MadModder
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Login
Register
MadModder
Gallery, Projects and General
How do I??
metal lathe thread dial
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: metal lathe thread dial (Read 11184 times)
bert4255
Jr. Member
on:
April 10, 2017, 05:19:36 PM »
I would like to make a thread dial for my lathe. it is a large lathe has a 49" swing, nt that that matters. How do i determine how many teeth the thread dial needs in relation to the lead screw. Is there a ratio? I want to do imperial threads.
Logged
RussellT
Hero Member
Re: metal lathe thread dial
Reply #1 on:
April 11, 2017, 04:58:03 AM »
I think we need more information. Is the lead screw metric or imperial. What's the thread pitch?
Logged
bert4255
Jr. Member
Reply #2 on:
April 11, 2017, 06:58:33 PM »
I think the lead screw is imperial. I'm not sure on pitch. I'll try and find out. thanks
Logged
In Memoriam
Hero Member
Nottingham, England.
Reply #3 on:
April 11, 2017, 07:03:50 PM »
The gear has to be a multiple of the threads per inch.
Just guessing from the size but your lathe probably has a 4 tpi thread so the gear needs to be a minimum of 8 or better 16 teeth
Logged
bert4255
Jr. Member
Reply #4 on:
April 11, 2017, 09:47:27 PM »
Thanks John, I will check and see what the thread count is
Logged
bert4255
Jr. Member
Reply #5 on:
April 25, 2017, 02:07:29 PM »
John, I'm getting about 2 1/2 threads per inch, not even 2 1/2. how do i determine if it is metric screw or imperial
thanks
Logged
shipto
Hero Member
Redditch, UK
Reply #6 on:
April 25, 2017, 03:05:49 PM »
Some pictures of the screw with a ruler lined up might help.
Logged
bert4255
Jr. Member
Reply #7 on:
May 10, 2017, 11:47:43 PM »
ok, it is a metric leadscrew with a 2.5" TPI
Logged
Pete.
Hero Member
Reply #8 on:
May 11, 2017, 01:41:48 AM »
That would be a 10mm pitch screw. It's a big boy alright.
A large lathe like that might well have a single tooth dog clutch which would remove the need for a dial. What make is it?
Logged
bert4255
Jr. Member
Reply #9 on:
May 11, 2017, 07:24:24 AM »
Peter, I figured it out thanks
Last Edit: May 11, 2017, 10:48:43 AM by bert4255
Logged
mattinker
Hero Member
Reply #10 on:
May 11, 2017, 09:55:21 AM »
Thread dials get more complicated on metric lathes. Inch dial gauges are easier than metric ones because they work using parts of an inch as the base. You can need several thread dial gears to make a metric lead screw work.
I would make a ten tooth gear (four times the aprox TPI, even though it is metric!) I would then use the technique that Tom Lipton describes here
https://youtube.com/watch?v=HXt4TWa382Q
i am sure the a mathematicians who could work it al out , I suffer from what the Americans call "Matth anxiety" S o I do things to avoid calculating!
Logged
Print
Pages: [
1
Go Up
« previous
next »
MadModder
How do I??
