Author Topic: soba brand qctp set  (Read 6505 times)
Offline polecat
soba brand qctp set
« on: April 01, 2015, 10:21:45 AM »
afternoon lads i have bought the above set it supplies 3 off 1/2" holders and 1 off 3/4" holder what is the 3/4" holder for please new to this so bare with me
thanks polecat
Re: soba brand qctp set
« Reply #1 on: April 01, 2015, 10:54:55 AM »
Polecat,
In case you have any 3/4" tools you want to use.
I have the same set.
Online John Rudd
« Reply #2 on: April 01, 2015, 11:56:19 AM »
Me too....and use the 3/4 holder for parting tools.....
Offline polecat
« Reply #3 on: April 02, 2015, 04:13:58 AM »
thanks lads for that i thought they had put a skemmy one in
polecat
Offline polecat
« Reply #4 on: April 05, 2015, 03:03:21 PM »
just setup the qctp wow this will save a lot of setting up just need some decent indexable insert cutters is there any difference in buying thicker than the usual 8mm/5/16" for my 7 x 14 arc eurotrade lathe are they better being thicker or will i stick with 8mm
thanks polecat
« Reply #5 on: April 05, 2015, 04:09:31 PM »
I have a selection of different sized tools from different machines and I just use whatever seems best for the job in hand. I suppose that the bigger the tool the less problems with vibration. But it often comes down to whatever tool will get into some small space.
Many of my carbide tools are the brazed-on tip variety. I like these because they have positive rake.  My replaceable carbides are ex-industrial and have negative rake. Ok for heavy jobs.
Stick with whatever your comfortable with.
Offline Fergus OMore
« Reply #6 on: April 05, 2015, 04:48:29 PM »
thanks polecat
I suspect that if your 3/4" one has vees machined it , it is for a parting tool rather than a 3/4" lathe tool.
Regards
Norman
Offline mechman48
« Reply #7 on: April 09, 2015, 10:26:25 AM »
To my knowledge any vee on the bottom is for boring bar use, to centralise & grip squarely...  :scratch:... ?
George.
George.
