Author Topic: Einhell MTB3000 minilathe potentiometer  (Read 20971 times)
Offline cre8tor
Re: Einhell MTB3000 minilathe potentiometer
« Reply #25 on: May 05, 2015, 05:49:30 AM »
I thought I can ask this question here now..
So I would like to buy indexable lathe tool set, but I really don't know if 10mm shank is suitable for my minilathe. Original tools
are with 8mm shank with fixed tips. Under these tools need to be approx. 1-1.5mm spacer if I want tip to be center of metal, which
is going to be turned or faced.
« Reply #26 on: May 05, 2015, 07:00:02 AM »
I use 10mm tooling on my mini lathe  but have a qctp to accomodate the centre height....
Offline cre8tor
« Reply #27 on: May 06, 2015, 01:15:57 AM »
Ok!
I think I must buy too that QCTP. Is there any suggestions, what manufacturer and what model QCTP is suitable for my 300mm Einhell
mini lathe? On my lathe is fixed bolt where original tool post stands. Do I need make any modifications to fit QCTP for my lathe? Or is it
just straight fit to it?
Offline Kjelle
« Reply #28 on: May 06, 2015, 01:45:59 PM »
Hi, have a later version of the same lathe, and I bought c2/c3 qctp from Arc... No fitting, no fuss, no muss. Not sure if your lathe is an earlier c2-300 in blue, but if it is, Seig stuff fits directly... And spares are easy to come by, mostly from the "normal" vendors in the UK (Arc, Warco etc.).
Kjelle
Offline cre8tor
« Reply #29 on: May 06, 2015, 10:46:40 PM »
Ok, good to know. My lathe is Einhell MTB3000 and in this forum I found some picture of it: http://foro.metalaficion.com/index.php?topic=6474.0
400W motor, and colour of blue :)
edit. Looks like same as this Warco: http://www.warco.co.uk/metal-lathes-metalworking-lathe-machine/302983-mini-lathe-hobby-lathes.html
Offline Kjelle
« Reply #30 on: May 07, 2015, 03:36:39 PM »
Sure looks like a Seig C2....
I have changed the gibs (for Arc's brass one's), made one h**l of a difference! Lots of info on these on the 'net.
Kjelle
Offline modeldozer
  • Country: es
  • Valencia, Spain
    • AJ´s Truckmodeling
« Reply #31 on: May 07, 2015, 04:09:36 PM »
Hi,
Have the same lathe (highly modified),  it is actualy the same as the Real bull ones as sold by Amadeal.
Abraham
Offline cre8tor
« Reply #32 on: May 08, 2015, 12:07:20 AM »
Kjelle
http://www.arceurotrade.co.uk/Catalogue/Machines-Accessories/Lathes/Model-C3-Mini-Lathe/C3-Super-C3-Mini-Lathe-Upgrades#Mini-Lathe-Brass-Gibs-Set
Does these fit directly for my 300mm lathe ? Or do I need to made modifications for these?
edit. Answer to myself, yes it fits :) From LMS: "These gibs are items 94 and 107 on your parts diagram. Fits all 7x10, 7x12, 7x14, and 7x16 mini lathes."
« Last Edit: May 08, 2015, 08:21:53 AM by cre8tor »
