Author Topic: Dividing Head  (Read 6995 times)
Dividing Head
« on: February 16, 2017, 02:35:37 PM »
I have aquired a Tywanees dividing head Vertex BS-O same as the Grizzly G1053 that is shy some bits , the direct indexing gear no 18 in the PDF is missing , iff anyone hear has one please tell me the number of teeth for me to make one , thanks in advance .
Re: Dividing Head
« Reply #1 on: February 16, 2017, 02:49:07 PM »
Jeff,
Just to clarify, is part 18 a shaft with the pinion cut into it, or is it a splined shaft - the drawing resolution isn't quite good enough to tell  :scratch:
Re: Dividing Head
« Reply #2 on: February 16, 2017, 02:55:23 PM »
Hi Jeff,
I'll take mine apart later and measure it up.
Re: Dividing Head
« Reply #3 on: February 16, 2017, 03:09:51 PM »
Part 18 is a 10mm shaft with a pinion on the end , I have disasembled the head as it has sawdust in it will take some pics tomorow and post , you like pictures .
Re: Dividing Head
« Reply #4 on: February 16, 2017, 03:37:46 PM »
Jeff,
It's got 11 teeth.
If you want any dimensions let me know.
« Last Edit: July 13, 2017, 01:03:18 PM by philf »
Re: Dividing Head
« Reply #5 on: February 16, 2017, 03:41:59 PM »
Thanks Phil mutch apresheated I would not have gessed it had that many , I thought 8 at most .
Re: Dividing Head
« Reply #6 on: February 16, 2017, 04:08:52 PM »
Hi Jeff,
No problem.
Before I put it back I thought I'd take a few dimensions.
« Last Edit: July 13, 2017, 01:02:41 PM by philf »
Re: Dividing Head
« Reply #7 on: February 16, 2017, 04:12:45 PM »
"I have disasembled the head as it has sawdust in it will take some pics tomorow and post , you like pictures"[/i
.... he he .. how ever did you guess that  :clap:
This coming together of forum members and gleaning information is what it's all about  :thumbup:
 :mmr:
Re: Dividing Head
« Reply #8 on: February 16, 2017, 04:15:26 PM »
Thanks again Phil that will save me some time .
Re: Dividing Head
« Reply #9 on: February 17, 2017, 08:39:45 AM »
Got it cleaned white spirit and steel wool .
Re: Dividing Head
« Reply #10 on: February 17, 2017, 08:49:30 AM »
Put back together the rear oiler was broken drilled it out 1/4" only had 6mm so glued that in , also snaged two high range plates for it , fingers are missing and the nose is 1 1/4" x 12 my chucks are 1 1/2" x 8tpi and the locating blocks need replacing to fit my tee slots , but first will be the direct i8ndexing gear .
Re: Dividing Head
« Reply #11 on: February 23, 2017, 10:24:11 AM »
Made a pinion for direct indexing it's .75 module 11 teeth blank diameter of 9.98mm , I have a cutter that I made for 30 teeth so used that , the teeth were a litle more pointed but worked smoothly , I have another issue the roof is to low and will have to put a dormer on the shed . to give me the full travel of the colum .
