Author Topic: The CNC experiment build.  (Read 106643 times)
Offline NeoTech
    • Roughedge Hobbyworks
Re: The CNC experiment build.
« Reply #100 on: April 14, 2015, 03:25:21 PM »
Well gray is stylish.. will pour flooring epoxy at a later stage getting a 2-3mm thick protective surface. =)
« Reply #101 on: April 14, 2015, 03:28:42 PM »
Nowt wrong with Grey , the floor dose look belting  :thumbup: , how long before you can give it a coat of sealer and get things moved back in ?
Offline NeoTech
« Reply #102 on: April 14, 2015, 04:25:37 PM »
Guessing it will take a 4-6 weeks or so.. i can use the floor from a week from now, but not seal it until later.. humidity would make it crack if i did. =)
Offline NeoTech
« Reply #103 on: June 22, 2015, 01:32:31 PM »
So after several detours my shop is coming together, only some electrics and new doors left.
My new compressor arrived a tad bit early, you can see it on the left there..
And this is from when i moved it in there.. by myself, by hand.. its effin 220kg..
Offline NeoTech
« Reply #104 on: July 16, 2015, 04:34:06 PM »
And it finally is time to move in..
Got lights up, gates inserted, electricity is drawn.. at last.. time to get back to the cnc part of this thread..
