Author Topic: Did make a find. =)  (Read 11966 times)
Offline NeoTech
    • Roughedge Hobbyworks
Did make a find. =)
« on: March 30, 2016, 02:45:39 AM »
It's not often you get the opportunity to buy a large collection of tools for cheap. One of the really good ones was this
A 125mm, 16 insert cutter on a ISO40 driver. No fricking idea if my new mill can handle this.
On top of that like 50-60 large diameter machine taps in metric and imperial sizes.. will sure come handy. =)
Offline PK
Re: Did make a find. =)
« Reply #1 on: March 30, 2016, 03:02:04 AM »
:-) It'll cost you hundreds to crash that sucker!
Offline NeoTech
« Reply #2 on: March 30, 2016, 03:43:46 AM »
Sure will and im not even sure i can actually use it. =)
« Reply #3 on: March 30, 2016, 03:48:42 AM »
What is your spindle horsepower ?
Offline NeoTech
« Reply #4 on: March 30, 2016, 07:31:27 AM »
Nooo fricking idea. but i assume that thing is too big ;D
Offline NeoTech
« Reply #5 on: March 30, 2016, 07:33:07 AM »
Some quick googling, 3Hp. =)
« Reply #6 on: March 30, 2016, 02:55:36 PM »
Do you have spare inserts for that facemill? They look very similar to some that I have got.
« Reply #7 on: March 30, 2016, 04:03:48 PM »
Nice find, even if that massive ripper needs to go on eBay. :)
Those 45 degree square insert face mills are my favorite for removing stock.  Even on a machine with rigidity issues they usually run smooth and can be pushed pretty hard.  The chips are nice to deal with too; not friggin' razor sharp and tightly curled if you get your feeds/speeds right.
The round insert ones are nice too, but I still prefer the square.
Offline NeoTech
« Reply #8 on: March 30, 2016, 04:23:29 PM »
Yeah I have 2 sets of extra inserts, it's SNMK insert, square  ones without holes in the middle. =)
Offline NeoTech
« Reply #9 on: March 30, 2016, 04:24:22 PM »
Ah yeah the light 3 insert ones is nice. I tried the round ones today runs reeeaaaly nice..  check my storebro combi mill for video and image. =)
Offline PeterE
  • Gothenburg
« Reply #10 on: March 30, 2016, 04:52:48 PM »
NeoTech,
Way back when I was using a SAJO 53 UF mill at Chalmers University we had a very similar facemill to your 16-bit one. Ours was a 12-bit and the SAJO with 4HP didn't have any problems with that.
So I guess that if you don't take overly large cuts your 16-bit facemill will work on your mill as well It leaves a very nice surface afterwards!
/Peter
Offline howsitwork?
« Reply #11 on: March 30, 2016, 05:03:43 PM »
Nice
I've a 7 tooth maydown one running on a 2hp mill and finish is good .Only tried small depth of cut, effectively a multi-toothed fly cutter but it works! :med:
« Reply #12 on: March 31, 2016, 12:54:04 AM »
Aah, sadly mine are different :(
