Author Topic: 2-6-0 Mixed Trafic Tender Locomotive  (Read 86787 times)
« on: February 09, 2016, 02:43:50 AM »
Its been some while since I started a thread, but I haven't been idle. Since getting my Simplex in Steam and doing a little tidying up work on it I've been pondering what to take on as my next long term project. I have the fancy to doing a larger tender loco, I dropped on a set of Don Young drawing for his 5" Gauge 2-6-0 Horwich Mogul otherwise known as a Crab due to its appearance. Don's drawings are beautifully detailed and have many of the features of the full sized engine, but her I hit a problem, I'm not that bothered about it being an exact scale model as long as it looks ok when its over on the far side of the track I will be happy I'm more interested in its ease of manufacture, and it being a good runner. So I will be using Dons drawings only as a guide, and will be redesigned it extensively to make it easier to make:- her are my objectives and list of constraints for the design.
Objectives:-
1:- 5" Gauge Miniature Locomotive
2:- Good Reliable Runner
3:- Extensive use
4:- Haul a minimum of 8 people
5:- Resemble a 2-6-0 Horwich Crab
Constraints:-
1:- All Features to be functional and relevant to use of a Miniature Locomotive
2:- Minimum of cast parts
3:- Make Maximum use of Don Young's design
4:- Maximum Use of laser cut parts
5:- Maximum use of commercially supplied Items (Boiler and Fittings)
6:- Simple Construction
7:- Simple and easy to maintain
8:- Transport by one person
So there we have it:-
Every project has to start some ware so I decided to start with the cylinders as I thought this would be the most difficult part to make and if I couldn't make them there was no point in taking it any further. I didn't wont to use castings I wanted to make them from a billet of cast iron, this called for a redesign of Don Young's drawing. I kept all the main critical for function features:- over all length valve ports cylinder piston valve relationship etc, but reduce the cylinder diameter to 1 3/4" 45mm and simplified other features so that it could be made from billet.
Progress to date:-
Cutting the meehanite cast iron billet to size.
I then roughed it out on the mill and finished square using an angle plate
spotted out the cylinder and valve position using the mills DRO and located in large four jaw using a wobble bar.
Roughed out the bores.
And then set up on the cross slide and using a between centre boring bar finished the bore.
First bore done only another three to go.
That's as far as I've got.
I'll keep you posted as things progress.
Re: 2-6-0 Mixed Trafic Tender Locomotive
« Reply #1 on: February 09, 2016, 04:05:36 AM »
I like your idea the cylinder castings from Reeves are £367.06 , will be watching at 72" long not so small .
« Reply #2 on: February 09, 2016, 05:02:20 AM »
Looks good Stew,  :dremel:
maybe a bit too ambitious for me..... :scratch:
« Reply #3 on: February 09, 2016, 07:29:06 AM »
Reminds me I really do need to make progress with my Fowler 4F.
The cylinder (inside twin) will also be hewn from the solid.
Looking forward to seeing more of your project.
« Reply #4 on: February 09, 2016, 07:32:42 AM »
Thanks for looking chaps
I bought all the bar material to make both cylinders including covers, piston, valve sleeves and valve spool for £160 so I recon I've saved myself a nice bit of cash, to be honest I think what they charge for castings is extortionate. On the down side there is quite a bit of machining to get them where I want, but on the plus side the continuous meehanite is lovely to machine, free of blow holes and hard inclusions, and once you have the billet for the cylinders squared up its a lot easier to handle than an odd shaped casting, I won't round the outside up until I have all the rest of the features machined.
I'm just going to take it one part at a time, my first hurdle is the cylinders, its pushing the capacity of my machine, so I'm keeping my fingers crossed.
I'll keep you posted with updates, so watch this space.
« Reply #5 on: March 21, 2016, 08:15:45 AM »
Well I've got the cylinders finished
And a few process shots
Offline joshagrady
  • Country: es
« Reply #6 on: March 22, 2016, 02:14:54 PM »
Wow!  That's looking great.  Keep up the good work, and keep the pictures coming.
Just to get a sense of the scale of the project, what is the size of your lathe?
« Reply #7 on: October 11, 2016, 05:13:37 AM »
Well its been a busy summer I've been beavering away on this project as well as running my Simplex Loco I recon I've clocked up about 250 miles on it, any way I thinks I'm well over due for giving you guys an up date, I'll probably spread it over a couple of post as I've made a fair bit of progress.
Valve sleeve
Spool Valve
Piston Rings
Valve Cover
Guide bar bracket
Family Picture
I've got the frame built and the cylinders mounted I'll show pictures of this in the next instalment.
« Reply #8 on: October 11, 2016, 07:38:55 AM »
Stew',
Nice to see you are making progress.
I have just (last night) made a start on machining the wheels for my Fowler 4F. I must post some pictures and bring the thread up to date.
Must remember to charge the camera batteries this time.
« Reply #9 on: October 11, 2016, 04:18:49 PM »
work well dun
« Reply #10 on: October 12, 2016, 02:16:01 PM »
Thanks for your comments chaps
Her's a few more in process shot build:-
The horn blocks were made from the off cuts of the cylinders
The frames were Laser cut the horns were screwed in place and the frames bolted back to back and the horns milled out so that everything lines up
The horizontal streachers were just 3/8" black plate the vertical streachers were laser cut fabrications silver soldered together.
Drag Beam was also a LASER cut fabrication silver soldered together.
Hers a few shots of the assembly so far
I've now made a start on the wheels axles and axle boxes I'll up date you when they are done.
  • Country: ie
« Reply #11 on: October 12, 2016, 04:23:10 PM »
Who on earth makes a 7" rule?
Seriously, great progress.
Laser cut frames? Ye youngsters have it so easy in my day it was a hacksaw and files!
« Reply #12 on: October 12, 2016, 05:02:51 PM »
And so it starts........
You were lucky to have a hacksaw!  :D
Nice build says the lurker!
« Reply #13 on: October 12, 2016, 05:27:29 PM »
Those assembly pics show you've come a long way, already.
Nicely done Stew!  :thumbup:
« Reply #14 on: October 13, 2016, 01:37:51 AM »
RDG they give them away when  you make a purchase they have there Tel No and web address on the back along with the moto "A little bit extra with RDG"
Hacksaws and files you were lucky to have them it was flint when I started.
 :lol: :lol: :lol: :lol:
Thanks for your input chaps
« Reply #15 on: October 13, 2016, 07:27:21 AM »
 A quick aside re rules (scales to our American and European colleagues).
Some time back at work I was having problems getting some 'rule size' cutting jobs the right length.
It turned out that one of the staff had clipped the end of the rule while measuring a job in the bandsaw.
So he ground off 1/8" from the damaged end. And didn't tell anyone.
« Reply #16 on: October 13, 2016, 01:00:40 PM »
Stu, cracking build.
Can I ask your process for profiling the cylinders - they look lovely, I can`t believe you have profiled them from the billet!
« Reply #17 on: October 13, 2016, 02:29:54 PM »
Hi Cris
The radius profile is just for appearance the cylinders will function just as well if they were left square. So all I did was to mark the radius on the end face and roughed them out with a series of flats with an end mill then blended them in with a file they didn't need any more than that.
« Reply #18 on: October 13, 2016, 02:43:02 PM »
Cheers Stu, fully understood it was appearance only but they look lovely. So they were hand filed. Jeeez.... I need to practice more!! Excellent work (but as I`ve said for many years, sod the engines and build a clock!  :wave: :) - you`d make a bloody brilliant clock )
I look forward for the next instalment.
Offline Auskart
« Reply #19 on: October 13, 2016, 11:25:48 PM »
Nice work  :clap:
Offline millwright
  • Leeds West Yorshire
« Reply #20 on: October 14, 2016, 04:40:25 PM »
Nice job Stew looking forward to more on this build.
« Reply #21 on: October 28, 2016, 02:46:58 AM »
Thanks for your interest
I,ve just completed machining the wheels: I was given a set of casting by a friend, some one had made a start of machining them the outside face had been machined up and the hole for the axle had been machined, some had the back face cleaned up, and all had the back hub face machined, but the hole was too big and the hub face was to thin meaning the rim of the wheel would rub on the frame. A set of unmachined casting will set you back about £200 so it is well worth the effort to recover them.
First job was to fit a bush with a flange to the bores fixed in place with high strength loctite and a small grub screw fitted down the joint.
That should keep it in place.
Next job was to set the wheel up in my four jaw chuck clock the dia of the bush up true and tap the back face of the wheel up against the face of the chuck, to do this I had to put some packing on the jaws in the shape of some small button magnets.
With a boring bar to get every thing running true rouch the bore out and finish off to size with a reamer
Face up the new hub to give the correct stand out, face the rim to the correct thickness and turn the dia for the flange to size.
I have a 300mm old fasion  vernier to measure the rim, the price was right and it does the job
To machine up the front face I used my home made face plate that I made a few uears ago from a disc of steel donated by bluechip, so that I could clamp down on the rim I used two way tape to stick four washers to the plate and I screwed a mandrell into the centre.
Turned the mandrell up for a nice push fit on the bore.
Rough out the out the wheel tred dia and flange thickness
With a radius tool finish off the dia and flange thickness
Using the same mandrell as for the face place mount it on the mill and clock the mill up on it zero the DRO and move the off set for the the crank pin and lock the table up.
Drill and ream for the crank pin:- its important that the off set is exactly the same for each wheel so once you've done one don't move any thing.
Thats it all done
That saved me £ 200
 :D :D :D :D
« Reply #22 on: October 28, 2016, 06:47:04 AM »
Nice wheels,
My procedure for machining the wheels for my 0-6-0 was very similar. The main difference was that I built a jig to hold them and clamped it on the faceplate.
Mine are really only temporary as they don't have the required number of spokes.
Good job; keep it going.
« Reply #23 on: March 08, 2017, 03:37:43 AM »
Thanks for your interest Dave you were the only one to reply so I guess your the only one watching.
Any way
Hi Chaps:- if any one does read it.
I've not updated this thread for a while I did get distracted with a couple of other projects and I was a bit put off from updating it because of the problems I was having with photobucket, but now that I've gone add free its making the process far easier.
I have done some work on it and I'm planning too have a intense period of activity on it.
So her's the update
The main driving axles are made fro 3/4" ground mild steel bar, the first job was rough cut them to length.
Face them all off so that they were all exactly the same length.
Using a collett centre drill.
Then between centres turn down the end for a nice close fit in the wheels
I then drill down the ends and cross drilled oiling way this way to oil the bearing all I have to do is squirt oil down the centre of the axle. sorry no pictures of this.
Next turn up and fit the driving pins for the wheels and loctite them in the wheels
Axle boxes Made from a chunk of cast iron
1st job square the chunk up to size
Cut each axle box off from the chunk
In the four jaw face off to length.
Then in the mill I found the centre of each box and put in a centre drill, and using a woble bar centred the box back up in the four jaw and drill out and reamed 3/4"
Then turned up  3/4" mandrell
Transferred  the chuck over onto the spin indexer and milled the groove for a nice slide fit on the frame hornblocks this way every thing will be concentric keeping the axle boxes in line.
Radius off the groove this is so the axles will roll on the track curve and humps and bumps.
This is the axles and axle boxes assembled with the springs.
Then using a quartering jig assemble the wheels:- its important for the wheel coupling that each set of wheels are quartered exactly the same
I post a picture of the wheels in the frame at a later dat.
I'm currently building the pony truck this is being fabricated from laser cut parts.
« Reply #24 on: March 08, 2017, 01:16:54 PM »
Hi Stew,
David's not the only one watching..... I just don't often comment (probably should really).
It's a great looking build so far, surprisingly complicated things, these steam engines! Are you making your own boiler, or getting a commercial one? Oh, and nice fix on those wheels BTW. You make it look and sound so simple, I'd be swearing and cursing after the 2nd one I bet.
Looking forward to the next installment!
