Author Topic: Newbie question MT3 collet chuck  (Read 13433 times)
Offline fatoftheland
« on: February 28, 2015, 05:04:08 AM »
Hello, I have a Warco 918 and want to fit a collet chuck to it. I know how to fit and remove my standard 3 and 4 jaw chucks but MT3 collet chucks have a taper with a drawbar thread. Do I need a drawbar on my lathe or is it just an interference fit? Confused!
Thanks
Jon
Re: Newbie question MT3 collet chuck
« Reply #1 on: February 28, 2015, 05:22:30 AM »
Jon,
IIRC, the 918 has a thread nose on the spindle....
There are 2 ways to do this, you could use the method you suggest and use a draw bar, else the 2nd is to buy an  ER chuck that mount on a backplate....like this...
http://www.arceurotrade.co.uk/Catalogue/Collets/ER-Lathe-Collet-Chucks...
If you already have the MT3 ER chuck, then the cheapest option is to use a drawbar..
« Reply #2 on: February 28, 2015, 07:21:22 AM »
Thanks for the speedy answer and the welcome.
My first project will be a drawbar with some sort of centring plate for the spindle hole.
« Reply #3 on: February 28, 2015, 07:25:17 AM »
Tbh, it doesn't need to have a shoulder , a flat washer big enough to go over the spindle bore....
I use a piece of M12 studding with a nut and the washer is made from aluminium....
The ally is soft enough not to deform the end of the spindle, not that the nut needs to be tight....
I just screw the stud into the thread in the taper, fit washer add nut and just nip it up....over tightening just causes aggro when you come to remove it...
HTH....
« Reply #4 on: February 28, 2015, 08:14:47 AM »
A washer with a shoulder is quicker to set up , I have made a short converter 3\8 whit to 12mm that fits imperial collets and only need one drawbar , morse and clarkson go to 3\4" ER32 go to 20mm , if you go for ER you wont need a drawbar as the collets dont have a pocket and long stuff can go up the spindle .
« Reply #5 on: February 28, 2015, 08:23:11 AM »
Oops, yeah I forgot to mention, if you go the backplate mounted collet holder route, as I linked to, as Chipenter says, long stock can go through into the spindle and beyond  if needed....but obviously if you go the MT route you can't do that.... :doh:
« Reply #6 on: February 28, 2015, 11:39:03 AM »
Jon,
Just to second what John Rudd has said,if you go for the draw bar setup don't over tighten it,a light nip is sufficient.
 Morse tapers are very shallow angled creating a high degree of wedging action with a comparatively large surface area and over tightening is a common error made by beginners to lathe practice.....OZ.
« Reply #7 on: February 28, 2015, 01:31:54 PM »
I see some talk of "if you use a drawbar" - would you really trust the taper to hold while turning a part in the collet without one?
A drill chuck I get because almost all of the force is locking the taper even tighter.  But when turning, especially if you are applying force away from the chuck, I don't think I'd feel comfortable without something positively keeping the taper in place.
Having MT3 as the main taper in my combo-mill spindle, I know first hand that those buggers really lock up tight with too much force.
« Reply #8 on: February 28, 2015, 03:44:37 PM »
Sparky,
The original query was how to mount a collet chuck, possibly MT3.
In John's message (post no. 2) he suggested (a) Morse Taper plus drawbar, or (b) mount a collet chuck on a backplate on the spindle, which wouldn't need a drawbar and would leave the spindle bore free for longer stock.
« Reply #9 on: February 28, 2015, 04:20:28 PM »
They don't always stay in a drill press quill, either.......  :(
« Reply #10 on: February 28, 2015, 04:59:25 PM »
Also iff you go for ER collets they are self extracting and don't have to bash seven shades out of the drawbar .
« Reply #11 on: March 01, 2015, 02:29:15 PM »
MT3 just tap it and unwrap it, easy after grollying up just got to have the knack. I am usually on 4 changes an hour daily.
Unlike ER need three pairs of hands, take up extended length stressing bearings and reducing space available.
5C much better wish I hadn't given mine away.
