Author Topic: Building a New Lathe  (Read 1341662 times)
Re: Building a New Lathe
« Reply #850 on: January 19, 2021, 07:09:40 AM »
Something like this?:
Sort of..... I use the actual vinyl, rather than the backing sheet. It doesn't crinkle in the laser printer, and so long as I put it through the laminator enough times (probably about 2-3 minutes worth) it seems to transfer 100% of the toner. I'll have to try the backing sheet.... and also, I do like his heated press, that's definitely one to add to the saved eBay searches!
« Reply #851 on: January 19, 2021, 10:34:55 AM »
Thanks guys. I've seen many of the videos, too, and really haven't given it much of a shot yet -- just a simple couple of tries with what was immediately to hand. Three factors are: that the actual size of brass I have is 3.25" x 4.25" so the letters are necessarily fine lined, I don't own a laminator (though do have a model aircraft shrinking iron), and most likely, I wasn't getting the piece hot enough. My only try was on sheet aluminum actually, as a test, since I only have one piece of brass sheet.
To get enough heat and uniform temp, I have seen one person in a video use a skillet on a gas stovetop doing the transfer, heating the metal under, and pressing the paper down with a Teflon scraper.
I haven't tried anything further because I think I should not get sidetracked on that, rather I should finish the ELS and test it first. The lathe is 5 years in the making now. It would be good to finish it operationally while the iron is hot......wait, no, wrong expression....  :wack:
« Reply #852 on: January 19, 2021, 10:44:10 AM »
Having said that, now I can't get this transfer thing out of my mind........
ps. and to add to the distractions, the plasma cutter just arrived and is sitting in an unopened box. I'm doing my best to ignore it and forge on with the lathe's ELS........
« Reply #853 on: January 19, 2021, 12:00:03 PM »
I can hear it calling you from all the way over here in Liverpool!!
« Reply #854 on: March 06, 2026, 12:17:48 PM »
Well after a slight pause of uhhh 5 years I FINALLY completed the ELS for my homemade lathe. For me, where I got hung up was in making the brass plate for a thread table. I was unable to do a good job of that using any type of printer medium as a screen for putting down etching resist. I finally lost patience half a decade ago and simply ran the lathe manually, and continued relying on taps and dies for threading.
This winter's snows and cold here have stopped all my normal casting activity, and put a damper on shop time as well (it's been COLD in there!). Searching for something to do indoors I finally said to myself, finish that ELS threading table plate, test the electronics in place, and finish the damn thing -- you can at least do that indoors!
So out with the printer and various new transparency films, and dry resist film, pieces of scrap test aluminum sheet, a UV blacklight, PC Board etchant, etc and.......nope. I simply could not get a good image of the resist on metal -- there were always bad areas or the exposure was wrong or the contrast wasn't high enough.
I decided finally the problem was probably due to too much of a DIY head on my shoulders. I simply could not get a good enough transparency to expose onto the dry film resist. I had tried every method known to YouTube for this and I could not get their poster's printer results either with an inkjet or laser printer.
I finally thought, what about having it printed at Staples on transparency film? A check online showed this would cost under $2, I could upload the image directly and pick it up in a day. Past experience with the their local printing dept wasn't promising for the other large blueprints I sometimes get, but for two bucks I thought, why not?
Well, the product was perfect. Really solid black. Really clean edges to the admittedly tiny numbers letters I was using. A test run on aluminum showed good masking with the resist film. So I repeated on brass, and all went well! Two bucks. I don't know how much I'd invested over time for special papers inks, toners, etc. to try to get a decent transparency, but it was substantial.
I guess I don't have to DIY everything. :loco:
Well sorry to waste space here with the above long-winded chagrin-ology, but the positive side of all this is: I NOW HAVE THREAD CUTTING CAPABILITY WITH MY (mostly) DIY LATHE!!!  :ddb: :ddb: :ddb: :ddb:
This kinda means my lathe is um, finished....!
(ELS unit and thread table lower left:)
well, maybe not -- I'm thinking about making a new milling attachment...........  :loco:
« Reply #855 on: March 06, 2026, 06:54:26 PM »
Nice
Offline Country Bubba
  • LaGrange, GA USA
« Reply #856 on: March 07, 2026, 05:47:36 AM »
 :bugeye:That looks fantastic! Now to check it out in the real world to see how well it preforms.
Congrats on a job well done.  :jaw:
Art
Country Bubba
« Reply #857 on: March 07, 2026, 09:15:01 AM »
Thanks Tom, Art.  :beer:  :beer:  I'll keep you posted on how the threading works out.  :dremel:
« Reply #858 on: March 13, 2026, 03:33:19 PM »
 :jaw:
That looks amazing.
