Author Topic: In case you missed these High temp sharpie's  (Read 8572 times)
Offline PTsideshow
« on: April 03, 2016, 08:01:22 AM »
In case you missed these hanging near the check out at your local big box (menards) May not be welding temps 500'F but still might last longer than regular ones in the shop.
http://i35.photobucket.com/albums/d200/ptsideshow/Shooting%20Reloading/FullSizeRender%2025_4.jpgIn case you missed these High temp sharpie's
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Re: In case you missed these High temp sharpie's
« Reply #1 on: April 03, 2016, 09:55:25 AM »
Use TIPEX, we marked gas turbine blades with it and they can exceed 1000℃
« Reply #2 on: April 03, 2016, 12:49:27 PM »
TIPEX is a useful mask to stop silver solder flowing where you don't want it  :thumbup:
« Reply #3 on: April 03, 2016, 12:58:49 PM »
Now that's a useful bit of information I hadn't even thought about...
« Reply #4 on: April 03, 2016, 01:23:43 PM »
Tipex fluid is really useful stuff in the workshop. I use it to put an start index mark on a chainsaw chain link when I'm sharpening the teeth.
OZ.
Offline PTsideshow
« Reply #5 on: April 03, 2016, 05:40:16 PM »
A graphite pencil line will also stop silver solder from crossing #2 pencil never heard of tipex fluid will have to keep a look out for it. :nrocks:
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
« Reply #6 on: April 03, 2016, 06:14:55 PM »
Tipex is white out in the St(ates.
Offline PTsideshow
« Reply #7 on: April 14, 2016, 05:39:29 AM »
Ok now, Now about using white out as a  silver solder stop, marking on wood pen blanks,but never thought about using it as a marking item. Will have to try it. :nrocks:
Thanks.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
