Author Topic: diy sheet metal pinch rollers  (Read 65196 times)
Offline Andrew Wildman
Re: diy sheet metal pinch rollers
« Reply #25 on: October 10, 2015, 03:51:06 PM »
I did ponder what the best design was.  In the end I decided that the bushes may get jammed and so the design I chose enables you to pull the rollers as well as push.  If it becomes a pain then I can always alter them.
I made the plates to hold the screw that moves the pinch roller.  No pictures of this as it was just drilling in the mill.  These plates were then used to drill m8 tapping size holes in the side plates.  I also fitted the keys in the gears.
http://i1031.photobucket.com/albums/y373/dreeewman/slip%20rolls/002_5.jpgdiy sheet metal pinch rollers
the holes were tapped in the drill
http://i1031.photobucket.com/albums/y373/dreeewman/slip%20rolls/003_6.jpgdiy sheet metal pinch rollers
Progress so far with mock up screws
http://i1031.photobucket.com/albums/y373/dreeewman/slip%20rolls/004_5.jpgdiy sheet metal pinch rollers
Had a fiddle about with different sized sheet.  Any more than 3mm thk and the gears cl are too far apart and start to get a bit lumpy but this is ok as I don't think the rest of the components are up to rolling any more than that.
« Reply #26 on: November 05, 2015, 09:17:29 AM »
Ive been away for a bit but I have had this week off, so in between decorating I have got a little bit done on the rollers.  The base plate was made and the tapped plates to adjust the third roller.
http://i1031.photobucket.com/albums/y373/dreeewman/slip%20rolls/001_6.jpgdiy sheet metal pinch rollers
I also fabbed up a handle.  Got to use the press brake that I built a few months ago!  Tools to make tools to make tools.........
http://i1031.photobucket.com/albums/y373/dreeewman/slip%20rolls/003_7.jpgdiy sheet metal pinch rollers
Here are the rolls nearly finished.  just some adjusting screws to make (the ones shown are just bolts)
http://i1031.photobucket.com/albums/y373/dreeewman/slip%20rolls/007_1.jpgdiy sheet metal pinch rollers
http://i1031.photobucket.com/albums/y373/dreeewman/slip%20rolls/005_4.jpgdiy sheet metal pinch rollers
« Reply #27 on: November 18, 2015, 03:49:36 PM »
....So we are nearly at the end of this build.  I churned out a few adjusting screws and some t handles:
http://i1031.photobucket.com/albums/y373/dreeewman/slip%20rolls/002_7.jpgdiy sheet metal pinch rollers
Here is a couple of views of the screws and handles installed.  Just need to cut the groove for the dog point grub screws into the screws, press some ferrules onto the ends to the t handles and give the thing a clean up and break a few edges and the project is complete.  Not really sure what I am goint to use the rolls for, but I am sure a project will turn up.  Anyone think of a tool I can make with this tool??!! :beer: :beer: :beer:
http://i1031.photobucket.com/albums/y373/dreeewman/slip%20rolls/004_7.jpgdiy sheet metal pinch rollers
http://i1031.photobucket.com/albums/y373/dreeewman/slip%20rolls/003_8.jpgdiy sheet metal pinch rollers
« Reply #28 on: November 18, 2015, 08:09:35 PM »
Looking really nice!  :thumbup: :clap: :clap: :clap:
Offline kennlindeman
« Reply #29 on: November 19, 2015, 02:37:14 AM »
Hi All
Any chance somebody could give me a copy of the drawings?
Thanks
Ken
Offline nrml
« Reply #30 on: November 19, 2015, 04:25:49 AM »
Did you have to modify the Vice you have on your Shaper? I had a similar one the next size down on my shaper but I struggled to get any accurate work done because of jaw lift. In a moment of frustration and rage a week or two back, I bought one of these ''ARC Versatile Milling Vices - with swivel base'' http://www.arceurotrade.co.uk/Catalogue/Workholding/Machine-Vices
I need to fix the old one, but it has joined that endless list of projects waiting to be done. I'd be very interested in seeing how others fixed thiers.
Offline JHovel
« Reply #31 on: November 19, 2015, 07:15:49 AM »
Beautifully made. Thanks for showing us in such great detail!
While you were posting your progress, I stole some of your design ideas and made one as well. I found your bushing design of the free-wheeling roler prevents rolling tapers. So I made mine without the outside flange on the bushes and turned a taper on the frame sides of the inner flanges, to allow the roller to be scewed as far as the diameter allows.
I also used a large (620mm diameter) wheel off some kind of large valve instead of a crank. I find the spokes on it allow better application of my muscles in all positions - whereas a crank will only work well in either straight pushing or straight pulling position. The inbetween positions where you have to push down or lift up don't work well with wide or thick material.
Works a treat!
Cheers,
Joe
Cheers,
Joe
« Reply #32 on: November 19, 2015, 12:56:20 PM »
 :clap: :clap: :clap:   VERY  Nicely done Andrew  :thumbup:
Offline Houtenkrullen
« Reply #33 on: November 20, 2015, 03:36:35 AM »
Andrew, very nice build!
How does your design compensate for the fact that the gears travel when you change the settings of the feed rollers? In the drawings of ausdier I suppose it is done by clever placement of the idler gears?
I ask because I acquired some parts of someone which were meant to be used on
 building a set of pinch rollers (3 stainless rolls plus bearing bushings, gears, and sideplates which may not work). He doesn't know how he had planned to make them anymore. I would like to finish them, but now need to design around the parts. There are only three gears though. I probably need to measure them and get a fourth one, or just use two as Andrew did?
Peter
« Reply #34 on: November 20, 2015, 03:53:50 PM »
Thanks all for the comments.  Nice to know that people are enjoying the build. :D
Houtenkrullen, The gears on mine are a large module so they can operate over a large range of centre distances.  The limit is about 3mm before they feel lumpy, but then the rollers are limited to that anyway as they are only 40mm dia and start to flex too much with material much above that.  The design with 4 gears is required with smaller mod gears and probably is a bit better for higher gauge material.  The three gears are probably for a pyramid design (google it!).  These may be better for higher gauge materials but leave a flat spot at both ends of your work piece.  Pays your money takes you choice with the design options
JHovel, That is fast work, you put me to shame.  I put a fair bit of clearance in the slots for the 3rd roller bushing, but you are right that your tapering capability is still more limited that a flangeless bush (is that a real term???).  I probably will not use these very much and will roll a taper even more seldom.  If it becomes annoying I will open up the clearance further.  Your rollers look a very useful bit of kit.  I like the wheel, although making the handle was the bit of the build I enjoyed most.
nrml, The vice is ok.  I clearly got a good one and considering I only paid £40 for it I was quite surprised how good it was.  I have eyed up one of those ARC vices for the Omnimil to replace the ageing Elliott one that is on it.  I may resort to a full rebuild on the vice it as with a less pitted bottom (not my lack of depth judgement) it could be a lot easier to use.
Ken, I think there are plans on the web for the GH Thomas design.  This was just a design I scribbled on the back of a water bill while the wife was watching Bake Off! :smart:
Just waiting for some dog point grub screws to turn up and then this one will be ticked off the list.
Offline rythmnbls
    • My U-Tube videos
« Reply #35 on: November 21, 2015, 09:20:48 AM »
Hi All
Thanks
Ken
See my earlier post in this thread. There's an attachment containing the GH Thomas design.
Regards.
Steve.
« Reply #36 on: December 07, 2015, 04:31:27 PM »
Finished.  Now onto the next project......
http://i1031.photobucket.com/albums/y373/dreeewman/slip%20rolls/001_7.jpgdiy sheet metal pinch rollers
