Author Topic: Boley 5LZ  (Read 6341 times)
Offline smiffy
Boley 5LZ
« on: April 03, 2016, 06:28:00 PM »
Had to make a new pin for a local farmers plough . 50mm dia and one end threaded 1-25 pitch on a reduced shank of 45mm. Material is EN24
So set my boley for semi auto screw cutting and this is a video of it working prior to cutting the thread.
The lathe  has 2 micro switches on the bed operated by stops on the apron . As the tool approaches the end of its cut the spindle is electro mechanically braked and reversed at 4x the cutting speed , when it has fully returned the spindle is reversed and cut put on and a the processes repeats itself  The lead screw is anti backlash and always engaged while screw cutting
There is no screw cutting gearbox but a large  selection of gears and it can cut Metric Imperial Modular and DP pitches
Offline smiffy
Re: Boley 5LZ
« Reply #1 on: April 03, 2016, 06:32:19 PM »
Maybe this link will work
Offline smiffy
Re: Boley 5LZ
« Reply #2 on: April 04, 2016, 03:23:19 AM »
 Having problems with the link if this does not work i=I give up
Offline RotarySMP
  • Country: at
Re: Boley 5LZ
« Reply #3 on: April 04, 2016, 05:29:25 AM »
The third link works for me. Sweet lathe. Where did you end up getting it from?
Mark
Mark
Offline Rick O Shea
    • www.clockconservation.co.uk
Re: Boley 5LZ
« Reply #4 on: April 04, 2016, 06:25:00 AM »
Hi Mike
That is a glorious lathe, nice bit of work too.
best wishes
Mike
If I knew any more I would be very very dangerous, but as I do not know much I am quite quite harmless.
Located in the Royal Forest of Dean Gloucestershire.
 www.magnetic-speedometer-repair.com
Offline smiffy
Re: Boley 5LZ
« Reply #5 on: April 08, 2016, 04:51:09 PM »
According to the Boley book I have spindle is a 3 Din 55 022 bored 4 MT and was available on request
Offline RotarySMP
  • Country: at
Re: Boley 5LZ
« Reply #6 on: April 08, 2016, 04:55:38 PM »
Now I get it.  :doh:
Size 3. (same as Camlock D1-3). I wonder how many different flavours of the KK short taper nose the germans came up with?
Certainly a better spindle nose than the threaded one.
Mark
Mark
