Author Topic: Bodging with Boris/ Bernhardt........  (Read 79642 times)
Online tom osselton
Re: Bodging with Boris........
« Reply #50 on: September 24, 2017, 02:07:44 PM »
I always look forward to your posts it's to bad about photobucket we all hope there's a special place in hell for them! :wack:
« Reply #51 on: September 24, 2017, 03:24:57 PM »
Thank you, Tom! ... I'm pleased I haven't been forgotten!   :wave:
Don't forget, you can now see any/ all Pbucket pics. Simply by Installing the appropriate add ons.
Firefox.....  https://addons.mozilla.org/en-US/firefox/addon/photobucket-fixer/
Chrome..... https://chrome.google.com/webstore/search/photobucket_hotlink_fix?hl=en
What a tremendous own goal, Pbucket have scored!  :loco:
So..... While thinking what to do, about the detached flange. I set to, making the cooling fins.
Around 4"/100mm diameter.
Started with, square, 5mm thick blanks. And, one off at 8mm thick, to screw to the bulkhead.
Using 3 stops, on the mill table. Means I can locate/ relocate all blanks, accurately. Every time......
Making it easy, to mill off the corners. Instead of sawing......
Also, to drill a central, 6mm hole.......
A piece of 4" dia steel, in the chuck. Faced with wide insulation tape. Plus a lump of spare nylon......
Friction turned the remaining corners away........
Giving, a handful of discs, all the same diameter.
Moved onto the mill.......
Removed the centre areas. Just undersize, to the hot cap o/d of 47mm......
Parted off, Five, 63mm dia blanks. From bar stock, and removed the centres, too.......
After finish boring, on the lathe. A quick mock up......
I think that looks ok.....  :thumbup:
Thanks for looking in......
« Last Edit: August 30, 2018, 02:51:22 PM by Stilldrillin »
« Reply #52 on: September 24, 2017, 03:44:22 PM »
Proper Job  :thumbup:  (said in a west country accent )
« Reply #53 on: September 24, 2017, 05:51:27 PM »
Thanks, Andrew!
Happy memories of Scrapheap Challenge, and the wonderful things they, "found", to Moderfy.......   :smart:
« Reply #54 on: September 25, 2017, 05:10:21 AM »
 It looks good but I'm puzzled!   :scratch:   :scratch:   :scratch:   :scratch:   :scratch:   :scratch:
Is it a VFD for the lathe?   :lol:   :lol:   :lol:
« Reply #55 on: September 25, 2017, 06:37:56 AM »
Oooohhhh........ Pete!  :bugeye:   ....... I love it, when you Lekky Lads, talk dirty.....  :thumbup:
« Reply #56 on: October 16, 2017, 07:58:32 AM »
I eventually, got my head around the hot cap, sealing/ retaining problem.
Finding a piece of correct diameter, tube. (It just happened to be bronze). I silver soldered a ring, to replace the original flange.....
Recessed, the new holding flange.......
The cylinder/ spigot, protrudes through, by "a couple of thou'". To make a positive location/ seal, against the bulkhead.......
Held on, by three, neater than original, screws........
Secure......
Thanks for looking in!
« Last Edit: August 30, 2018, 02:53:26 PM by Stilldrillin »
« Reply #57 on: October 16, 2017, 08:36:46 AM »
I hate to see engines, held onto their wooden bases using, obvious, wood screws. I prefer engineering screws. Button heads, look ok.
Or, in this case. Countersink.......
The two rear fixing holes are now, under the bearing pedestals.
Had to drill a central hole.......
I drill, clearance holes, for the screws.
Underneath. I counter bore 15mm deep. The same diameter, as the nut's a/f measurement.
I can then pull the nuts, captive, into the recess......
« Last Edit: August 30, 2018, 02:54:16 PM by Stilldrillin »
« Reply #58 on: October 16, 2017, 02:24:52 PM »
New, improved, crankshaft location.....
The two uprights, are made from 6mm thick angle iron. Cleaned up, square, on the mill. Dowelled and screwed in place, from underneath the base plate. Allowing removal, and accurate replacement, when necessary.....
The two, outer bearing housings, are a sliding fit, in the uprights. Held in place with slidelock........
The inner bearing housings, slide over the smaller diameter.......
Butting against the upright. Also, held with sleevelock.......
Should be much more effective than the wobbly, original assembly.
« Last Edit: August 30, 2018, 02:55:21 PM by Stilldrillin »
« Reply #59 on: October 17, 2017, 01:46:40 PM »
The crank assembly, is finished....
It cycles nicely. No tight spots.......
The flywheel, is next. At 7" dia. It's a little on the large side, for a mini lathe......
The original bore was unsuitable. So, I drilled out, oversize, and plugged with a piece of m/s. Held in with the ever faithful sleevelock.
The rear boss, held in the chuck jaws, has been machined nicely true to the rim. Allowing me to set the rim running, within a thou'.
Now, I'm starting to open up to a 10mm dia bore. Hopefully. Perfectly true to the rim......
We'll see......
« Last Edit: August 30, 2018, 02:56:40 PM by Stilldrillin »
« Reply #60 on: October 19, 2017, 02:14:40 PM »
Boring shallow recesses, for each size of drill. Then the 10mm reamer. Held them all, true to centre line.......
After re assembling. Time for a quick test run.......
Only, the cosmetics left to do, now......  :thumbup:
Online tom osselton
« Reply #61 on: October 19, 2017, 02:20:59 PM »
I can't see the test run video.
« Reply #62 on: October 19, 2017, 03:00:19 PM »
Sorry Tom.
I had forgotten to, "Publish". Hope, it's ok now.....  :thumbup:
« Reply #63 on: October 19, 2017, 03:08:24 PM »
That's a cracker David!
 :clap:
« Reply #64 on: October 19, 2017, 03:26:08 PM »
Very nice  :thumbup:
Offline fcheslop
« Reply #65 on: October 19, 2017, 05:34:08 PM »
Very nice.
If it had been in my shop it would have been a door stop or hiding with the spiders under the bench
Keep well marra
cheers
« Reply #66 on: October 23, 2017, 05:30:38 PM »
Phil, Andrew.
Thank you, Gentlemen!  :thumbup:
Very nice.
Keep well marra
cheers
Nah!
You, would have made it correctly. In the first place.....
Had a good showday, on Saturday.
It ran for over five hours. Only stopping for meths top ups.......
« Last Edit: August 30, 2018, 02:59:30 PM by Stilldrillin »
« Reply #67 on: October 24, 2017, 12:27:39 AM »
The master strikes again:- another great job Dave
PS I hope you and yours are all well
« Reply #68 on: October 25, 2017, 05:45:21 PM »
Thanks Stew!
I think I might be getting the hang of these things. After all this time.....  :thumbup:
We are, "normal", here, thanks. Hope the same goes for you. Over your side of the Pennines.
« Reply #69 on: October 24, 2018, 05:23:41 PM »
It's been a while. As I often say.
After some 60hrs running. I'm calling this job, finished. Finally!
And.... The final video. Filmed, while setting up my table at Papplewick, last Saturday......
« Reply #70 on: October 24, 2018, 05:43:31 PM »
Nice :thumbup:
Time for a strip down and inspection at 60 hours ?
Online tom osselton
« Reply #71 on: October 24, 2018, 08:07:52 PM »
That runs real nice!
« Reply #72 on: October 26, 2018, 06:06:43 PM »
Nice :thumbup:
Nah! Not until it starts to sulk, as they all do, in time.
The Maiwald.......
Ran for around 100hrs, before it decided, it didn't like it's brass piston. So, I made a steel one. It's happy again now.
Andrew, Tom. Thanks for your kind comments.  :thumbup:
« Reply #73 on: October 28, 2018, 02:52:59 PM »
Great work, David!  :clap:
Offline hanermo
« Reply #74 on: November 07, 2018, 05:03:51 PM »
The pics and craftsmanship are fantastic.
