Author Topic: Mystery Measuring Stick  (Read 33096 times)
Offline S. Heslop
Re: Mystery Measuring Stick
« Reply #25 on: May 04, 2015, 09:54:31 AM »
Wouldn't a wide blade on top like that tend to block what you are aiming at to a dangerous degree? If there's movement laterally or behind, how can you tell?
I misread the website I linked and it suggests that those tangent sights were used for direct fire in 19th century artillery, so now the blade thing is back to confusing me.
Offline steampunkpete
« Reply #26 on: May 11, 2015, 02:15:40 AM »
Thank you all very much for your ideas and suggestions.
I think that I am probably right in thinking it is a calibration device for artillery. It's purpose would be something like fine alignment of the computer to the cradle or the piece, so only a very small scale would be needed. It is conceivable that it might be for the setting up of indirect fire equipment.
I think that a visit to the RA museum is now on my to-do list.
Peter
Offline Joe d
« Reply #27 on: May 19, 2015, 09:52:30 PM »
Found it!  This thing is a ventometer, used for adjusting military rifle sights
http://www.militaryrifles.com/britain/MHVentometer.htm
If you decide you don't need it, let me know :)
Cheers, Joe
(edited for crap spelling :doh:)
« Last Edit: May 19, 2015, 11:11:37 PM by Joe d »
« Reply #28 on: May 19, 2015, 10:07:19 PM »
Ahh, click! The fact that it isn't a sight itself and is removed solves all the questions I had re robustness, the measurement increments, why vernier, and wouldn't it block the view.
It is a removable adjusting tool. All of those then are answered. But also as a tool for setting sights, it does relate to weaponry and angular measurement, as Rob said early on.
Offline Arbalist
« Reply #29 on: May 20, 2015, 04:11:40 AM »
Joe's link is pretty conclusive. I'm surprised though as it doesn't look robust enough and even looks bent in the first picture.
Offline S. Heslop
« Reply #30 on: May 20, 2015, 06:16:32 AM »
Cheers, Joe
Thank god! This has been haunting me.
« Reply #31 on: May 20, 2015, 07:41:29 AM »
I'm guessing it was originally kept in a case and used for calibration, not active battle use. It would be pretty clumsy and slow for that. So robustness not an issue. It's basically a caliper.
Maybe this one, ex-service, was tossed in a drawer somewhere and got bent.
« Reply #32 on: May 22, 2015, 02:28:31 AM »
Well done Joe - champion WWW searching. :D
I had tried for hours and not found it.
I have to say that I feel pretty smug that functionally it is exactly what I deduced, except that I had thought it for artillery (father being RA) than for small arms. Now I know where to start I can do some more research on it.
Thank you very much Joe, and all the other contributors.
« Reply #33 on: May 22, 2015, 12:08:50 PM »
Further info:
Made by a company called "Allison-Gregory" or "Gregory-Allison" depending on source.
This one is for fine sight adjustment in the horizontal plane, and is associated with setting up the sight for windage. I have found an antique gun dealer who sells Ventometers, and has a few examples of this exact model. One in good condition, as mine is, sells for £65, so it isn't entirely without value.
The ventometers that work in the vertical plane are of a different design.
« Last Edit: May 23, 2015, 02:23:28 AM by steampunkpete »
Offline Joe d
« Reply #34 on: May 22, 2015, 05:12:24 PM »
Pete:
Wish I could claim amazing Google-Fu powers, but as is much more normal for me, found it when I was
looking for something else!
But, at least now you know :thumbup:
Cheers, Joe
