Author Topic: Making a Desiccant Air Dryer with Silica Gel  (Read 67593 times)
Re: Making a Desiccant Air Dryer with Silica Gel
« Reply #25 on: April 22, 2017, 06:52:40 AM »
Thanks Dickeybird
I've not measured the pressure drop but it will be minimal. The sintered silencer I'm using seems to present very little resistance blowing through it, and the silica gel crystals are large enough to have big gaps for air flow.
The air is not really expanding within the dryer so I'd not expect much cooling effect, though again I've not measured it - if air is flowing then I'm using the tool that's using the air, not feeling the dryer  :ddb:
« Last Edit: July 23, 2017, 06:53:44 AM by awemawson »
Offline shipto
  • Redditch, UK
« Reply #26 on: April 22, 2017, 06:56:42 AM »
Well theres no doubt it works to some extent at least. good job :thumbup:
« Reply #27 on: April 22, 2017, 07:07:34 AM »
So I thought I'd take a peek at at after it had been cooking for one hour. Superficially it all looked to have turned back to the original orange, but when I raked the surface there were still a few blue crystals, So I gave it a goodly stir up and have left it for it's second hour.
Certainly when I opened oven door, masses of steam came out to the extent that my glasses fogged up  :clap:
I seem to remember that silica gel can absorb it's own weight in water - now there's roughly 1kg cooking, so up to a litre of water if it was all used up.
« Reply #28 on: April 22, 2017, 07:09:32 AM »
Oh it's most certainly working, there is a noticeable difference in my shop air.
Offline shipto
  • Redditch, UK
« Reply #29 on: April 22, 2017, 10:05:23 AM »
It's a good solution to remember, I may have mentioned we used to have a dragun brand plasma at work with built in air that had no drying and ate consumables at a extraordinary rate
Sent from my SM-N910F using Tapatalk
« Reply #30 on: April 22, 2017, 10:37:55 AM »
The recycled silica gel is noticeably darker than the original - I suspect that I may have over cooked it - I'm sure that the water has been driven off, but perhaps I've affected whatever chemical is being used as a moisture indicator  :scratch:
« Reply #31 on: April 22, 2017, 11:26:23 AM »
Try a few grains "test" to see whether the colour changes!
Cheers, Matthew.
« Reply #32 on: April 22, 2017, 01:08:16 PM »
Yes I have Matthew and it does  :thumbup:
It turns out the the orange indicator in the silica gel is Methyl violet, but I've not been able to find anything about it's temperature stability. However I have found that the gel will recycle at a lower temperature - 120 deg C rather than the 140 I aimed for and possibly overshot  :scratch:
I think the gel will work still very effectively, but the indicator colour change, although it happens, isn't quite as definitive.
« Last Edit: April 23, 2017, 06:00:38 AM by awemawson »
« Reply #33 on: April 22, 2017, 01:46:32 PM »
That makes me think of other comparative tests, new and old! I think you've probably started thinking about that having begun tests! i would have though that it was the indicator capacity that would change, not the water absorption. It'll be interesting to see what you come up with!
cheers Matthew.
« Reply #34 on: April 23, 2017, 05:06:37 AM »
Suggest you weigh out say 50 grams, leave in damp place for some time, weigh it again.
During drying weigh it say every 30 mins and watch what happens to the weights.
Offline russ57
« Reply #35 on: April 25, 2017, 12:18:31 AM »
Just a minor warning... I had a similar water filter split. I have no idea why, and I had bought it second hand so it may well have been damaged a earlier. Fortunately, it split a day after we returned from holidays and wife heard the bang and the water running.
 If yours was to fail, the result might be more spectacular.  It might be worth considering a protective shield of some sort?
-russ
« Reply #36 on: April 25, 2017, 01:11:28 AM »
Oh dear! Russ, you just reminded me of the time when our filter popped an 'O' ring. Unfortunately we were actually on holidays not just arrived home like you. Couldn't get the back door open so went to the front. Stepped inside and found myself in 1/2" of water.
   Thankfully the insurance covered new floor coverings. I then moved the filter outside. Ain't hind sight a wonderful thing.
       Still, here we are discussing compressed air so no risk of flooding, just a (shielded) bang? I cannot recall whether the specs for the water filter were discussed.
« Reply #37 on: April 25, 2017, 02:23:20 AM »
Mine's rated at 160 psi but only supplied with air regulated to 100 psi so should have a bit of safety margin. However it is a sensible warning, having had a 25 mm 'stop end' blow off I'm aware of the power stored in compressed air.
In the case of my main desiccant drier, it is housed in an unmanned Portakabin, so there should be no risk to life and limb.
In the case of the one on my CNC Plasma Table, it is more exposed, but the input air is regulated down to 70 psi, so a higher safety margin.
Offline russ57
« Reply #38 on: April 25, 2017, 06:24:13 AM »
That's good. Still, a vessel giving way at 70 psi would possibly not go unnoticed 😨
-russ
Offline Ed ke6bnl
« Reply #39 on: April 25, 2017, 10:13:45 AM »
I made one years ago from a receiver for a large air cond. system. had screens in there and probably safe for excess of 300 psi. has a top that is removable with several screws. NOT CLEAR and it is out side on my car lift. I have never changed or reheated the silcone bead. sits for long period in the hot sun and seem to be ready all the time.
1950 Ford F1 streetrod
1968 ecotec powered Baja Bug kink coil overs
1953 Chevy AD ready for 4 cyl. cummins and nv4500
Offline Ed ke6bnl
« Reply #40 on: April 25, 2017, 10:16:45 AM »
I made one years ago from a receiver for a large air cond. system. had screens in there and probably safe for excess of 300 psi. has a top that is removable with several screws. NOT CLEAR and it is out side on my car lift. I have never changed or reheated the silica bead. sits for long period in the hot sun and seem to be ready all the time.
« Reply #41 on: April 25, 2017, 12:30:25 PM »
Ed, if the silica gel is in a sealed container the moisture will be retained however warm the sun is  :scratch:
Offline PK
« Reply #42 on: April 25, 2017, 05:36:07 PM »
I've used those exact filter cases for desiccant and coolant at 100PSI for years..
« Reply #43 on: April 25, 2017, 06:05:38 PM »
That's comforting to know PK  :thumbup:
Offline Ed ke6bnl
« Reply #44 on: April 25, 2017, 07:11:36 PM »
that make sense my only thought is that it get warm and leaves the silica gel and maybe in the 50 foot air line attached and on the first use it is moved out with the air and the remainder is dry air. Some of the line goes under ground and it use to have water with air and i do not see that since it was installed
« Reply #45 on: July 23, 2017, 06:47:35 AM »
Today it was time once more to 'cook' my silica gel to remove the moisture that it had trapped. Last time the crystals, which turn blue/black when damp, lost their nice orange hue on cooking, probably because the indicator had broken down at the 140/150 deg C that I used.
This time I set the electric oven to 120 Deg C, cooked for three hours and they have returned to a nice orange  :thumbup:
(It's now cooling under cling film to keep the moisture out)
« Reply #46 on: July 24, 2017, 02:36:01 AM »
Great to read that your regenerative desiccant air dryer is working as designed Andrew.
 :mmr:
Regards,
Offline RodW
« Reply #47 on: July 24, 2017, 04:58:44 AM »
A very god project and I'm sure you saved quite a lot for a bigger desiccant drier compared with the commercial one I bought.
http://i210.photobucket.com/albums/bb270/rodweb/Mobile%20Uploads/2017-07/20170724_184240_zpsubse0hlw.jpgMaking a Desiccant Air Dryer with Silica Gel
THis has a filter/regulator, coalescent filter and finally a dessicant drier which cost me about AUD $220. THe final filter is a motorguard style "toilet roll" filter which seems obligitory on all plasma cutters I've seen in operation.
RodW
Brisbane, Australia
Offline howsitwork?
« Reply #48 on: July 25, 2017, 04:18:14 PM »
Andrew
Well impressed, can't think how I missed this project.
Ian
