Author Topic: All squared away.  (Read 22263 times)
All squared away.
« on: March 14, 2015, 04:36:00 PM »
The headstock on my red lathe can be removed. and it is located by a pivot bolt at the gear end and a clamp bolt at the chuck end. As it can swivel on the gear end bolt there is a pair of coinciding parks at eh front to assist in re-aligning it.
But let's assume there is some doubt about the marks.
How would the members ensure that the head is truly concentric with the lathe centre line.  If it isn't the chucks and face plate will not be square to the axis.
To add to the interest let us assume that you don't already have a face plate to assist in this operation.
I know how I would do it,  but am curious as to how others see the problem.
Re: All squared away.
« Reply #1 on: March 14, 2015, 05:15:43 PM »
Test bar http://www.arceurotrade.co.uk/Catalogue/Measurement/Parallels-Angle-Blocks-Test-Bars and a dial guage in the toolpost , or iff the tailstock is spot on a bar between centres .
« Reply #2 on: March 14, 2015, 06:07:38 PM »
If you put a round bar in the chuck and then take average readings with a dial gauge it should be possible to align it without having to buy an expensive test bar.
Offline Arbalist
« Reply #3 on: March 14, 2015, 07:00:09 PM »
Offline steampunkpete
« Reply #4 on: March 15, 2015, 03:50:59 AM »
If I had them, I'd use a round bar in a collet rather than a chuck.
I'd use the longest bar that I had, as the longer the bar, the more accurate the achievable alignment. If I had some straight tube I'd use that for preference, but it would have to be closely round tube, not oval.
I'd then mount a dial gauge on the saddle. I'd then check that the bar was straight by setting the dial gauge at the end of the bar furthest from the headstock and rotating the chuck by hand. I'd also check at a couple of intermediate points in case in case the first reading was at a null point  on a banana shaped bar.
If then the bar proved to be straight, I'd take dial gauge readings along the bar by traversing the saddle.
Adjustment to the headstock by splitting the difference in traditional form. The headstock to be bolted down to a known torque between adjustments.
This all assumes that the mis-alignment is only in the horizontal plane. Given the risk of dirt trapped beneath the headstock, distortion etc. I'd also check alignment in the vertical plane by setting the dial gauge on top of the bar and repeating the alignment check along its length. If there was a problem there, I'd weep and then bang my head on the headstock until one of them was properly aligned.
By this time I'd be in need of a cuppa or a beer.
What have I missed?
« Reply #5 on: March 15, 2015, 07:43:40 AM »
Everyone seems to have a version of the same idea.
Pete,
..I'd then check that the bar was straight by setting the dial gauge at the end of the bar furthest from the headstock and rotating the chuck by hand. ...
This would not necessarily show the bar was true. You can have a situation where the headstock spindle was absolutely spot on (I should be so lucky ) but any error in the chuck or the chuck back plate would give you the end of the bar rotating around a (small) circle.
You would still need to do the 'rotate and half the error' operation at both ends to find out if the bar or the chuck was causing the difference.
Thanks all for the advice.
Still pursuing the fabled micron run- out.
Offline Fergus OMore
« Reply #6 on: March 15, 2015, 08:42:50 AM »
Not me :doh: Three or 4 jaw chuck with the longest piece that will swing in the gap. Same as a faceplate.
Face the extreme outer edges and clock . If the up and down worries, put a block the saddle and fit the top slide at 90 degrees. Do the same with the clock or even a bit of fag paper!
It's about the 6th Proposition of Euclid- if I recall.
It's amazing what can be done with a bit of metal 'twer that size and a bit of spit and fag paper.
Norman
Offline edward
« Reply #7 on: March 15, 2015, 10:50:14 AM »
I have the same problem with my ancient drummond. My chuck has a bit of a wobble so plan to turn a bit of something down and mic it. We shall see.....
« Reply #8 on: March 16, 2015, 05:00:07 AM »
I think one of the advantages of these methods is that the bar doesn't need to be straight or parallel.  It does need to be round though.
The averaging method takes away all the errors and looks at the axis of rotation of the spindle.
If the bar is a bit wonky then a big foot on the dial gauge might help to eliminate any error due to movement in the wrong plane.
« Reply #9 on: March 16, 2015, 07:26:31 AM »
Sorry, but it is wrong. If you clock a test bar ( ignoring a wiggly chuck or whatever)  your record a combination of out of truth for the spindle- and the wear of the bed.  This cutting of a test piece is all well and good for a new lathe. It is in Myford's setting up instructions for their setting up 'thing'. I've got a test bar that has a No2 MT shank ground from a worn out reamer- great on my lathe which was slideways ground fairly recently - but bloody awful for the same use before that.
The first thing is to assume that moving the saddle is the first step to a quick way to a Moonbeam from a Lesser Lunacy.
Probably the best way is to get the two classic books out. One is Connolly and the other is Schlesinger.  They are the 'modern' editions of Euclid.
And if you have done all this, you still have to do something else- and that is compensate for the deflection of a lathe tool.
Regards
Norman
« Reply #10 on: March 16, 2015, 09:21:01 AM »
But If the spindle bearings and bed are worn enough, then making the spindle parallel with the bed is easy:
 Don't do anything!  :lol:
(Joking, but if wear is signifigant than there is no meaning to the words "making them parallel". )
David is presenting a hypothetical case of an assumed straight bed and unworn spindle, for fun consderation here, I think.
« Reply #11 on: March 16, 2015, 09:38:30 AM »
It's all to do with hides- flat or otherwise. The squaw on the hippotamus hide is equal the son of the squaws of the opposite two hides. Easy as Pi.  :smart:
Norman
« Reply #12 on: March 16, 2015, 09:41:46 AM »
We had pizza and cherry pie to celebrate, Norman, you?
ps. don't forget deflection of the test bar due to clock spring if you're into micron lathes
pps. do you use an air bearing traveling steady on a micron lathe? questions, questions......
« Reply #13 on: March 16, 2015, 10:02:39 AM »
Gave my wife the Book of Pi which was about a guy with a  tiger on a lifeboat. Very confusing!
But I got utterly confused with Holzapffel- the lathe guy who was actually using hippo hide to flatten metal. Seriously, I'm not joking. Then he sold an ornamental turning lathe to the Tsar of Russia and you know the problems Putiin it into today's topics. A sort of Crime here or was there?
I had a really fun. It was how the Planet Venus was used to do the Megalithic Yard and it's almost the Vernal Equinox on which to do the calculations. Look it up- Prof Thom and  Knight and Lomas- University of Bradford
I'm not the only one :bang: :bang: :bang:
Norman
Sorry I wrote Hall and Knight- wrong =Knight wrote my School Algebra book
N
« Reply #14 on: March 16, 2015, 10:47:50 AM »
I think that Mr. VTSteam is quite right again, and if you think about it, we aren't trying to align the spindle axis with the bed of the lathe, we are trying to align it parallel to the locus of some point on the saddle, so there is no real reason why we shouldn't move the saddle.
I'm not certain what is intended by this, and I would welcome an explanation as it might help me to understand.
I'm not sure why there is a consensus on using a chuck rather than a collet. My experience is that collets are more accurate (although they can't be adjusted in the same way as an independent jaw chuck) so what is the advantage of starting the job with a chuck?
« Reply #15 on: March 16, 2015, 12:25:22 PM »
I know how I would do it.
Dave,
Are you brave enough to tell us yet?
Cheers.
« Reply #16 on: March 16, 2015, 12:36:56 PM »
Actually, you can do it with a child's lazer pen- hence my Moonbeams
Norman
« Reply #17 on: March 16, 2015, 03:28:38 PM »
First, catch your child....
« Reply #18 on: March 16, 2015, 04:42:43 PM »
What I did is fit my faceplate then take a very light skip across to the centre.
(That's why I excluded the use of a faceplate in the hypothetical case above)
I then placed a straight edge right cross the plate.
Only if the headstock was square  to the bed would there be no gaps at any point.
If the chuck end of the headstock was toward me then I would get a concave cone,  if it was away from me I'd get convex cone.
Of course, this won't do much good it your chuck back plate isn't square. So I suppose if you treated that the same way then everything should fall into place.
Then you can put a bar in the chuck and do the tests mentioned above.
The truth of the back plate and how well it fits the register and the thread seems to be critical to all this.
« Reply #19 on: March 16, 2015, 04:49:46 PM »
Assuming the saddle slide is square to the ways.
All these problems can come up in building a new lathe.
  • Country: ie
« Reply #20 on: March 16, 2015, 04:59:11 PM »
Surely there must be a logical approach to all this?
Like:
1. Check the headstock play.
     Fit big chuck, Long length of bar sticking out (unsupported)
     Clock it in the two axes and see how much play there is Y axis (cross slide feed) and Z axis ( Up and down)
2. Check any end float in headstock (X axis): clock on end of bar, use a lever on the tool post and back of chuck
When these have been measured and corrected then move onto the saddle and lathe bed alignment checks:
This is as detailed in the Myford set up instructions and uses a machinable test bar (unsupported so use alloy) and take some very fine cuts about 10 " apart. Adust sadle and bed supports until both diameters are the same.
3. Next is the tailstock!
« Reply #21 on: March 16, 2015, 05:18:02 PM »
VT,
...Assuming the saddle slide is square to the ways...
That's the easiest bit.
Stand your clock on the bed and traverse the cross slide from side to side.
Maybe clamp a good straight edge to the cross slide table first and clock against that.
My own cross slide shows less than a tenth of a thou' over it's five inch of travel. That is my reference for everything else.
« Reply #22 on: March 16, 2015, 05:32:20 PM »
Sorry David, I don't get it....from your word description maybe.
Clock on slide maybe, against square on bed.
  • Country: ie
« Reply #23 on: March 16, 2015, 05:40:36 PM »
The saddle has to be square to the bed! It just slides along the reference bedway (either the "v" on the posh lathes or the bed edge (like on ML7s).
What may not be square is the cross slide ways in respect to the bed. This at the moment is not important as we are concentrating on the headstock alignment and making sire there is no twist in the bed.
I have heard that the cross slide is deliberately not set at exactly 90 degrees to the bed! That way when you face a large piece the centre of the work is concave by a tiny amount. Concave is better than convex when facing!
« Reply #24 on: March 16, 2015, 06:00:11 PM »
will, I did say the slide. And it definitely is a concern in new lathe construction, also as I said. And wear can alter the relationship.
