Author Topic: Rebirth of a 6 Foot Flail Mower  (Read 320385 times)
Re: Rebirth of a 6 Foot Flail Mower
« Reply #125 on: June 10, 2018, 08:02:24 AM »
Interestingly, the parts drawing that I have illustrates quite a different form of flail.
Mine are rather like a  comma curled around their mounting bolt, whereas these ones swing on a bent rod link. I don't suppose that the grass minds which form clouts it on the head at a great rate of knots  :lol:
Carlquib, do you have any references you can cite to the sucking nature of the curl?
The only similar replacement flail to mine that I can find illustrated on the web has a very similar amount of curl to mine
Offline carlquib
« Reply #126 on: June 10, 2018, 08:15:13 AM »
We use several different types of these flails. They are used for mowing, same as yours, but also to defoliate sugar beets before we dig them. The sucking reference comes from there. My parma topper whirls them around at 2500 rpm. You can watch it pull the material up off the ground so it does a better job shredding it. I've had the other style of j knife as well and they just don't do as good a job. They don't generate the lift on the material. I'm sure glad mine aren't $15, I believe the last batch I picked up was about $7.00, which I though was plenty.
My name is Brian and I'm a toolaholic.
« Reply #127 on: June 10, 2018, 09:37:59 AM »
... mm $7 - that's about £5 which is far more reasonable, though as Norman says not too complex to make given a forge and a suitable jig.
I wonder what steel they are - something fairly tough I expect  :scratch:
Offline carlquib
« Reply #128 on: June 10, 2018, 09:57:53 AM »
The flails we get are made from a 1095 spring steel.
Offline Jo
« Reply #129 on: June 10, 2018, 12:37:51 PM »
Sounds like the idea use for old car suspension leaf springs
Jo
Online NormanV
  • United Kingdom
« Reply #130 on: June 10, 2018, 12:50:48 PM »
Five years ago I bought a new blade for my rotary mower, it cut really well. I have just looked at it for the first time since then. It looks totally wrecked, but, I cannot detect any difference in its cutting abilities. Grass is not so tough!
Offline wgw
« Reply #131 on: June 10, 2018, 01:30:17 PM »
In an earlier life I designed mowers and etc. We did some experiments on grass cutting, as expected the main thing was speed of the rotor tip, with correct speed could cut grass with just about anything. A few lengths of chain worked just as well as a sharp blade. Of course it depends what the cut grass is to be used for.  BTW grass is tough stuff, try getting it in a bearing.
« Reply #132 on: June 10, 2018, 01:46:45 PM »
I have one area of pasture that is rather infested with rushes, both 'clump rushes' and 'creeping rushes'.
Regular cutting is about the only way to keep them under control, but it is very noticeable that the tractor (Ford 4000 1974) labours far more on the rushes than the grass, also you can tell from the smell which you are cutting !
Having sharpened the blades I did the entire 10 acres in high range 1st gear this morning before breakfast, whereas the last cut pre-sharpening was low range 4th until in the rushes, when I had to drop to low range 3rd, and low second on occasions.
Really the field needs proper drainage installed then it's acidity regulated to get rid of the rushes, but it makes no economic sense for sheep grazing.
(Where the rushes are is very peaty - originally a stream bed then silted up about 100 years ago)
Offline wgw
« Reply #133 on: June 11, 2018, 06:33:03 AM »
The rushes can create their own bog, the roots attract water by capillary action. I,ve got some in a small field, and it's high, started getting boggy after 3 years. My fault, didn't bother cutting the few bits there was after a year with no grazing and it just spread. Sheep might help, spraying works.
« Reply #134 on: June 11, 2018, 06:53:43 AM »
Heavy cutting, then when the new shoots emerge hit them with a 'weed wiper' charged with glyphosate is the received wisdom - be good if I had a weed wiper  :scratch:
The idea being the the roll of the wiper only touches the rush shoots and not the surrounding grass. A drop of washing up liquid in the glyphosate helps break down the waxy surface of the rush.
I have had some success on 'clumping rushes' with a backpack sprayer but it's hard going covering a large area. Whenever I need a bonfire it is always placed on the most dense patch of rush that I can find - they don't like that at all  :lol:
« Reply #135 on: May 08, 2019, 07:27:23 AM »
(Revival of an old thread but this is where the information should go!)
Start of the grass mowing season, so on Bank Holiday Monday I coupled up the Turner 6 foot flail mower to the Ford 4000 for the first time this year.
It was an ABSOLUTE PAIN to get the PTO female spline on the PTO shaft onto the male spline on the tractor. Would have been easier if there was help about but I was single handed. So what's the problem? Well turning the male spline by hand just gripping it is not possible due to drag and suchlike in its gear box. Turning the female spline, which is in the UJ on the end of the PTO shaft is only possible by putting a lever through the UJ, but then it turns back by itself due to the weight of the flail teeth flopping one way or the other.
Now while trying to get the rotational alignment  right, you have to press a button on the UJ yoke to allow the male spline to enter the female, and draw the two together all in a confined space between the mower and the tractor.
It actually took me 90 minutes which is obviously not acceptable - something must be done  :bang:
Having mowed the 'ten acre' and sitting down to relax I started Googling - I surely can't be the first to have this problem. Sure enough, some one has patented a spanner to go on the male spline in such a away that you can rotate it a bit while offering up the UJ female spline. This would make the job hugely easier. The spanner of course has to be able to be removed once the aligned parts are together, so has to be open ended not a ring which could have been made to fit the splines.
The patented 'spanner' solved this by being a simple parallel jawed open ended spanner, with a screw through one jaw to engage into the low part of a spline - crude but probably effective.
So for goodness sake make one before the next time you have to change the mower over - so I did  :ddb:
A quick Autocad sketch into SheetCAM as a DXF and then off to the CNC plasma table would do the job, but the thickest plate that I had to hand was only 8 mm thick. No matter - make two and weld them together - so I did  :ddb:
Rough and ready the pair got tacked together, an 8 MM thread popped into one jaw with one half sitting in each plate and lets try it out - so I did  :ddb:
I was concerned that a steel screw bearing onto the inner diameter of the splined shaft might do damage, but by reducing the end of the screw and doming it any damage will be minimal and anyway it bears on a bit of the shaft that in practice is never used. I would have used a brass bolt but not only did I not have a suitable one, I suspect that it would shear off in use.
All rather crude, certainly agricultural, but it works  :clap:
Hopefully next change over will be less frustrating
« Last Edit: May 09, 2019, 11:36:03 AM by awemawson »
Offline seadog
  • NE London
« Reply #136 on: May 08, 2019, 10:38:15 AM »
Now all that you need to do is to make sure you put it somewhere where it can be found when it's needed. Or, chain it to the flail  :D
« Reply #137 on: May 08, 2019, 11:12:41 AM »
I deliberately made it so it was not too long to go in the tractor tool box  :thumbup:
Offline pycoed
« Reply #138 on: May 09, 2019, 07:02:53 AM »
Just be thankful you have the button type yoke! I'd love to know who thought it would be a good idea to use a collar that you have to pull back whilst you are shoving the PTO shaft forwards to engage :bang: :bang: :bang:.
My tractor (Zetor) has a "helpful" metal shroud around the PTO stub as well, not to mention the damned PTO shaft guard that doesn't telescope any more since my old tractor self immolated  :Doh:
Offline mc
« Reply #139 on: May 09, 2019, 06:42:52 PM »
I would of thought the flail should be fitted with an overrun clutch?
« Reply #140 on: May 10, 2019, 02:20:56 AM »
Old technology here Moray, 1970's tractor and flail probably much the same vintage
« Reply #141 on: May 10, 2019, 05:59:48 AM »
Agreed 1000% a few of our machines have collars and they are real PITA
« Reply #142 on: May 10, 2019, 09:07:41 AM »
It did occur to me that a Jubilee Clip temporarily applied would sort the push button issue - or even a suitably sized G-Clamp
Offline mc
« Reply #143 on: May 10, 2019, 07:21:08 PM »
I've worked on older machines with overrun clutches, but have never dealt with a flail. I can't make up my mind whether a flail would have enough of a flywheel effect to justify needing one or not...
It might just be because I'm 6'4", but for big PTO shafts I just hold them between my legs, while wrestling the splines in to line. Once they're aligned and on that first 1/2", you can then worry about retaining pins/collars.
Offline pycoed
« Reply #144 on: July 04, 2020, 09:32:42 AM »
For anyone reading this epic adventure who is not familiar with this flail mower I would add the following ( having just collected my own via Ebay!)
What Andrew is underplaying is the sheer massiveness of this mower - modern good quality 6 ft flail mowers are typically 330 Kg (Kubota) to 450Kg (Bomford's modern machines)--------- this one is 700Kg
It's an absolute monster, so hats off to Andrew for coping with the beast :clap:
When I got mine home I complained to the wife about how edgy my SWB Vitara felt towing it home compared to previous pickup etc. I thought then it was around 400Kg plus the 650Kg of the trailer (8X5 tipper) after contacting Bomfords to get the operator's manual sent to me I was staggered to find the actual weight.
Thankfully mine is in pretty good working order:-
Offline pycoed
« Reply #145 on: June 12, 2023, 11:00:56 AM »
If you think Andrew's flail roller  was bad, then just have a look at this one!:-
The bearings are easy to change (did mine last year) as long as you recognise when they are knackered & do  something about it - this one from  Snowball  Engineering takes a bit of believing for leaveitalonery.
« Reply #146 on: June 12, 2023, 01:31:12 PM »
That's Snowball Engineering I think.He does an excellent job and is pleasantly modest as he does it.
« Reply #147 on: May 26, 2026, 06:01:17 AM »
Well it's been working for a long time, but the flail mower has failed :bang:
Young lady driving it for me says the the rear roller isn't rolling. Well no it isn't as the right hand stub axle has parted from the roller - ten year of fatigue on the weld I expect. Much bending and distortion  - all a bit of a mess
It's possible that the spool that forms the stub axle is reusable if not bent - and the tube certainly is but both will need major clean ups before re-welding
I removed the right and left hand trailing skids to make access easier then tried removing the right hand bearing - no chance - firmly stuck - heat - hydraulic pullers - big hammers - no avail - need it on the bench to introduce it to an angle grinder.
In the end it only took one 4.5" disk - surprising as it's very hard steel:
This leaves the skid that got bent in the original failure and even more when I tried removing the bearing from the shaft !
Bent skid introduced to 60 ton press a few times in judicially placed places and it's somewhat better (but not perfect) - but after all they ARE self aligning bearings  :clap:
Putting the stub axle between centres on the lathe it seems to have survived without bending so I will re-use it
Replacement two mounting hole (130 mm spacing) RHP self aligning bearing housing with 1-1/4 insert ordered from Bearing Boys (?80 !) so update when it arrives.
« Reply #148 on: May 26, 2026, 09:34:16 AM »
Small update: the self aligning 1-1/4" bearing sits on a 'Grass Guard' designed to stop grass entering the bearing.
Despite the fact that frankly it doesn't work I thought that I'd better make a new one, as the previous one suffered at the hands of the angle grinder while the seized 1-1/4" insert was cut off. Made from 1/8" mild steel the only bit that I had was horribly rusty and had a matrix of small holes drilled into it.
Well beggars can't be choosers so I pressed on though I had great fun getting a decent earth for the CNC Plasma Cutter, that I woke from a long and deep sleep not having been used in ages.
Came out acceptably for what it's for.;
« Reply #149 on: May 26, 2026, 12:25:37 PM »
Looks good Andrew, and glad to see you back posting.  :thumbup: :beer:
I'm not doing anything interesting -- just yardwork chores alternated with escapes early or late in the day to go fishing at local ponds or river for an hour or two... on occasion. Waterball is filling up to its 3000 gallon limit -- an inch shy today.
Have done a lot of brush-hogging, trying to get a handle on invasive multiflora rose, japanese barberry and black locust starts, which are making life somewhat thorny! Plus winged euonymous, oriental bittersweet, Japanese knotweed. Pretty soon these guys are going to take over if neighbors around here don't start cutting them back, as well.
