Author Topic: 2 Axis CNC doodad  (Read 33563 times)
2 Axis CNC doodad
« on: August 09, 2016, 04:56:13 PM »
Evening chaps
A mate of mine gave me this thing ,no idea what its off ,any one recognise it ?   Aluminium frame ,well made .
http://i1066.photobucket.com/albums/u410/RobWilson100/X%20Y%20Thing/P1120036_zps6ifowdws.jpg2 Axis CNC doodad
http://i1066.photobucket.com/albums/u410/RobWilson100/X%20Y%20Thing/P1120042_zpsyaobty4v.jpg2 Axis CNC doodad
Removed the bellows for a look see .
http://i1066.photobucket.com/albums/u410/RobWilson100/X%20Y%20Thing/P1120045_zpsnm00cnkg.jpg2 Axis CNC doodad
http://i1066.photobucket.com/albums/u410/RobWilson100/X%20Y%20Thing/P1120046_zpsofj7pbly.jpg2 Axis CNC doodad
http://i1066.photobucket.com/albums/u410/RobWilson100/X%20Y%20Thing/P1120047_zpskk72su9k.jpg2 Axis CNC doodad
http://i1066.photobucket.com/albums/u410/RobWilson100/X%20Y%20Thing/P1120044_zpssjrwxqbi.jpg2 Axis CNC doodad
http://i1066.photobucket.com/albums/u410/RobWilson100/X%20Y%20Thing/P1120050_zpsv0zozffj.jpg2 Axis CNC doodad
Looks like it may make a canny wee plasma table , work area 500mm x 400mm
http://i1066.photobucket.com/albums/u410/RobWilson100/X%20Y%20Thing/P1120048_zpszq8zozze.jpg2 Axis CNC doodad
or maybe a router  :coffee:
Re: 2 Axis CNC doodad
« Reply #1 on: August 09, 2016, 05:03:59 PM »
Absolutely no use at all Rob. Seeing as you're a mate I'll get rid of it for you FOC  :lol:
« Reply #2 on: August 09, 2016, 05:07:22 PM »
Plasma, router, not much difference.
It could be made to do either but for a router you would need a Z axis and that beam might be a bit skimpily built to support one. Hard to tell from pictures.
Plasma would be easier and then you just want of those controller that Joules was playing with.
Ignore that Mawson bloke, he's only jealous.
« Reply #3 on: August 10, 2016, 01:59:19 AM »
It's not been used as a router theres no sh*t / dust in the bellows , take it from me ruter dust is hard to get out completly .
« Reply #4 on: August 10, 2016, 05:06:46 AM »
The motors are 1980's style 4 wire ?  They are pre hybrid (modern motors)  The frame looks like it came out of a light sensitive environment with it's dark anodised finish.  I got a hit on Hewlett Packard using these motors in a gas chromatograph, so it's most likely high end stuff that this came out of.
i.e   NOT one of these....
« Reply #5 on: August 10, 2016, 09:50:14 AM »
Wonder what the switches on the belts are for in pictures 5 & 6? Stop switches for loose tension on the belts?
« Reply #6 on: August 10, 2016, 03:24:38 PM »
They'll be in the Estop series connected fault chain detecting broken or over slack belts
Offline NeoTech
    • Roughedge Hobbyworks
« Reply #7 on: August 10, 2016, 03:33:01 PM »
Woop woop. i see a new fancy Plasma table!   :poke: :poke: :poke: :poke:
« Reply #8 on: August 10, 2016, 04:18:44 PM »
Thanks! Figured on the slack belts, but not the broken ones. Neat idea!
« Reply #9 on: August 16, 2016, 12:33:41 PM »
May not be fast enough for a plasma cutter  , fine screws and stepper motors says precision and slow. Nor does it look strong enough for a big router , maybe an engraver? (ex optical device?)
« Reply #10 on: August 18, 2016, 11:32:11 AM »
mmmmmmmmmmmmm  :scratch: maybe a 3D Printer  project   :scratch:
To be honest I am not sure I have the free time to do anything with it . so so much going on  :dremel:  I still have all this lot to go at that I got 6 years ago .
Offline nrml
« Reply #11 on: August 18, 2016, 05:48:58 PM »
I would throw away those flexible couplings and use something more substantial if I were building a machine from those parts. I've seen several reports of the springy bit cracking in use and causing difficult to trace problems down the line. The three piece aluminium and plastic couplings are almost as cheap and are less likely to fail.
« Reply #12 on: August 18, 2016, 06:37:47 PM »
I agree with the first bit but not the second. The alloy and plastic couplings, often known as lovejoy coupling are not guaranteed to be backlash free plus they can only handle misalignment in one plane.
The only coupling that is backlash free and can handle misalignment in two planes is the Oldham coupling.
Its attention to detail like this that turn a mediocre conversion into a good one.
Problem in someone foits a set of lovejoys and posts the pics and everyone follows suit.
« Reply #13 on: August 19, 2016, 05:26:15 AM »
There are other types accommodating misalignment in two planes John.
This is a photo of an assortment from my coupling drawer.
The four on the left are all zero backlash and allow slight misalignment in two planes and angular misalignment. They tend to be very expensive but, in my experience, are used in the applications requiring greatest accuracy and reliability.There are versions of this type of coupling with only one flexible driving plate - these are cheaper but only compensate for angular misalignment.
Your favoured Oldham coupling (3rd from L on top row) will accommodate much more misalignment but it can come at a cost of lifetime. The more off-axis the motor and leadscrew the more sliding between the three parts and therefore wear and eventually backlash. They are 'relatively' cheap and ideal for home CNC projects.
The aluminium coupling at bottom right will take small amounts of misalignment in all planes but if they are not well aligned they will fatigue. They are also very springy so, if the table you are trying to move has any friction, a step or two at the stepping motor might well not move the table at all and just wind the 'spring' up.
I agree that the Lovejoy type of coupling will only compensate for angular misalignment.
Cheers.
« Last Edit: July 13, 2017, 01:07:11 PM by philf »
« Reply #14 on: August 19, 2016, 05:35:13 AM »
Thanks for that Phil, may I copy and save this for future use with credits of course ?
« Reply #15 on: August 19, 2016, 05:38:03 AM »
Certainly John - Phil.
