X3 with the 60Krpm sub spindle.
It went well enough that I've ordered bits to take it to the next level.
Lessons learned:
  • Generic engraving cutters aren't close to well enough balanced to run at more than 30KRPM.
  • Small (0.5mm) carbide endmills work wel (used a v cutter in the attached).
  • A vacuum hold down fixture is important for keeping the stock flat..
Offline PK
Re: PCB routing
« Reply #1 on: April 23, 2017, 09:40:07 PM »
Say hello to my little friend!
Re: PCB routing
« Reply #2 on: April 24, 2017, 02:37:17 AM »
It makes you wonder how they make them?
Re: PCB routing
« Reply #3 on: April 24, 2017, 07:02:42 AM »
Small children with great eyesight and a Dremel.
Offline efrench
Re: PCB routing
« Reply #4 on: April 25, 2017, 02:49:31 PM »
Have you tried Voronoi style traces?
Offline PK
Re: PCB routing
« Reply #5 on: April 25, 2017, 05:34:22 PM »
You know, I'd never heard of them.  If the tool chain is short I'll give it a go.. Sadly the ball screw rebuild that resulted from this attempt has turned into a bigger than Ben Hur 'Cluster F&#k' of a job, with stripped threads and......
So it'll be a few days before I can get back to this....
