Author Topic: Do you lap your female centres ?  (Read 19693 times)
Online awemawson
« on: March 11, 2016, 05:34:41 PM »
I've been doing a bit of between centre turning and cylindrical grinding recently.
Now obviously you need nicely formed centre holes for the work to run nicely - I've always just very carefully drilled my centre holes with a centre drill aiming for the best  finish I can get, but I'm aware that lapping the centres is recommended for precision work.
So do you lap your female centres, and if so how do YOU do it ?
Offline chipswarf
Re: Do you lap your female centres ?
« Reply #1 on: March 11, 2016, 11:05:42 PM »
In 1969, at the USAF Machinist's Course at Chanute AFB, IL, the grinding shop had a center lapping machine. It was set up like a drill press, with some sort of chuck holding a rod shaped stone in line with a static center on the table below. There was a rickety appendage that could be swung into place to move a diamond tip in a 30 degree angle to the vertical chucked stone. Thus, was put a 60 degree cone point on the working end.
After 'truing' the stone point, you'd settle one end of the workpiece into the lower static center and run the turning stone point into the top center. All this story telling is by way of suggesting how you might set up your own center lapping device.
« Reply #2 on: March 12, 2016, 02:29:14 AM »
Only on stuff that has been hardend and quenched , on softer metal I stop feeding the center and hold it for a few seconds .
Offline leg17
« Reply #3 on: March 29, 2016, 10:10:03 AM »
Center Lapping
As mentioned above, center lapping is for hardened materials, typically for grinding operations.
Abrasive center laps are relatively inexpensive.  They usually are available in a couple of grits.  A medium or fine grit will usually work on properly drilled workpieces.  Chuck the lap in the headstock of your lathe.  Install a conventional center in the tailstock.  Carefully position the tailstock so that the workpiece can be held against the tailstock and not accidentally break off the tip of the fragile center lap in the headstock.  Turn on the headstock, maybe about 500 rpm or so.  Hold the workpiece against the tailstock with the left hand and center it as well as you can.  Advance the tailstock carefully until the lap engages the workpiece.  You will hold the workpiece against the tailstock center to prevent it from turning AND to prevent the weight of it to damage the center lap.  Gently make contact with the lap to clean up the workpiece center.  This should not take much effort if the center hole was carefully machined prior to heat treat.  Be careful backing away so as not to damage the lap.  Reverse the workpiece and repeat.
The lap rotates, not the workpiece.
The lap usually will not be able to bear the weight of the workpiece.
Work carefully.
Let us know how it worked out.
Offline ian99
« Reply #4 on: March 30, 2016, 10:08:07 AM »
Great title for a thread and I was hoping for some pictures. But I guess I have a dirty mind!
« Reply #5 on: October 20, 2016, 08:16:53 AM »
Interesting....I never even knew this. Now I'm considering it.
Found this pretty informative "How to lap a Center on a lathe"
Now my questions: Where do you find small carbide "laps" in europe? Can carbide burr used instead? Those can be used only on soft material, but maybe there are harder:
https://www.shop-apt.co.uk/carbide-burrs-60-countersink-type-j.html
I envision carbide being very useful for small centres. 120 grit stone can't be dressed very small and survive.
My next related question would be about how to dress dead centres....but let's wait for it. I don't have this setup:
Some silly videos too:
Turn the voice down...next one has exceptionally irritating muzak
« Last Edit: October 20, 2016, 09:01:38 AM by PekkaNF »
« Reply #6 on: October 21, 2016, 07:00:24 AM »
A toolpost grinder does a very good job on centres. It also has many other uses and is relatively simple to build one from scratch if you don't fancy buying one.
Toolpost grinding a lathe centre:
OZ.
« Reply #7 on: October 22, 2016, 12:05:01 PM »
Thanks.
I wonder how Andrew et.al. finishes centres.
I'll try most simple stuff first and see where it takes.
I did a little reading on 1915 book "Modern toolmaking methods" and there was a little descriotion of conical lampping and lappin on centre holes.
Apparently some sort of nutating or orbital component is needed to prevent rings or distortion of the conical form.
I'm not planning of making any orbital mechanism like on jig grinders that has planetary (orbital?) and reciprocating motion (oscillating) movements. I tried to google those mechanisms for hours, but could not find any illustrations.
Online awemawson
« Reply #8 on: October 22, 2016, 12:16:51 PM »
Male centres I can do easily on my Jones & Shipman 1300 EUIR cylindrical grinder, but I've still not got any way of lapping female centre holes other than a suitably pointed wooden dowel and lapping paste.
« Reply #9 on: October 22, 2016, 01:11:39 PM »
How does it works out? I read somewhere that rings are nuicance and paste has tendency to accumulate at the wider part of the hole (and make taht part bigger). Some texts suggest using brass lap and to make it 0,5 - 1 degree more acute to comesate somewhat that tendency. Other book said that you should "peck" very briefly repeatedly and use slow rpm. Probably the same reason.
Online awemawson
« Reply #10 on: October 22, 2016, 01:36:25 PM »
I've only done it once as an experiment, and it wasn't very scientific. Certainly improved the centre hole cosmetically but I had no means of any quantitative measurements
« Reply #11 on: October 23, 2016, 03:00:03 AM »
I wonder how well small cylindrical rotating diamond file would work, when feed at half angle?
Like those:
http://www.netkonttori.fi/adeona/745949/web?1402058056
Offline leg17
« Reply #12 on: November 04, 2016, 11:16:43 PM »
Andrew
Buy a center lap and follow my detailed instruction.
Done in the tool and die and machining industry all the time.
You don't have to re-invent the wheel.
« Reply #13 on: November 23, 2018, 02:15:13 AM »
Depending on your intrest this might be OT or not. Least my question is closely related:
How to true female centre to OD of the clinder? Specimen is surface hardened very accurate tool steel rod, relatively soft centre (carbide cuts easy, HSS just about).
I bought well used and some parts missing small bench centre. Checking against blued surface plate shows slight dip on the middle of the table and rails. Very slight.
Just about fits my DIY clindrical "test bar" l=300 mm OD25mm.
Shows less than 0,02 mm of TIR, I would like improve it a little without grinding OD.
The indicator is off on that picture, I moved the bench centre to be able to take clear photo.
Offline Pete49
« Reply #14 on: November 23, 2018, 09:47:30 PM »
Yes as often as I can.  :beer:
oops oh metalwork....bugger
« Reply #15 on: November 24, 2018, 04:03:05 AM »
Pekka,
I made a test bar for my lathe using some hardened and tempered ground bar. I could drill the centres with a centre drill but there was still some runout. I held one end in a collet and supported the other end with a fixed steady (right at the end) and then bored the centre with the topslide set at 30 degrees to the lathe axis and it's now within about 0.001mm TIR.
« Reply #16 on: November 24, 2018, 08:13:56 AM »
Thank you Phil.
I tried it once, but had trouble of making a small boring bar to bore out small enough centre. Now, when you reminded of this method and I'm thinking if I have broken solid carbon end mill I could grind the small boring bar.
