Author Topic: Elbow grease in a ultrasonic tank?  (Read 8805 times)
Offline Rick O Shea
    • www.clockconservation.co.uk
« on: June 21, 2016, 03:48:43 AM »
I noticed a thread recently about cleaning  and it was suggested that elbow grease, no don't laugh , is very good stuff. I wonder if this  is suitable to be used in ultrasonic tanks. I believe it is a citric acid based chemical pretty dilute I would imagine with some sort of soap chemical added but I don't know. Any advice or comments.
I am planning to use it to clean small instruments like speedometers. I use ultrasonics in my clockmaking work but with different chemicals, I would like on that is a bit easier to dispose  and is not too damaging to the environment. and that works, quite a big ask.
If I knew any more I would be very very dangerous, but as I do not know much I am quite quite harmless.
Located in the Royal Forest of Dean Gloucestershire.
 www.magnetic-speedometer-repair.com
Offline RotarySMP
  • Country: at
Re: Elbow grease in a ultrasonic tank?
« Reply #1 on: June 22, 2016, 09:26:09 AM »
Elbow grease in the ultrasonic might work, but I find a bucket of propwash just as effective.
Mark
Mark
Offline Eugene
« Reply #2 on: June 22, 2016, 10:39:31 AM »
Rick,
A common or garden dishwasher tablet is pretty good, in some warm water.
Eug
Offline appletree
« Reply #3 on: June 22, 2016, 02:31:15 PM »
Hi what is propwash please? product not known to me in UK.
I use paraffin in my ultrasonic for “Rough” cleaning and Automotive panelwipe for finer work (in my other machine).
Panelwipe   is a degreaser used in car painting quick evaporating and leaves no residue £12 gallon
« Reply #4 on: June 22, 2016, 03:32:57 PM »
Hi what is propwash please? ...
Used to clean up after spilling either the green oil burnt in the starboard navlight or the red oil burnt in the port navlight on the golden rivet....
(actually propwash is the air current behind a propeller......)
Offline Rick O Shea
« Reply #5 on: June 23, 2016, 05:07:20 AM »
Thanks for the prop wash, due to dyslexia I read it as hogwash.......
I use paraffin at the moment and have tried a variety of things in the past, I will have a look at panel wipe, does it contain Zylene? which I can't stand.
many thanks for the help so far.
« Reply #6 on: June 23, 2016, 05:14:48 AM »
Strewth, what a job blending the oil for white light, I had no idea.
Offline mechman48
« Reply #7 on: June 28, 2016, 10:20:05 AM »
You need blue oil to blend with the red & green... three primary colours to give 'white light'... as long as you get the ratios correct... :thumbup:  :palm:
George.
George.
