Author Topic: diy press brake  (Read 13912 times)
Offline Andrew Wildman
diy press brake
« on: August 16, 2015, 02:34:41 PM »
I have a number of project updates.  The first project is a diy press brake.  I was fed up of using the hammer and vice method of folding sheet so I purchased some 20X100 plate from a local fabricator and build a press brake to fit in my 20T press.
Machining the 'punch'
Press brake with removable die and back gauge:
brake in position:
first fold:
Re: diy press brake
« Reply #1 on: August 16, 2015, 03:40:05 PM »
That is really nice. Wish to do one like that some day.
Re: diy press brake
« Reply #2 on: August 16, 2015, 09:18:59 PM »
Holy cr@p that's nice!
Re: diy press brake
« Reply #3 on: August 16, 2015, 09:36:19 PM »
oooo nice
Offline jcs0001
Re: diy press brake
« Reply #4 on: August 17, 2015, 10:25:15 AM »
Beautiful work.  That should be really handy.
John.
Re: diy press brake
« Reply #5 on: August 17, 2015, 11:11:08 AM »
Is punch/die combination bolt-on business? There seems to be extra hardware under the die.
Re: diy press brake
« Reply #6 on: August 17, 2015, 12:41:50 PM »
The punch *(upper bit) is one piece but the die* (lower bit) is a bolt on part so that I can change it to better suited for smaller bends.
* probably not correct terms!
Offline rotorhead
Re: diy press brake
« Reply #7 on: August 19, 2015, 05:11:56 PM »
Hi there Andrew,
Is that miller an Elliott, the table apron and base configuration looks similar to mine...
If it is, what model is it please...
Sunny Scunny,
North Lincolnshire.
Re: diy press brake
« Reply #8 on: August 20, 2015, 07:57:12 AM »
mill is an omnimil 01 based on a U2 with an Elliott/victoria turret head.
Handy machine but could do with a rebuild.  when I bought it the power down feed on the head was bust so rebuild that  (may post some pics when I find them)
Offline rotorhead
Re: diy press brake
« Reply #9 on: August 20, 2015, 06:29:05 PM »
Looks a nice piece of sturdy kit, I would venture more rigid than a Briddy.
Pictures would be welcomed, I had to make a cross feed nut for mine several years ago, sadly no pics though...
Sunny Scunny,
North Lincolnshire.
Re: diy press brake
« Reply #10 on: August 20, 2015, 07:48:17 PM »
** Indeed, the correct terms, despite the fact that many in the metal fabrication business indiscriminately refer to both the upper and lower chunks of shaped metal as "the die".  I've had funny looks when I mention anything about a "punch", even though most catalogues and technical publications use these terms.
Offline NeoTech
    • Roughedge Hobbyworks
Re: diy press brake
« Reply #11 on: September 29, 2015, 03:30:55 AM »
This design, couldn't be adapted for a shear as well? *just thinking*
Re: diy press brake
« Reply #12 on: October 01, 2015, 04:00:38 PM »
good idea...brain whirring :smart:
Offline NeoTech
Re: diy press brake
« Reply #13 on: October 02, 2015, 02:18:51 AM »
two pieces of O1 tool steel with a 45 degree on one side and a straight on the other mounted to a "jig" that can be fitted between the bending die and the head. you dont need more than 2mm clearance.. unless you want pieces of steel flying, and u wanna cut something thicker.
