Author Topic: Machine tool stands/ bases  (Read 11253 times)
« on: April 22, 2015, 07:28:18 PM »
Hi All , I have been trying to get a few more things sorted out in the workshop, mainly making a stand for a Thiel die filer and a Meddings bench drill, I was about to start from scratch but was given an old metal bench so chopped that up to make the die filer stand and made the drill stand from scratch.
  Here are a few photos of the process.
  The donated metal bench
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20001.jpgMachine tool stands/ bases
Chopped up, then welded up in its new form, the only bits left over are next to the new bench.
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20002.jpgMachine tool stands/ bases
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20007.jpgMachine tool stands/ bases
The floor in the workshop is all over the place so I wanted adjustable legs to level things up, I welded big nuts into the legs then used a bolt with lock nut as the levellers. A couple were tight after welding so having no tap the right size I cut some slots into a spare bolt and it cleared the threads.
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20008.jpgMachine tool stands/ bases
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20009.jpgMachine tool stands/ bases
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20014.jpgMachine tool stands/ bases
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20010.jpgMachine tool stands/ bases
I had a spare Thiel badge so decided to add that to the frame, as a finishing touch lol, I cut a bit of pipe and made a addition the shape of the lowe half of the badge , its on the bench behind the badge
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20023.jpgMachine tool stands/ bases
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20026.jpgMachine tool stands/ bases
Now onto the drill stand, I wanted it to have a couple of shelves for storage, same sort of thing but made from scratch. Its got the same system for levelling legs.
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20012.jpgMachine tool stands/ bases
I found 4 old cast iron castor wheels and decided to put two wheels at the rear of each frame just off the ground so if the machine was tilted back a touch it would rest on the castor wheels and be able to be moved about if needed. I cut and plated the ends of some box section to house the wheels then welded these to the frames
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20020.jpgMachine tool stands/ bases
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20021.jpgMachine tool stands/ bases
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20028.jpgMachine tool stands/ bases
A coat of primer, I started brushing and rollering it on but ended up getting the spray gun out.
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20029.jpgMachine tool stands/ bases
Then a coat or two of John Doubleboosts favorite colour Machine Green RAL 6011 lol
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20030.jpgMachine tool stands/ bases
Then inch thick ply for the tops and shelves and the machines bolted to the tops
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20032.jpgMachine tool stands/ bases
http://i1167.photobucket.com/albums/q631/micktoon/Madmodder%202015/Frames%20plus%20photo%20booth%20033.jpgMachine tool stands/ bases
 Another job ticked off the list but plenty more to go.
  Cheers Mick.
Re: Machine tool stands/ bases
« Reply #1 on: April 23, 2015, 01:37:54 AM »
A good job nicely executed- well done that man  :thumbup:
« Reply #2 on: April 23, 2015, 02:58:17 AM »
Thank you very much. Good execution and very enjoyable photos.
« Reply #3 on: April 23, 2015, 05:30:53 PM »
well dun mick
« Reply #4 on: April 23, 2015, 06:13:48 PM »
Nice strong looking job
Shame about the colour  :bugeye: :bugeye: :bugeye: :bugeye: :bugeye:
Offline Zadig
« Reply #5 on: April 24, 2015, 01:56:41 AM »
Very nice work, great pictures. Thiel made lovely machines, I used to have a couple of their mills.
Offline ArnieB
« Reply #6 on: April 24, 2015, 03:25:01 AM »
A job well done.  puts my welding to shame.
Arnie
« Reply #7 on: April 24, 2015, 04:00:41 AM »
   Well made Mick, like the portability feature.
« Reply #8 on: April 24, 2015, 02:22:51 PM »
 :thumbup: Nicely done Mick  :clap: :clap:
I do like your wheel mounts  :med:
« Reply #9 on: April 25, 2015, 09:20:11 AM »
Looking good!  :clap: :beer:
