Author Topic: 3D Printed Solar Shield  (Read 219867 times)
« on: October 31, 2015, 04:20:08 PM »
I got an Aldi weather station a few days ago to replace an old one that had gone faulty.  One issue I had with the old station was the outside sensor hung on the workshop wall and got cooked in the sun.  So this time I thought I would have a play at a solution.
I started with a vague idea and drew the sensor in CAD as my starting point.
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/Solar%20Radiation%20Shield_zps25nuo0sk.png3D Printed Solar Shield
The above was pretty much at the end of the design process.  In reality I started with the sensor, then the top and the rest of the design grew during the printing of parts.  No real plan from the start and even contemplated the layers printed in two complete halves.
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/IMG_0003_zpse2wu1eoo.jpg3D Printed Solar Shield
I had printed most of the parts and used three carbon rods to hold everything together, they are a tight push fit into the top.
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/IMG_0004_zpsf8mlnwd1.jpg3D Printed Solar Shield
Next came the sensor mounting plate, pick up the spacers between layers for this plate to attach too.  Hold the sensor in with tie wraps, easy to change the batteries when needed.
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/IMG_0007_zpsi7wbsfvf.jpg3D Printed Solar Shield
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/IMG_0008_zpsnofn6ojb.jpg3D Printed Solar Shield
Last part to be printed is the base.  This part picks up the three 3mm carbon rods and attaches to the 19mm alloy tube I am using,
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/IMG_0009_zpsseevlcgr.jpg3D Printed Solar Shield
Couple more tie wraps to secure to the post, in reality not really need as its a firm fit.
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/IMG_0010_zpsuvaaql7k.jpg3D Printed Solar Shield
Now installed and working.  The whole project took about 16hrs, designing the next parts during prints of the previous parts.  The material used is PLA printed in 0.2mm layers and this is also a test to see how it holds up to the outdoor environment.   The top plate has a coating of bees wax to see if it helps reduce UV damage and water resistance.
It was a nice quick project making something useful and try out some new ideas.
                    Joules
Re: 3D Printed Solar Shield
« Reply #1 on: October 31, 2015, 06:52:16 PM »
Nice one :beer:
« Reply #2 on: November 01, 2015, 01:46:46 PM »
 :thumbup: nicely done ,,,,,,,,,,I may have to invest in a 3D printer .
Offline SteveT
« Reply #3 on: November 01, 2015, 04:20:03 PM »
Nicely done
Steven Tyrer
lives in Cardiff South Wales
« Reply #4 on: November 01, 2015, 05:45:49 PM »
good job there on at having one of them at work
Offline Pete49
« Reply #5 on: November 01, 2015, 09:59:23 PM »
Very nice job you made of it. I have found many uses for my 3D printer since I bought it, way more than I thought I would. Just a bit of info for you re plastics. PLA plastics degrade in the weather /sun. ABS is the better filament to use for that purpose. I have seen how the sun can affect plastics here in Australia especially in our summers.
« Reply #6 on: November 02, 2015, 06:53:50 AM »
Thanks Pete,
      we print as part of our business, however we have no definitive information on how the plastic degrades, so this is for our own research.  We have had prints in oil and machine coolant for over a year without them degrading.  There is alot of misinformation regarding current printed plastics, so to help our clients we are running tests with real world prints than just tiles and cubes.
Offline nrml
« Reply #7 on: November 02, 2015, 07:39:42 AM »
Very nicely done.  :clap:
Which plastic among the widely available 3D printer filaments would you recommend for parts that will be exposed to grease, oil and cutting fluid?
« Reply #8 on: November 02, 2015, 07:54:41 AM »
If your working temperature is below 50c then without a doubt PLA, it has so far proved for us to be the most unreactive of the printed plastics, in the lower printing temperatures.
Offline nrml
« Reply #9 on: November 05, 2015, 05:26:51 AM »
Thank you. That is very useful to know. I've been having problems with cutting / tapping fluid eating away certain plastic bottles so I wasn't sure if printed supports for a digital caliper style DRO would work. I now have the confidence to give it a try.
« Reply #10 on: November 05, 2015, 03:51:24 PM »
Well great news   :)    My solar radiation shield outlasted my weather station.  Just returned the faulty unit to Aldi  :(  I have put the old weather station back into business after faffing with it and making a new mount, that took all of an hour.   Ain't 3D printers great....
Offline Pete49
« Reply #11 on: November 05, 2015, 10:35:36 PM »
Joules the reason I mentioned the difference between PLA & ABS here where I live in Australia our summer sun is very destructive
 to plastics. Keep in mind when the temp is showing 45-8C in the sun its about 55C and I had a normal non mercury thermometer left in the sun pop its tube, and I actually have a picture of my weather station showing the temp reached 50.1C one day last summer, even the a/c had problems keeping us cool. Left in the sun some PLA here breaks down after a summer outside
« Reply #12 on: November 06, 2015, 09:30:51 AM »
Other end of the scale here Pete.  Damp, freezing conditions, that will be the test over the next few months.  Then the looong glorious English summer   :lol:
Offline Pete49
« Reply #13 on: November 06, 2015, 10:38:52 PM »
you have my sympathies for your upcoming winter and condolences on your summer  :ddb:
« Reply #14 on: January 17, 2016, 07:13:43 AM »
Pete, I am seeing no effect from the Australian sun on my PLA  :scratch:
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/IMG_0106_zpsux2rxshq.jpg3D Printed Solar Shield
Offline Pete49
« Reply #15 on: January 17, 2016, 08:04:49 PM »
bloody hell man do you even know what sun is over there? :lol:
Just a bit of info for you notebook on plastics. I occasionally grab some noodle packs, the type in white plastic cups. I left it out in direct sun from December until today (not intentionally, just where I had finished it) next to my workshop and went to move it today and it turned into plastic splinters. So either sun or UV made it return to the earth  :loco:
« Reply #16 on: August 24, 2016, 05:25:16 AM »
Here you go Pete, once every hundred years or so we get a few hours of sun.....
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/Solar%20Shield%20in%20Action_zpslt7bzzqp.jpg3D Printed Solar Shield
Couple more months and this will have done its first year.  No sign of degradation yet, houses a few spiders.  PLA rules   :poke:
Offline Pete49
« Reply #17 on: August 25, 2016, 12:25:21 AM »
Nice one Joules. Hope you were able to take the time and sit outside. Just another cold sunny day here at 17.4C ....glad winter is nearly over I can't cope with the cold nowdays.
I have printed a couple PLA pieces and will leave them outside and see what happens. Is it the UV that is supposed to degrade it or actual strong sunlight? I found my dashcam buckled pretty badly last summer (no longer operated)
but once I peeled the case off it was fine so considering making a case/finding a case to suit as I hate waste or throwing out good stuff  :loco:
Offline efrench
« Reply #18 on: August 25, 2016, 03:43:21 AM »
PLA wouldn't be my first choice for something sitting in a car window.  It will get hot enough to deform as you've seen with your dashcam.  ABS would be my first choice and I've had good success with nylon weed trimmer line.  The later requires an all metal hotend.
« Reply #19 on: August 25, 2016, 05:58:26 AM »
I did a dashcam mount in PLA, my first total part failure, but not unexpected due to the heat at the top of the windscreen.  It did prove the design though as I have a bit of PLA knocking around.
My mate printed the final part in E3D's Edge PET filament.  It has survived all the recent sun and gone on to be my second favourite filament.
Offline Pete49
« Reply #20 on: August 25, 2016, 11:41:25 PM »
My dash cam was a commercial ABS (?) camera and the case died fairly quickly, didn't last the summer. I just warped around the internals so that the controls wouldn't work. The new one I remove as soon as I park up for any longer than 10mins. At least they be cheap enough to replace for now  :doh:
« Reply #21 on: August 26, 2016, 02:19:24 AM »
I don't think black is the ideal colour for a dash cam.  You might notice the mount I designed was to get the camera under the roof lining to offer it some protection from direct sun.  Ours is a cheap Aldi camera and works surprising well, once I cracked it open and refocused the lens.
Offline Pete49
« Reply #22 on: August 26, 2016, 11:51:13 PM »
 I agree black is not the best colour but all the manufacturers seem to think so. Interesting fix Joules and I will see if I can get away with that idea. Ideally a case in white or a reflective colour would be the best option I think. I had to remove the camera even though its winter as I noticed the case starting to curl  :Doh:
« Reply #23 on: October 29, 2016, 06:34:17 AM »
Hasn't time flown, the battery in the sensor packed up so needed a replacement.  It's almost a year to the day that this went up, it's dealt with the UK weather, some discolouration on top, no delamination of the print.  It's now back on its post for another year of operation, pretty conclusive evidence that PLA is suitable for outdoor use in the UK at least.
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/IMG_0171_zpsu8byw5jf.jpg3D Printed Solar Shield
Offline Noitoen
« Reply #24 on: October 29, 2016, 06:38:45 AM »
You could print a clip on replacement cover.
